Welding galvanized material
/ Welding galvanized material #1
Shield Arc
Super Member
Port Orchard, WA.
John Deere, 4200
Wife wanted me to build her an arch out of chain. What a PITA! I should have told her it can't be done:laughing:. No, I should have told her I don't have the right welding machine, and I'll have to buy another one:D. Used some old lashing chain, got it all welded up. Any body want to come over and do the clean up, before I spray the cold galvanize?
/ Welding galvanized material #2
what a wast of a good log chain!!!!
/ Welding galvanized material #4
Arc,
Tell your better half that you now need a large sand blasting cabinet and related equipment to properly clean this arch so it looks show room quality for all of her friends to see. She certainly wouldn't want this looking shoddy now would she.
/ Welding galvanized material #5
If that was galvanized chain to start with you are lucky you are not in the hospital. Fumes from welding galvanized metal without a resperator can cause permanent lung damage. If you see yellow smoke and sparkes don't weld it.
/ Welding galvanized material #7
Just a hunch but I think Shield Arc knows what he's doing?;)
LOL :laughing:
Nice work shield. But regardless or what "kind" of chain it was, I think I could have came up with a better use than making a dang yard decoration for the wife that now needs mowed and trimmed around:banghead:
Arc,
That's a good idea! I've been looking at sand blaster cabinets. Now that I have a new compressor I should make up my mind which one to buy.
You would probably fall over if you knew how much galvanized material I welded in my time. I worked marine construction most of my life. I've been poisoned at least 12-times. One of the last times I got poisoned my wife called the Poison Control Center in Atlanta Georgia. They said there are no long term effects, just treat is like the 24 to 48-hour flu. They must be right, I'm still here! ;)
/ Welding galvanized material #9
Like Shield Arc, I've welded LOTS and LOTS of galvanized. Most of it was flat or curved steel so I ground off most of the coating where the weld was needed but I still always (LOL) made sure I had plenty of air moving the fumes away from me. Never been poisoned enough to have to seek medical but been sick a few times. I assume that was chain you already had on hand, otherwise I'm sure you would have gotten black steel chain.
Nice compressor you have there, what is the CFM?
/ Welding galvanized material #10
My bad, didn't notice the moniker. I found out the hard way. No more good deeds for "friends" with broken boat trailers. Just tell the other half the new compressor needs new "tools" in order to use it to it's full potential.
/ Welding galvanized material #11
Well you did a good job on the chain, that had to be tedious! I welded a galvanized chain link fence down on a trailer for my Dad when I was young and dumb. I know he knew better he welded for years and was a Machinist, but none the less h left me to weld it and went in the house.
I always wondered about the purty colored smoke it was putting off, I had blues, greens and yellow, must of done something right, the fence is still on the trailer and it still being used 30 years later!
/ Welding galvanized material #12
Almost forty years ago I decided to put up an original chain link fence. We lived on a corner and finally had enough of the corner cutters.
I set two inch square tubing posts. Then I tacked up a section of chain links. Then I welded those links solid, broke the tacks at the posts, and inverted it. I had two chains, one sagging normally down on top and the bottom sagged up. I just did the two sections on the corner to see what kind of feed back I would get. They didn't last a week. It didn't matter if they were four or eighty four, they had to step on it to test it. The fence was finished with two sags of chain, no gates. Oh, and I owned a chainlink fence company at that time.
/ Welding galvanized material #14
On welding the galvanized, I'll be sixty five in less than six weeks, been welding galvanized since I was early twenties. We thought we had a health emergency about a month ago, It turned out I had a serious case of too good insurance-itis. Bottom line, finer'n frog hair. I can no longer say I take no medicine on a regular basis. Cardiologist convinced me a baby aspirin a day won't hurt me.
Zinc poisoning is like the body flu, you only feel like you're going to die.
Here are the specs on the new compressor.
Champion VRV7 8 1 Ph 7 5HP Air Compressor Auto Tank Drain Start Stop 2475N7 5P | eBay
In my line of work concrete was the vast amount of the end product. Most of you would be surprised how much steel is involved to hold the concrete forms in place. I've done two all galvanized steel docks. The piling, and beams all galvanized, everything welded together. But most of the steel is cold tar epoxied. You can't burn that stuff off, it has to be ground off.
The first picture is a 24-inch galvanized steel pile. Notice the screw on the bottom? These pile screw in the ground as you drive them. The second picture is of pile with cold tar epoxy on them. The square boxes had to be welded to the pile. Lids were welded on top of the 48-inch piling too. I didn't weld any of this, I was the project superintendent. Every weld on this project was 100% UT. I fired over a dozen weldors on that project. Some of them would walk away from a joint with pin holes the size of your little finger nail in the weld!:mad:
/ Welding galvanized material #16
FYI, google OSHA and "welding galvanized". Even OSHA officially says there is only short term flu like symptoms.
/ Welding galvanized material #17
i had one of them log chains.mine come off the tennessee river .really liked that chain,but someone else helped their self.
/ Welding galvanized material #18
I weld G90 galv at least a couple times a week. I've never had any problems.
-Phillip
/ Welding galvanized material #19
Apparently your "pinholes" are larger than mine... If its the size of my pinky nail, I would call it a hole, not a pinhole.
Aaron Z
/ Welding galvanized material #20
That's one heck of a nice compressor.:thumbsup::thumbsup: Now you can see how your V-350 Pro handles an Arcair torch.:D:laughing::laughing:
Oh, I see you thought like did. It's coal tar epoxy, not cold tar epoxy. I worked in a tank shop and lots of underground tanks were covered with it. They also use cathodic protection on underground tanks. About a year after I left that tank shop, there was an explosion in the paint bay. There were no heaters directly in the paint bay but one of the painters helpers went into a tank to inspect it and a static electricity charge caused a flash fire inside the tank. The tank rolled and it took awhile to get him out. He lived but was badly burned and had a long recovery. The painter was so shaken that he refused to ever go in the paint bay again. I heard from someone who worked there at the time that the painter felt guilty for the accident and couldn't work for over a year afterwards. I think the tank was coated with coal tar epoxy on the inside as well. I think after that all coal tar was applied outside. I recall helping roll coal tar epoxy on a tank now that I think about it.
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2018 MACK CXU (PINNACLE) (A67714)
2018 MACK CXU...
2007 OK TRUCK & TRAILER PRESSURE WASHER TRAILER (INOPERABLE) (A67714)
2007 OK TRUCK &...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2007 JLG 450AJ TELESCOPIC BOOM LIFT (A65056)
2007 JLG 450AJ...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
