Seat adjustment isn't enough
/ Seat adjustment isn't enough #1
Steppenwolfe
Super Member
The Blue Ridge Mountains
Kubota MX5400, 1140 RTV
Hey, Guys. I'm thinking some one here has already solved this problem. I have an older L2600 I use for mowing. I bought it used with only 210 hours on it. Anyway, I'm a big guy and I need to figure out a way to move the entire seat mechanism back about 4 inches. I have it slammed all the way back now, and it just isn't enough. So, any idea's ?
/ Seat adjustment isn't enough #2
Sure... look at the base. Unbolt it and check clearances, drill new homes in the seat bracket and mount it where it clears & gives you the space you want ... KennyV
/ Seat adjustment isn't enough #3
I've got the big guy problem too. My seat was far enough back, but too low for comfort. Here's some pictures showing what I did.
While scrounging in the junk box for parts I came across some fat rubber grommets and added them to the project to cut the vibration. I think these grommets were originally used on some old Chevy PUs to isolate the cab from the frame. Works good. Don't over tighten the grommets. Use Loctite instead.
rScotty
rScotty
View attachment 316374View attachment 316375
Thanks, Scotty. I hadn't considered the wood, and I like the grommets. I appreciate it.
/ Seat adjustment isn't enough #5
The wood was just supposed to be a quick and easy way to see if the height was right.......that was almost 5 years ago...good thing we oiled that wood.. :)
rScotty
2024 John Deere 6R 130 Tractor Loader (A63109)
2024 John Deere 6R...
(1) New 7ft Chain Sling (A61166)
(1) New 7ft Chain...
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A62131)
UNUSED WOLVERINE...
International Engine (A61568)
International...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
John Deere Z997R (A60462)
John Deere Z997R...
