Rear Remotes
/ Rear Remotes #1
Baby Grand
Elite Member
Windsor, CT.
Kubotas: L3240GST B2320HST B5100D & G5200H
Interested in getting a top & tilt outfit for our L3240, but I want to install 3 remotes, first.
Went looking on some Kubota dealer parts pages and can't find anything listed.
I'm looking for the following P/Ns:
L8305 Base Kit
L8303 1st Valve
L8306 2nd pos stacking
L8303 2nd Valve
L8307 3rd pos stacking
L8303 3rd Valve
Are these the right numbers - am I missing a prefix or something?
Any advice on how to find this stuff?
Float or non-float?
Any recommendations would be greatly appreciated!
/ Rear Remotes #2
If Kubota is similar to other tractor manufacturers you can get attachments such as rear remotes cheaper through complete(whole) goods dept than parts dept. For your application one st of controls with float would be enough but float wouldn't be required on all three sets.
/ Rear Remotes #3
Here are the part numbers and price I paid for my 2 valves. Neither are detant, both center closed, non-float. Philip.
  • RECEIPT ORIGINAL no address.pdf
  • RECEIPT 2ND REMOTE.pdf
/ Rear Remotes
Thanks, Philip - that's good information.
Tx Jim - thanks for the Wholegoods idea.
I nosed around some and it looks like there are new P/Ns (and prices).
Complete revision March 1, 2012.:
REAR REMOTE HYDRAULICS
ROPS MODELS:
Must order Base Kit and one Valve Section to complete installation.
L8335 Base Kit and 1st Lever $500.00
Requires L8308 or L8309 Valve to complete Assembly
L8308 Double Acting Valve Section $240.00
Requires: Base Kit and First Lever
L8309 FD Float Detent Valve Section $302.00
L8336 Second Position Stacking Kit $248.00
Includes Hardware and 2nd Lever
Requires: Additional L8308 or L8309 Valve Section
L8337 Third Position Stacking Kit $248.00
Includes Hardware and 3rd Lever
(For Triple Remotes, Second Position Stacking Kit also required)
http://www.dot.state.mn.us/maintenance/equipment/contracts/tractor_utility/2012/Niebur/L%20Series.pdf
So how do you place an order through Whole Goods vs parts?
/ Rear Remotes #5
See the salesman at the dealership to order thru Whole Goods.Pricy proposition but well well worth it.Good Luck!
/ Rear Remotes #7
I also think you should check through about getting it whole goods. It even comes with instructions. You should get 2 with float.
/ Rear Remotes #8
Yes, they are wholegoods items that must be ordered through the dealer sales department. The kits do come with very good installiation instructions. I have personally installed a number of these and it is a lot easier if you pull both the right rear tire and fender. It will take a couple of hours, but a very neat setup when done.
/ Rear Remotes #9
BG, if you do order the the remotes please post the part numbers and the retail price if you don't mind. I've never had a need for rear remotes but still think about getting a set.
/ Rear Remotes
Okay - I'll call the dealership and get a quote for a three valve setup with 2 floaters. What I really want is to be able to run the rear blade with TNT and a blade rotating mechanism that I plan to knock together. But I'm sure that just having them available will open up some other possibilities. I'll post a full report - thanks for all the advice!
-Jim
GROVE RT 63S HEAVY DUTY HYDRAULIC CRANE (A60736)
GROVE RT 63S HEAVY...
2007 Ford F-750 2,000 Gallon Water Truck (A60352)
2007 Ford F-750...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
2015 FORD F-550 (A60736)
2015 FORD F-550...
TRI PAC EVOLUTION APU (A60736)
TRI PAC EVOLUTION...
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
