Seat adjustment isn't enough
/ Seat adjustment isn't enough #1
Steppenwolfe
Super Member
The Blue Ridge Mountains
Kubota MX5400, 1140 RTV
Hey, Guys. I'm thinking some one here has already solved this problem. I have an older L2600 I use for mowing. I bought it used with only 210 hours on it. Anyway, I'm a big guy and I need to figure out a way to move the entire seat mechanism back about 4 inches. I have it slammed all the way back now, and it just isn't enough. So, any idea's ?
/ Seat adjustment isn't enough #2
Sure... look at the base. Unbolt it and check clearances, drill new homes in the seat bracket and mount it where it clears & gives you the space you want ... KennyV
/ Seat adjustment isn't enough #3
I've got the big guy problem too. My seat was far enough back, but too low for comfort. Here's some pictures showing what I did.
While scrounging in the junk box for parts I came across some fat rubber grommets and added them to the project to cut the vibration. I think these grommets were originally used on some old Chevy PUs to isolate the cab from the frame. Works good. Don't over tighten the grommets. Use Loctite instead.
rScotty
rScotty
View attachment 316374View attachment 316375
Thanks, Scotty. I hadn't considered the wood, and I like the grommets. I appreciate it.
/ Seat adjustment isn't enough #5
The wood was just supposed to be a quick and easy way to see if the height was right.......that was almost 5 years ago...good thing we oiled that wood.. :)
rScotty
2012 John Deere 1990 Planter (A63109)
2012 John Deere...
Miller Millermatic 212 Auto-Set MIG welder (A63118)
Miller Millermatic...
(2) 30 Yard Dumpsters (A61166)
(2) 30 Yard...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
(APPROX. 60) UNUSED MISC SIZE RATCHET STRAPS (A62130)
(APPROX. 60)...
