Liquid filled tires
/ Liquid filled tires #21
Forgot to mention that - unless you live in a bog - there should be little concern about loaded R4s cutting ruts. They're wide for a reason, it's called the "footprint". That means how many square inches of tire tread is supporting the tractor at any given time; pounds per square inch of tire contact. Narrow ag type tires (R1) can and do rut in many conditions; small footprint.. And ballast makes them cut even deeper. R4s are meaningfully wider, and R3s (turfs) are often even wider. These respectively larger footprints simply provide more square inches of tire distributing the weight over a larger patch of ground.
//greg//
/ Liquid filled tires #22
Got lots of experts on this thread huh Cleat.... :)
I used windshield washer fluid. Got a smokin deal at the local auto dealership. 180 gallon for $200. Filled to 12 oclock is perfect. I pumped mine in similar to how you did it. Kinda slow but worked fine. And like you,,, locally the tire shops wanted an insane amount of money to add RimGuard.
You'll notice a big difference of the tractor's ability now.
Lastly, didn't realize the myth of straight anti-freeze freezing was still alive??? Guess they better quit storing it in unheated warehouses and hauling it in unheated trucks huh... ;)
Same here. I use WWF. Last time I bought it for $38 for a 55gal drum.
Like you they wanted something like $8 per gallon for Rim Guard.
Chris
/ Liquid filled tires #23
Holy crap! With all the fuss on this subject, I think that a heavy boxblade might be the best option. No toxic issue, no freeze point issue, its a usefull tool most tractor owners already have, you can pile inexpensive bags of quickcrete on it until you give out, and its weight is a better counterbalance for the FEL. Hmm...I think I have made up my mind.
/ Liquid filled tires #24
I was curious, so I had to look it up.
Ethylene glycol disrupts hydrogen bonding when dissolved in water. Pure ethylene glycol freezes at about −12 ーC (10.4 ーF), but when mixed with water molecules, neither can readily form a solid crystal structure, and therefore the freezing point of the mixture is depressed significantly. The minimum freezing point is observed when the ethylene glycol percent in water is about 70%, as shown below. This is the reason pure ethylene glycol is not used as an antifreeze謡ater is a necessary component as well.
this is from wikipedia, I guess the jury is still out on the validity of the info there, but I trust it... usually Ethylene glycol - Wikipedia, the free encyclopedia
other types are probably different of course.
/ Liquid filled tires #25
A point many are missing here is that ethylene -glycol antifreeze as it comes out of the jug already has some water mixed with it. It varies by brand and you need to read the directions to get the right mix for that brand. A jug I have on hand has a chart on it that shows the highest protection at a 70% mix of that product as shipped with 30% clean water. You would have to look long and hard to find some shipped at 100% ethylene glycol but I suppose many have assumed the stuff they are getting is 100% without reading the label.
/ Liquid filled tires #26
RimGuard is sold to all dealers at exactly the same price per gallon. Granted, transportation costs increase with delivery distance. But not enough to account for such a major discrepancy. I still have the receipt to document that I was charged $2.70/gal installed, and some members have reported getting it for even less. I think $2.32/gal was the lowest posted. Unfortunately RimGuard itself does not sell to the general public, instead guarantees exclusive sales territories to their dealers. Pretty good recipe for price gouging. So it seems pretty clear that the $8/gal you cite must include a significantly inflated "installation charge".
//greg//
/ Liquid filled tires #27
What about when youre pullin it?
Well, I just got done grading my gravel drive and was at one time pulling with the box scraper full to the top on level ground and there was no noticeable wheel slip at all. 2 weeks ago I would have required 4WD and I can now do it in 2WD.
I am a happy camper.
Cleat
/ Liquid filled tires #29
Cleat
And that my friend is the goal!!!!
/ Liquid filled tires #30
//greg//
Yea, I remember a setup fee of like $50 per wheel.
WWF is common practice here.
Chris
/ Liquid filled tires #31
I finally got around to filling my rear tires. Tire size is 15-19.5NHS R4. I used RV antifreeze and put in around 220 litres (58 gallons). Total cost was around $210.00.
I figure I just added around 470lbs to the rear of my tractor. That should help with traction and stability.
I used a small submersible pump in a pail and an old hose from a tire pump to fill the tires until liquid was at the valve with the valve at the 12:00 position. Took around 2 hours to do both tires.
Hopefully I will not require 4x4 as often.
Cleat
One way of looking at that "hope" is that when (not IF) you get stuck in 2WD with loaded rears the 4WD is less likely to get you out (-:
i.e. things will have progressed to where you will not just be Stuck, it will be "stuck but good 'n stuck".
Better be good at working your way out with the bucket (-:
/ Liquid filled tires #32
Well, that's clearly a glass half empty viewpoint. So how do you regard owners who ballast all four corners on a 4wd tractor?
//greg//
/ Liquid filled tires #33
//greg//
The need for front ballast in the tires or mounted on a front rack would come form the work the tractor was set up to do. If you were pulling heavy drawbar loads without a front end loader mounted you might need front weight to keep the front end down so the front tires could help pull effectively. You owners manual should have a section telling you how and when to add front weight and how to determine the wheel slip to check that you have it right for the implement you are pulling. I plan to leave my FEL on most of the time and at 1500 lbs counting the bucket that is more then enough on the front so have not loaded my front tires.
/ Liquid filled tires #34
My new tractor (NH T1520) is awaiting a trip to the CU and surrender of my trade-ins (JD & NH 1520s). I didn't ask for it, but 'rim guard' will be included, and delivery to dealers can't cost much here in 'beet country' (mid-MI). I'd have hoped the box-blade to be enough weight for using the FEL as has been in the past with a '1/3 yd' bucket (7308) ... well not always for big rocks, & would have thought the extra wt of R-4s (?) vs turfs would have added a useful bit on top of the B-B's weight. Doubt if I'd appreciate more weight up front when using the FEL to get 'unstuck'. :confused: btw: whether the new guy will adequately replace the other '1520s' I'm done parking a tractor outside with the 'Bumble-Bee' mini BH ;)
/ Liquid filled tires #35
Hey, I tried an experiment concerning antifreeze freezing. I put a container of straight Multi Purpose Anti Freeze, OReilly's brand in my freezer. I also put a container of Windshield Washer Fluid in the freezer. Also put in a thermometer. The freezer temp was 0 degrees F. Neither container of liquid froze. Maybe other brands of straight antifreeze would freeze. Can't speak to that, only to what I stated above.
/ Liquid filled tires #36
Gotta wonder if WWF has other than alcohol in it and whether we'd eventually lose some of it to evaporative leaking between pressure top-ups. Ovrszd, is the O'Reilleys A-F 'pre-mixed' (buying water) or 'you mix' type. (Do we fuss this much over what we put into our radiators??)
Weren't for the cost, Jack Daniels wouldn't freeze easily, and we wouldn't be depending on an 'emergency keg' hung from our neck when stuck out in the 'boonies'. (pant pant .. 'over here, shep!') :D
/ Liquid filled tires #37
//greg//
Irrelevant to my post.
My point is that loaded tires will get him "FARTHER IN" to whatever he gets stuck in.
Engaging 4WD will then have less marginal benefit.
With unloaded tires the warning (wheel slip) comes earlier and as long as you are smart enough to back out of the situation - you usually can.
Blasting through ? - Yeah, lots of people on this forum seem to believe in that, they post heroic tales and pictures.
I think it is idiotic.
/ Liquid filled tires #38
How long were they in the freezer ? and how big were they ?
How long do you suppose it would take 50 or 60 gallons of water (INSULATED in a tire) to even crust over at 0 degrees F ?
There is the surface/volume ratio to consider, e.g. when you double the height, depth and width of anything you increase the volume by a factor of eight, but the area increases by a factor of four, so there is half as much surface area per unit of volume - this affects the rate of cooling.
/ Liquid filled tires #39
Regarding getting stuck with loaded tires: I have all four corners loaded and work my tractor in some areas where getting stuck isn't just a possibility it is a probability. With the loaded tires, I find that 90% of the time all I need to do is engage the differential lock and I walk right out - no 4WD needed. When the diff-lock alone isn't enough, the front wheel assist has always been effective.
The differential lock is one of the better features on these Chinese tractors as it overcomes the issue of one wheel slipping and stopping progress. Not only is it very effective, it isn't as subject to failure as easily as the front drive train is.
/ Liquid filled tires #40
Yes it is a very effective feature but it is not a new idea or exclusive to Chinese tractors. My 880 David Brown built sometime in the sixtys had one as dose my new JD 5045E. I'd say it is pretty much standard equipment on any well designed tractor of any size today.
2025 24in Mini Excavator Bucket Attachment (A64553)
2025 24in Mini...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2023 ASV RT-25...
Hydraulic Breaker Excavator Attachment (A64553)
Hydraulic Breaker...
2017 BOBCAT E50 EXCAVATOR (A63276)
2017 BOBCAT E50...
300# SPIN SPREADER, 3PT (A64278)
300# SPIN...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
