How do you build a bridge over a creek for a Tractor
/ How do you build a bridge over a creek for a Tractor #21
Yep, some culvert bridges can be ugly. Unless they are in Texas.
http://www.tractorbynet.com/forums/...0d1102396363-bridge-atv-542530-endproduct.jpg
http://www.tractorbynet.com/forums/...98-bridge-atv-646693-bridgechainnorthwest.jpg
In Texas we consider this a small 6' culvert:
http://www.tractorbynet.com/forums/...145d1098604192-bridge-atv-517986-woodrail.jpg
Thread - http://www.tractorbynet.com/forums/projects/42791-bridge-atv.html
We built it for an ATV but it would easily hold a tractor if it were a few feet wider.
/ How do you build a bridge over a creek for a Tractor #22
Just dump some rock on each bank and the bottom. Will firm it up and not rot.
Put down some mat first and then rocks on top. If you don't need to cross it when the water is deep, this is enough.
/ How do you build a bridge over a creek for a Tractor #23
Around here, a bridge has to be engineered, a culvert does not.
/ How do you build a bridge over a creek for a Tractor #24
Old trailers make good bridges.
/ How do you build a bridge over a creek for a Tractor #25
Ok, that is a nice bridge. Had I the time and $$, I'd build several very similar though wider. And now of course you have me pondering what I could build with my available resources.
Here is the finished bridge, I need to put a load of gravel on the front and back to level it up a little.
Thanks
Darin
I used (4) 6x6x10 pressure treated lumber. I set them on footers that I dug out friday night filling each one with 5 bags of 80lb concrete and bolted them down.
Total cost was less than $400
Darin
/ How do you build a bridge over a creek for a Tractor #28
Darin[/QUOTE}
I see that pix above is your new bridge.. very cool.
James K0UA
/ How do you build a bridge over a creek for a Tractor #29
Thanks
Darin
Wow that was fast work, Bridge looks good !! a little dirt and gravel to ramp up to it and your all set. looks like that will last for years. and looks good too. !
/ How do you build a bridge over a creek for a Tractor #30
Great work!
24in pin on excavator tooth bucket (A61307)
24in pin on...
2021 UTILITY VS2DX 53FT DRY VAN TRAILER (A59905)
2021 UTILITY VS2DX...
2017 Ford F-550 Mason Dump Truck w/ Liftgate (A59230)
2017 Ford F-550...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
2005 John Deere 7420 (A60462)
2005 John Deere...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
