Rear Remotes
/ Rear Remotes #11
Get 2 of them with the float function, you won't be sorry. ;)
Please explain to this old farmer the need for all three(3) valves to have the float capability at the added expense of $128? In all my tractor experience I've found very few tasks that required a float position on a control valve. Back dragging with a frt end loader bucket for smoothing is one task, operating a disc hay cutter & correct orbit motor operation is another. Thanks as I'm seeking to gain knowledge,Jim
/ Rear Remotes #12
Well, to start with I normally recommend having the controls for the top and tilt cylinders to have the float function as reflected in the quote ""Get 2 of them with the float function, you won't be sorry. "" So I'm a bit confused :confused3: when you ask me about 3 rear remotes having float. Did you need me to explain why to have the "TnT" valves with the float function? :confused:
/ Rear Remotes #13
Yes. And more uses you find as you go and are glad you got the capability up front. ... It surely depends on the extent of variety in the things you do. However these tend to increase for many. - for instance a hyd lifted trailing item like a haybine will lower much more quickly in float vs power down. ... More than 2 would probably never be essential to take the advantage, but being able to plug into any set at random presents its own time and effort advantage.
larry
/ Rear Remotes #14
Different needs for different people, I am about to send out a 4 valve unit, ALL have the float function. ;)
/ Rear Remotes
I was actually thinking that using the float on the tilt cylinder while brush hogging might make for a smoother cut, by allowing the deck to follow the ground contours a little more closely. I had been thinking about disconnecting one of the lifting links and replacing it with a chain running through a section of pipe, but having the float would make for a much faster hitch and avoid having to have all that claptrap handy. Plus with the float it's instantly convertible to no float, if needed.
Curious to try both the lift and tilt in float with the rear blade while contour scraping. I use the FEL float a lot, both for back dragging and for snow removal going forward, so I can see how it might be a sweet setup and how I might kick myself for not spending the additional $60 for that second float function when I'm looking at such a big piece of change to begin with. I'm still sore with myself for not getting the remotes when I bought the tractor.
/ Rear Remotes #16
MtnViewRanch
Please forgive me for misquoting you. I do not see the advantage of float on top and tilt cylinders so may I ask for you to explain the need? Keep in mind my many years of tractor experience is in the agriculture field not industrial or landscaping so this may explain my lack of understanding.
Thank you,Jim
/ Rear Remotes #17
Baby Grand
I can see where float on the center link would be beneficial for mowing. I don't even attach center link on my mower because of using a quich hitch and never modified top link of QH to attach to top of mower. I fail to see how float on a lift link would be beneficial while mowing. The skid shoe on that side would be dragging all the time while in float or were you referring to utilize the float just for ease of attaching implement to draft link?
/ Rear Remotes #18
The 1st valve cannot have float. You can only have a max of 2 float. I use float with my rear blade for moving snow, the landscape rake, and sometimes the pallet mover.
/ Rear Remotes #19
MtnViewRanch
Thank you,Jim
Tx Jim, the float function is used by many for mowing purposes and is why I recommend it for use with the top link. The swivel pivot that comes on many rear mowers is simply not enough movement for mowing banks, up or down. When the float function is used with the side link, this is where I use it for finish grading at intersections where the camber changes and you want the implement to follow the contour of the road, not the tractor as it goes around a corner. Others use it for raking rough ground and just want to clean up the surface, not change how the terrain is. Others have used a hydraulic side link for AG use on hill sides where one row is at a different angle than another.
Many other uses, those are just a few. ;)
2022 John Deere 5055E (A60462)
2022 John Deere...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
Godwin CD150M Dri-Prime Towable Trash Pump (A61567)
Godwin CD150M...
2015 Chevrolet Tahoe SUV (A61569)
2015 Chevrolet...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
John Deere 6125R (A60462)
John Deere 6125R...
