Right model for 30% grade hill
   / Right model for 30% grade hill #21
That is a nice chart. If you could print it on a something clear you could look right through it to determine the grade/ angle. Now I wonder if there is a App for that?
Just print it on a clear plastic sheet. The white won't print.
Bruce
   / Right model for 30% grade hill #23
Like a sheet protector?
That might work. Be careful, as it will take longer for the ink to dry. It won't soak in.
The sheets I've seen made for printing on have a very slight satin finish.
Bruce
   / Right model for 30% grade hill #24
For the iPhone. Yes. I carpenter :). Works pretty well.
Sent from my iPhone using TractorByNet
   / Right model for 30% grade hill #25
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=319800"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=319801"/>
I have similar apps on my android stuff. I have acutally used them in a pinch. I was thinking it would be nice if you could hold the phone up, camera be on with a overlay of the chart BCP posted. The phone could tell you when you were holding it level like the level apps do. I really got this thread off track.
   / Right model for 30% grade hill #26
the App for stability with that kind of a grade would be a Ventrac (or Steiner)... probably a smaller unit would be suitable for the area that you are covering. I understand the % and degrees issue, but really can't visualize the property. I believe that it kinda depends if you are going up & down or across and back.
Ventrac's - I like them :)
   / Right model for 30% grade hill #27
How much does the Ventrac app cost?:) It would seem to me that a 30% grade ain't that steep, and most anything will handle that. Especially if we are just talking mowing, and not carting round bales around with a loader.
   / Right model for 30% grade hill #28
A Kubota BX will handle 30* easily up and down. 30* about the limit for it going across.
Read your owners book, you won't get enough oil feed.
GODWIN CD150M DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150M DRI...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
2019 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2019 CATERPILLAR...
2014 Dodge Charger Sedan (A53424)
2014 Dodge Charger...
(INOP) 2018 INTERNATIONAL 7400 SBA 6X4 DUMP TRUCK (A51406)
(INOP) 2018...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
