Bridge Crane designs and ideas...38' span
   / Bridge Crane designs and ideas...38' span
Wow. My idea was to keep your current design of non moving 12' rails with the matching trucks you have, but instead of an underhung hoist (load on the bottom flange of the beam) on one big beam, use a top running design (hoist rides on top of and between two smaller beams).
The two beams do not move in relation to each other. Think IOI instead of a big I with an O hanging under it.
This design also leaves the bottom flanges of both beams available for smaller hoists for greater manipulation of a load. You can hang multiple hoists on a single beam but they are unable to bypass one another. With a main hoist on top and one on the bottom that can bypass the top, turning loads over becomes easier and safer.
This will help you by having smaller beams to lift into place. Two beams can have better torsional rigidity. Top running provides more room under the hook. A larger area of each beam is loaded.
I see what you are saying.
But I dont have enough rail to span 38' twice nor do I have a top running hoist.
What I do have is enough rail for the 12' spans, and 3 under-hung hoist. A 5-ton, a 1-ton, and a half ton. And I have a 5-ton and 1ton hoist.
And seeing what is out there in the used market, I think one large beam is gonna be cheaper than two smaller beams. ITs hard enough to find 38' of beam, let alone 2 of the same size.
   / Bridge Crane designs and ideas...38' span #62
You still don't get it.
Your original post had a picture of three beams welded together. Drop the bottom beam and space the upper two just far enough apart to accept the hoist. You can't build a little car to run on top of two beams? You seemed determined to scab something together from Craig's list and your scrap pile so I went with that.
Where did I tell you to change direction? Where did I tell you to use the rail the long way? I didn't. I only tried to present an alternative to the three beam idea.
With the price of scrap where it is you should find a reasonable price on the real thing. Ask a demolition company as they know they would get very little sending one to scrap. Most current demo jobs were bid with higher scrap prices making a window of opportunity.
   / Bridge Crane designs and ideas...38' span #63
That's how my steel supplier has their bridge cranes.
I have a set of V-groove wheels something like in this link. I thought about building a gantry crane. Mounting the V-groove wheel to the bottom of the 4-legs. Weld clips to the toes of angle iron, with the heel of the angle iron up, and bolt it to the shop floor for rails to run on. Don't see why LD1 couldnt build a cart with V-groove wheels mounted on the bottom, and angle iron on the top of the two span beams for rails for the cart to run on.
Value Brand Caster Wheel, 900 lb., 5 D x 2 In. 1NWG1 | Zoro.com
   / Bridge Crane designs and ideas...38' span #65
farmer2009 I gave you bad information!:eek: The center posts are 8" x 8" x 1/2" wall square tubing. You know how many times a day I walk right by those posts? And forgot what size they are.:eek:
Thanks. Post should be heavy enough. Amazing the little things we never pay attention to.
Oh I get it just fine.
When you mentioned two beams for the 38' span, I was assuming you meant them beams to be stationary, and a beam riding along them. NOT what I want,
this isnt Going to be a "scabbed" together piece. I have a pair of beams for the rails, rail track, columns, hoists, trolleys, etc. I only lack a main bridge beam. depending on whats out there, three beams as I picture is going to be stronger that twp in the method you describe.
Thanks for your input.
   / Bridge Crane designs and ideas...38' span #67
Relax safety police.
This is my own personal shop and no one for hire will be using the crane. No need for inspections or eng. stamp
Whatever beam I go with, I will run the calculations and assign a SWL. Dont need a freakin engineer to do some simple math for me.
Your problems will start when you or your heirs try to sell your property including the shop with your DIY crane. The buyer's mortgage entity will insist on a detailed inspection and will be looking for the engineering design package, the building permits and the periodic inspection reports for that bridge crane. Stuff like that can slow down or kill the escrow.
Good luck and be careful out there.
No intentions on ever selling. And if I do, it wont be hard to take the crane down. But I doubt I will have to worry about any of that. This is rural ohio, not CA or NY. We dont have any building inspections or anything like that here.
Had no issues selling my last house that had I-beams spanning across the garage with trolleys as well as supporting the upstairs floor loads.
Another question for the masses as I cannot find a formula or program to do what I want.
How to calculate stacked beams?
Example: I currently have 35' of W6x12 beam on my rack. Obviously it is too weak to make a span.
If I were to use W12x65 that is listed on c-list (nice 12" wide flanges so not much worry about buckling), I could safely lift 5550# @ 7200psi stress and 0.68" deflection.
IF I were to attach the W6x12 beam under it for the trolley to ride on, how to caclulate the new load capacity? I would end up with 18" of total depth, and 77# per foot total, but obviously the metal isnt distributed like a W18x76 (close) beam is. Which a W18x76 by itself would yield 9230# capacity @ 0.45 deflection.
I am guessing The W12x65 w/ W6x12 under it is going to be somewhere between those two. But would like a way or program to work it out and havent found a formula yet. Would like to try various scenarios as I come across beams, or look back at beams I previously ruled out as they were too small.
   / Bridge Crane designs and ideas...38' span #70
I think you just add the rigidty( moment of inertia) of both. See if you can find an online calculator that will do rectangles, and see what you get for a solid square, and then a rectangle the same size as two of the squares, and see if the moment of inertia is double.
HUSQVARNA RIDING...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56435)
2014 Doyle Dry...
Eaton PRS0100001 145psi Rotary Screw Air Compressor (A56857)
Eaton PRS0100001...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
