Bridge Crane designs and ideas...38' span
   / Bridge Crane designs and ideas...38' span
I meant to ask about the flanges. (thats where the strength is). ASsuming its 6" x ~1/4" also, that makes it a W6x15# beam.
For my calculations I was using A36 steel with 36ksi yield strength. So a 5:1 safety would limit allowable to 7200psi. Most beams are actually a992 which is 50ksi so a 5:1 would allow 10ksi stress.
Assuming the beam above, a 1000# load would be 8660psi stress and 0.905" deflection. NO that would not scare me.
1500# is 13ksi stess and 1.36" deflection. While exceeding a SF of 5:1, still a good ways from failure.
   / Bridge Crane designs and ideas...38' span #122
LD1, a friend has half a dozen 20 foot lengths of what I believe is W31 beams (8" x 8", web and flange thickness seems to be very close to dimensions given for W31). I have no idea what grade of steel they are made from though so I guess you would have to assume it's the lowest grade available. He wants to use them to build a gantry crane and use one of the beams full length for the top beam. Could you please do the calculations for me to see what the maximum safe load would be with both a 5:1 and 2:1 safety factor?
Assuming A36 steel
5:1 max load 3300# and would deflect 0.288"
2:1 max load 8250# and would deflect 0.720"
Static Load Failure would occur at 1.44" of deflection and 16,500# hanging on it.
If it were mine, id personally feel comfortable hoisting ~5k on it. Dynamic conditions hoisting and bouncing something are alot different than a static load. Thus why most are 5:1 for safety.
Assuming A36 steel
   / Bridge Crane designs and ideas...38' span #125
Wait...has anybody checked any of these solutions for Euler Buckling ??? The unbraced length of the top flange is critical in determining the allowable stress in a member induced to bending. Many beam tables only calculate the allowable load based on a braced top flange. Make sure the beam design accounts for the allowable stress reduction due to the total unbraced length of the top flange, including Euler Buckling. I can guess from experience (Registered Structural Engineer for 35 years) that a 6" flange will have a very low allowable bending stress at spans over 12'.
   / Bridge Crane designs and ideas...38' span #126
Assuming A36 steel
Thank you! :) That is a lot more than I thought it would be. He'll be happy!
I'll wait to hear what people have to say about Euler Buckling before I pass any information on.
   / Bridge Crane designs and ideas...38' span #127
NO you mean that a bunch of forum math shouldn't be relied upon for designing gantry cranes?
With a wide flange 8x8 beam, no worries.
   / Bridge Crane designs and ideas...38' span #130
Ld
A structural engineer has said that unbraced length will control beam capacity. Why do you think the unbraced length is not important?
I assume you are designing using a beam table . The beam tables I have used are for braced flanges only
   / Bridge Crane designs and ideas...38' span #131
Knowledge is a wonderful thing! Knowledge of what you don't know about is even better!
I have heard that an infinitely thin and deep beam would theoretically support prodigious weights but would not be able to support itself in real life?
   / Bridge Crane designs and ideas...38' span #132
I have heard ears that an infinitely thin and deep beam would theoretically support prodigious weights but would not be able to support itself in real life?
The infinitely thin and deep beam could support infinite weight if braced at infinitely small intervals
I agree with this, and perhaps others can share their knowledge, instead of making blanket statements.
MANY MANY bridge crane tables out there. Here are just a few I have referenced during this thread.
https://www.cmworks.com/Public/11833/Sngl Grdr Underhung Crane Brdg Kits-113533-71.pdf
http://www.harringtonhoists.com/tech_support/edocs/EDOC 0367 rev02.pdf
None of the beams are braced unless specified. The problem with charts is.....for a given load or span....there may only be 1 beam listed but in reality, any of a dozen beams may work.
Using Mace's w8x31 beam wanting to span 20'.......BOTH charts show a LIGHTER W8x21 beam being good for 1-ton. The harrington chart then jumps to a W10x39 for 4-ton, and the CM chart jumps to W10x26 for 1.5 ton then W10x30 for 2-ton.
So...why the difference right there, 1 calls out for a W10x30, the other for a W10x39?
In either case, The 8x31 beam going to be LESS prone to top fange buckling since it is wider and shorter.
NO I am not a certified structural or civil engineer. I hate how often it gets mentioned....consult and engineer. If I was building a space shuttle...I would. This is a simple span bridge beam. ITs not rocket science, just numbers and formulas. I am just as capable of plugging numbers into the formulas. And am able to verify my results, with many of the charts out there like I posted using various scenerios, weights, and spans. As well as using Strucalc program Which looks at all sorts of other variables. And for a 38' span like my beam, using a wide flange and 5:1 safety....the buckling never pops up.
Perhaps If I were designing a floor or something not dynamic like a crane, I would allow for more than 7200psi bending stress, and then euler buckling would come into play. But limiting bending stress to no more than 7200psi....not a concern with alot of wide flange beams.
So, as far as I am concerned, this thread dont have much left to offer, other than the few that will still pop in and leave their blanket statement of doubt, then offer nothing as far as advise, formulas, or anything to help anyone gain more knowledge.
I have no use for people who are the type to tell you something wont work but refuse to tell you why or explain as if their knowledge is sacred. Not saying anyone here is like that, but feeling like we are getting there.
Along the lines of my previous post.....
Any knowledge or wisdom you are willing to share? Or are you just going to leave it as is?
FWIW, all the reading, learning, calculating, reading more.....I havent heard the term euler buckling until now. So I had to look that one up.
Euler buckling doesnt apply to HORIZONTAL beams. Euler buckling is a concern for COLUMNS.
And making a comment like "I can guess from experience (Registered Structural Engineer for 35 years) that a 6" flange will have a very low allowable bending stress at spans over 12'." Taken out of context makes no sense and dont mean a thing.
A 6" flange on a 6" or 8" beam is pretty substantial. Like a W8x28 or W6x20.....Would have to get to FAR longer than 12' to even worry about top flange buckling.
Now a 6" flange on a 21" beam, like a W21x44....(or about ANY of the S-type beams)....then yea, you need to account for TF buckling and either add a channel cap or something.
   / Bridge Crane designs and ideas...38' span #136
[video]http://thechronicleherald.ca/sites/default/files/imagecache/ch_article_main_image/articles/B97436230Z.120150316192917000GM18STDU.21.jpg[/video]
Simple beam design would indicate the beam is restrained/supported at each end. The tables are just that, Tables. When entering real world design there will be many other factors which must be checked as the beam is chosen. Each condition defaults to another condition even to the support design. The beam seat must also be determined. Temperature conditions in case of say fire and other items of which my knowledge is deficient.
Even the professionals as shown above make mistakes in calculation or construction handling.
   / Bridge Crane designs and ideas...38' span #137
When I worked at the Fab shop we had two large overhead cranes... they had cogged gears with a chain fall to move one end of the shop to the other which was about 200' for the one in the back.
When I built my dump trailer it was child's play to flip it over or turn it to get the perfect angle for mig welds.
Anyway, the shop had a fire and the next day while the bricks were still hot... the beautiful cranes were heaps of tangled spaghetti.... all the aluminum plates on the mills and lathes were puddles on the floor... as was my tool box and tools...
Steel turns to putty with heat and then melts...
   / Bridge Crane designs and ideas...38' span #138
Sort of on the topic of beams and bending, a contractor in Edmonton did a $4,000,000 %$#@! up on a new bridge. They are paying $11,500/day in penalties and put the project about a year behind schedule. People with common sense knew what happened as soon as they saw the pictures but of course the city isn't going to say anything because it's under investigation. 3 month's later they concluded what everybody thought. The contractor installing massive (narrow flange) I beams for a bridge and were putting the beams up 1 at a time and installing all the cross braces as they went. Then I think because they were trying to beat a storm or the wind or something got in a hurry and put the last 3 beams up without putting all of the bracing on each beam before installing the next one. The beams buckled under their own weight. The contractor had to bring in a HUGE crane (1200 ton I think), that there only 2 in the province, to take the entire bridge structure down in 1 piece. One of the local structural shops was able to heat straighten the beams which is a miracle in itself. They got the beams and structure back in place but now it's too cold to pour the concrete. The engineers and the city didn't want to take a chance on trying to keep the concrete above 5 deg. C using heaters and blankets. If something went wrong it would be an even bigger problem as the concrete wouldn't have the required strength. These weren't columns and were definitely horizontal beams so I'm not sure if this is an example of Euler buckling or another type of buckling but it a perfect example of why beams load charts by themselves may not be sufficient when designed weight carrying beams.
Everything I see refers to it as lateral - torsional buckling. NOT euler buckling.
And yes, it must be accounted for. But very difficult to figure on something as dynamic as a bridge crane.
I am not looking at simple beam span charts. I am looking that charts put out by bridge crane companies. Places that sell end trucks, hoists, wheels, etc. Those charts show their recommend beam sizes. If top flange bracing is required, they specify what size channel cap to use.
IF you look at any of these charts, none of the beams all tall skinny beams. The ones that are like the S-type, start specifying a channel cap starting around 28' spans. And none of the wide flange beams start specifying a cap til ~50' spans.
Today though, I am going to pick up my beam. Bout 1.5hr drive. Using only tape measure information provided by the owner, I have concluded it is either a W18x60, W18x65, or W18x71.
Harrington hoists chart tells me the 18x60 is good for 2-ton at 40' span and the 18x71 is good for 3-ton. (The 18x65 will likely fall around 2.5-ton) But my span will be shorter too. More like 37 or 38'. Weather the beam is 60, 65, or 71# dont much matter. It will do what I need with a comfortable safety factor, and the price is good at 15 cents a pound.
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
2014 FORD F-150 STX EXT CAB TRUCK (A60430)
2014 FORD F-150...
2016 John Deere 4044R 42HP 4WD Utility Tractor (A59228)
2016 John Deere...
2019 CATERPILLAR 420F2 IT BACKHOE (A60429)
2019 CATERPILLAR...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
