CNC Dan
schweizer said:I think I entered something wrong in EpicFEM -- result is 0.2 ft of deflection. ~2 1/2 inches? That's huge!
you have to set the default units first.
prehaps that was 0.2 inches.
Thank you all. I double checked the calcs manually again. 0.2 inches is the correct deflection #, or 0.1 inches for 2 pieces of parallel angle iron. CNC Dan, I was reading the wrong deflection units on EpicFEM (ft vs. inches). You are correct. Thanks.
I don't think buckling or torsion/twisting will be an issue if wood cross members are jammed into the inside of the "L".
Marcus
