Right model for 30% grade hill
/ Right model for 30% grade hill #21
That is a nice chart. If you could print it on a something clear you could look right through it to determine the grade/ angle. Now I wonder if there is a App for that?
Just print it on a clear plastic sheet. The white won't print.
Bruce
/ Right model for 30% grade hill #23
Like a sheet protector?
That might work. Be careful, as it will take longer for the ink to dry. It won't soak in.
The sheets I've seen made for printing on have a very slight satin finish.
Bruce
/ Right model for 30% grade hill #24
For the iPhone. Yes. I carpenter :). Works pretty well.
Sent from my iPhone using TractorByNet
/ Right model for 30% grade hill #25
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=319800"/>
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=319801"/>
I have similar apps on my android stuff. I have acutally used them in a pinch. I was thinking it would be nice if you could hold the phone up, camera be on with a overlay of the chart BCP posted. The phone could tell you when you were holding it level like the level apps do. I really got this thread off track.
/ Right model for 30% grade hill #26
the App for stability with that kind of a grade would be a Ventrac (or Steiner)... probably a smaller unit would be suitable for the area that you are covering. I understand the % and degrees issue, but really can't visualize the property. I believe that it kinda depends if you are going up & down or across and back.
Ventrac's - I like them :)
/ Right model for 30% grade hill #27
How much does the Ventrac app cost?:) It would seem to me that a 30% grade ain't that steep, and most anything will handle that. Especially if we are just talking mowing, and not carting round bales around with a loader.
/ Right model for 30% grade hill #28
A Kubota BX will handle 30* easily up and down. 30* about the limit for it going across.
Read your owners book, you won't get enough oil feed.
/ Right model for 30% grade hill #31
There is one.. dunno why its off in that video..
2008 Down to Earth Trailers DTE7610G29 10ft. S/A Utility Trailer (A61569)
2008 Down to Earth...
4022CFL (A59228)
4022CFL (A59228)
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2023 Mac Trailers 48ft. T/A Walking Floor Trailer (A61568)
2023 Mac Trailers...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
2023 CATERPILLAR 299D3 SKID STEER (A62129)
2023 CATERPILLAR...
