Rear Remotes
   / Rear Remotes #1
Baby Grand
Elite Member
Windsor, CT.
Kubotas: L3240GST B2320HST B5100D & G5200H
Interested in getting a top & tilt outfit for our L3240, but I want to install 3 remotes, first.
Went looking on some Kubota dealer parts pages and can't find anything listed.
I'm looking for the following P/Ns:
L8305 Base Kit
L8303 1st Valve
L8306 2nd pos stacking
L8303 2nd Valve
L8307 3rd pos stacking
L8303 3rd Valve
Are these the right numbers - am I missing a prefix or something?
Any advice on how to find this stuff?
Float or non-float?
Any recommendations would be greatly appreciated!
   / Rear Remotes #2
If Kubota is similar to other tractor manufacturers you can get attachments such as rear remotes cheaper through complete(whole) goods dept than parts dept. For your application one st of controls with float would be enough but float wouldn't be required on all three sets.
   / Rear Remotes #3
Here are the part numbers and price I paid for my 2 valves. Neither are detant, both center closed, non-float. Philip.
  • RECEIPT ORIGINAL no address.pdf
  • RECEIPT 2ND REMOTE.pdf
   / Rear Remotes
Thanks, Philip - that's good information.
Tx Jim - thanks for the Wholegoods idea.
I nosed around some and it looks like there are new P/Ns (and prices).
Complete revision March 1, 2012.:
REAR REMOTE HYDRAULICS
ROPS MODELS:
Must order Base Kit and one Valve Section to complete installation.
L8335 Base Kit and 1st Lever $500.00
Requires L8308 or L8309 Valve to complete Assembly
L8308 Double Acting Valve Section $240.00
Requires: Base Kit and First Lever
L8309 FD Float Detent Valve Section $302.00
L8336 Second Position Stacking Kit $248.00
Includes Hardware and 2nd Lever
Requires: Additional L8308 or L8309 Valve Section
L8337 Third Position Stacking Kit $248.00
Includes Hardware and 3rd Lever
(For Triple Remotes, Second Position Stacking Kit also required)
http://www.dot.state.mn.us/maintenance/equipment/contracts/tractor_utility/2012/Niebur/L%20Series.pdf
So how do you place an order through Whole Goods vs parts?
   / Rear Remotes #5
See the salesman at the dealership to order thru Whole Goods.Pricy proposition but well well worth it.Good Luck!
   / Rear Remotes #7
I also think you should check through about getting it whole goods. It even comes with instructions. You should get 2 with float.
   / Rear Remotes #8
Yes, they are wholegoods items that must be ordered through the dealer sales department. The kits do come with very good installiation instructions. I have personally installed a number of these and it is a lot easier if you pull both the right rear tire and fender. It will take a couple of hours, but a very neat setup when done.
   / Rear Remotes #9
BG, if you do order the the remotes please post the part numbers and the retail price if you don't mind. I've never had a need for rear remotes but still think about getting a set.
   / Rear Remotes
Okay - I'll call the dealership and get a quote for a three valve setup with 2 floaters. What I really want is to be able to run the rear blade with TNT and a blade rotating mechanism that I plan to knock together. But I'm sure that just having them available will open up some other possibilities. I'll post a full report - thanks for all the advice!
-Jim
   / Rear Remotes #11
Get 2 of them with the float function, you won't be sorry. ;)
Please explain to this old farmer the need for all three(3) valves to have the float capability at the added expense of $128? In all my tractor experience I've found very few tasks that required a float position on a control valve. Back dragging with a frt end loader bucket for smoothing is one task, operating a disc hay cutter & correct orbit motor operation is another. Thanks as I'm seeking to gain knowledge,Jim
   / Rear Remotes #12
Well, to start with I normally recommend having the controls for the top and tilt cylinders to have the float function as reflected in the quote ""Get 2 of them with the float function, you won't be sorry. "" So I'm a bit confused :confused3: when you ask me about 3 rear remotes having float. Did you need me to explain why to have the "TnT" valves with the float function? :confused:
   / Rear Remotes #13
Yes. And more uses you find as you go and are glad you got the capability up front. ... It surely depends on the extent of variety in the things you do. However these tend to increase for many. - for instance a hyd lifted trailing item like a haybine will lower much more quickly in float vs power down. ... More than 2 would probably never be essential to take the advantage, but being able to plug into any set at random presents its own time and effort advantage.
larry
   / Rear Remotes #14
Different needs for different people, I am about to send out a 4 valve unit, ALL have the float function. ;)
   / Rear Remotes
I was actually thinking that using the float on the tilt cylinder while brush hogging might make for a smoother cut, by allowing the deck to follow the ground contours a little more closely. I had been thinking about disconnecting one of the lifting links and replacing it with a chain running through a section of pipe, but having the float would make for a much faster hitch and avoid having to have all that claptrap handy. Plus with the float it's instantly convertible to no float, if needed.
Curious to try both the lift and tilt in float with the rear blade while contour scraping. I use the FEL float a lot, both for back dragging and for snow removal going forward, so I can see how it might be a sweet setup and how I might kick myself for not spending the additional $60 for that second float function when I'm looking at such a big piece of change to begin with. I'm still sore with myself for not getting the remotes when I bought the tractor.
   / Rear Remotes #16
MtnViewRanch
Please forgive me for misquoting you. I do not see the advantage of float on top and tilt cylinders so may I ask for you to explain the need? Keep in mind my many years of tractor experience is in the agriculture field not industrial or landscaping so this may explain my lack of understanding.
Thank you,Jim
   / Rear Remotes #17
Baby Grand
I can see where float on the center link would be beneficial for mowing. I don't even attach center link on my mower because of using a quich hitch and never modified top link of QH to attach to top of mower. I fail to see how float on a lift link would be beneficial while mowing. The skid shoe on that side would be dragging all the time while in float or were you referring to utilize the float just for ease of attaching implement to draft link?
   / Rear Remotes #18
The 1st valve cannot have float. You can only have a max of 2 float. I use float with my rear blade for moving snow, the landscape rake, and sometimes the pallet mover.
   / Rear Remotes #19
MtnViewRanch
Thank you,Jim
Tx Jim, the float function is used by many for mowing purposes and is why I recommend it for use with the top link. The swivel pivot that comes on many rear mowers is simply not enough movement for mowing banks, up or down. When the float function is used with the side link, this is where I use it for finish grading at intersections where the camber changes and you want the implement to follow the contour of the road, not the tractor as it goes around a corner. Others use it for raking rough ground and just want to clean up the surface, not change how the terrain is. Others have used a hydraulic side link for AG use on hill sides where one row is at a different angle than another.
Many other uses, those are just a few. ;)
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A59904)
2012 INTERNATIONAL...
KUBOTA L3410 TRACTOR (A60430)
KUBOTA L3410...
2019 FORD F-150 XL CREW CAB TRUCK (A59823)
2019 FORD F-150 XL...
2016 KOMATSU D65EX-18 CRAWLER DOZER (A60429)
2016 KOMATSU...
