My B21 doesn't like ULSD fuel
   / My B21 doesn't like ULSD fuel #1
LazyBoy
Alabama Gulf Coast
Kubota B21
I bought my B21 in 2007 and just used regular low sulfur Diesel available at the gas station, but lately it seemed to be down on power and it didn't push and scoop dirt as well as it did years ago, so I was reading about the new ULSD fuel and how some older diesels don't like it much and read about mixing 2 cycle oil in to help, so I just tried mixing up a batch 100 to 1 with some Husqvarna 2 cycle I had and now my B21 runs smoother and pushes and scoops like it used to, anyone else tried this?
   / My B21 doesn't like ULSD fuel #2
I use 0.5 oz per gallon of two cycle in my B21 and it seems to run a lot 'smoother'. I use the same mix in my 2001 sierra 2500 Duramax.
   / My B21 doesn't like ULSD fuel #3
Interesting, hadn't heard that before. Hope people will chime in with thoughts.
MarkV
   / My B21 doesn't like ULSD fuel #4
Its pretty common in the diesel pickup truck world to mix two cycle oil with your diesel. I'm not convinced it works, but I've also read some stuff that says it works.
   / My B21 doesn't like ULSD fuel #5
I've been doing that for years..... Adding two stroke oil at the rate of about 3/4 oz. oil per gallon of ULSD. Have also tried the Opti-Lube XPD in the wintertime. Can't say as how any of this has made a noticeable difference in the way our trucks or tractors run. But it hasn't hurt them and makes me feel better.
rScotty
   / My B21 doesn't like ULSD fuel #6
I've been mixing 3/4 ounces per gallon of diesel in my little B6100 for some time now and it appears to make a lot of difference, especially in starting. It also seems like the engine doesn't have as much "knock" as it used to.
The article where I read about this subject also said to use marine 2 cycle oil, because of the lower ash content.
   / My B21 doesn't like ULSD fuel #7
One of the guys on Dieselplace.com did a very technical review of lubricity and the marine 2 cycle oil did very well compared other additives (most much more expensive). It ranked 7th in the list of effectiveness and one of the least expensive.
Lubricity Additive Study Results - Diesel Place : Chevrolet and GMC Diesel Truck Forums
IIRC, the original thread was eventually closed and a second one opened if you want to read several hundred more comments.
I really should be adding some to my B21 and B2710.
Thanks for the link Ken45101, good reading.
   / My B21 doesn't like ULSD fuel #9
I used to hear about guys dumping a quart of ATF in their trucks tank before fill up. Does nobody do that anymore? I thought for sure it would have been in the test.
   / My B21 doesn't like ULSD fuel #10
Red ATF? I would really fear it looking like off road diesel if they ever tested your tank. IDK about any advantages but the $5000 fine would not make it worthwhile for me.
   / My B21 doesn't like ULSD fuel #11
Are you sure it was Automatic Transmission Fluid? That's downright weird!
rScotty
   / My B21 doesn't like ULSD fuel #12
rScotty
I promise! Red ATF fluid!
I don't know what reasoning behind ATF instead of oil was but I used to hear about it a lot.
   / My B21 doesn't like ULSD fuel #13
I have been using Stanadyne Lubricity Formula since day one in my BX24. ULSD fuel is low on sulfur which is a lubricate. Injector pumps need lubrication. I also use it in my truck's Cummings engine too.
Lubricity Formula - Stanadyne
:2cents:
   / My B21 doesn't like ULSD fuel #14
:2cents:
IDK if you read the thread I referenced earlier, but the Stanadyne Lubricity Formula comes out right next to two cycle outboard oil both in effectiveness and cost. It's actually a little cheaper than the two cycle oil:
7)Super Tech Outboard 2-cycle TC-W3 engine oil
Unconventional (Not ULSD compliant, may damage 2007 or newer systems)
HFRR 474, 162 micron improvement
200:1 ratio
16.64 oz/tank
$1.09/tank
8)Stanadyne Lubricity Formula
Lubricity Only
demulsifier, 5% bio-diesel compatible, alcohol free
HFRR 479, 157 micron improvement
1000:1 ratio
3.32 oz/tank
$1.00/tank
   / My B21 doesn't like ULSD fuel #15
Why no red dye? I only run off road through my tractor. It isn't a licensed vehicle...
   / My B21 doesn't like ULSD fuel #16
The guys we were talking about were running red ATF in trucks.
   / My B21 doesn't like ULSD fuel #17
We didn't put the ATF in the fuel tanks. We would put a quart of ATF in the fuel filters when we changed the oil and all filters. The idea was that the ATF would burn off any carbon that had built up on the injectors. It could have been an old wifes tell, but it "felt" like the engine ran a little better.:p
   / My B21 doesn't like ULSD fuel #18
Don't want to start a additive war. There are plenty on Diesel sites. I just know Lubricity works for me. :D
   / My B21 doesn't like ULSD fuel #19
No, my intent was to show that your choice compares well.
   / My B21 doesn't like ULSD fuel #20
I remember the ATF thing DT86,works best when your truck is red and white.
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
1999 GMC C7500 S/A Dump Truck (A59230)
1999 GMC C7500 S/A...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A56438)
2019 BOBCAT T630...
2018 VOLVO EC480EL EXCAVATOR (A60429)
2018 VOLVO EC480EL...
