Snow Removal Frustration
/ Snow Removal Frustration #41
If you are concerned about tearing up paved or concrete try the rubber chains. I picked them up this year and had no problem unless ice under the snow on my hill but nothing will help on ice.
Sent from my iPad using TractorByNet
Do you have a link for those rubber chains?
/ Snow Removal Frustration #42
Yes I do.
WWW.rubbertirechains.com
I called them if you are not happy with the chain after 1 use the will refund 75% when I got them. Just spent a fortune on new drive way didn't want to rip it up.
After 28 inches of snow with 40+inch drifts this is what my driveway hill looked like. Also had no problem piling it up.
When I ran out of snow I did the street just for fun!
/ Snow Removal Frustration #43
I have a b2920 too and clear snow with a 6' rear blade and fel. I have loaded turfs. Loading makes a HUGE difference. I don't use chains (turfs aren't too bad as long as the snow doesn't pack to ice), chains would help. I find that i can move up to 11" driving forward with the rear blade at an angle. More than that and i have to go i. Reverse (you bottom out and lose traction). I use the fel for snowbanks and to knock down deep snow. The loaded tires will also help so the angled blade doesn't push around the tractor. I also find operating in medium range and using speed and momentum can help especially on hills. The tires may spin a bit, but if you can keep moving it works. In very deep snow i push with the fel or blade then clean up with the blade.
/ Snow Removal Frustration #44
Weight helps. My 45 hp New Holland has all 4 loaded tires and weighs about 7000# with the 7' LP rear blade. I have a slotted metal pipe on the cutting edge. R-4 tires.
I've used it for 2 Wisconsin winters now with no problems. Chains would be nice for built up ice but so far I've gotten by without.
I put the bucket on for snow.
/ Snow Removal Frustration #45
I have a B7800 which is almost identical in size to a B2920. I had the R4 tires loaded when I purchased it. It was pretty pitiful for moving snow with the FEL. I bought chains and that made a world of difference. If you don't have a need for loaded tires spend your money on some chains.
/ Snow Removal Frustration #46
Here in NE Kansas, I got the same snow situation as "coldstream". That much snow back to back is unusual. And that wet, heavy stuff in round two would make any combination difficult. My 11 HP walk behind snow blower wasn't all that effective either. So..........With my 2012 year B2620 (R4 tires) I had fairly good results with a 300 lb rear 5 ft blade, the FEL and two link ladder chains. I won't load the rears nor buy front chains...nor invest in a front plow for my situation.
I do, however, encounter different situations since I do six neighbors on our road (for free). In some places there are drifts, some are close quarters, some are very hilly, some are concrete, some are black top and some are gravel. And of course, the county road grader and truck plow make driveways inpassable until I get there with my FEL.
I'm learning how to approach each situation by using the FEL, or pushing the snow, or pulling the snow or piling up the snow. My biggest problem was adjusting the rear blade with the 1/4 inching valve that apparently is not adjusted per the dealer. I'm looking into that today. :confused:
/ Snow Removal Frustration #47
Yes I do.
Rubber Tire (Snow) Chains - Traction without damage.
Thank you for the link.
/ Snow Removal Frustration #48
My vote would be for chains and loaded tires in that order. I have a B7500 with R4s - during the winter I have a 60" front blower. The first year I had it I tried it without chains and it was a joke. The tires were loaded, but there was just no traction. I put chains all the way around and traction was no longer an issue at all. I did not leave the chains on the front for more than a few runs. I don't need them (use the brakes to steer when tire slide) and I felt it was extra wear and tear. I believe chains will solve your traction issue.
/ Snow Removal Frustration #49
Try chains first, but don't discount loading the tires. Weight helps a lot more than some people realize, especially when pushing(that goes for anything being pushed, dirt/mud/snow/rocks). If you really don't want loaded tires, consider wheel weights. Either buy them, or make your own.
/ Snow Removal Frustration #50
I just sold my 5 foot 3 point 2 stage blower for 600. See others in same price range right now. Definitely the time to buy.
/ Snow Removal Frustration #51
Adding weight will for sure help, but it is not the be all end all. My tn75d tips the scales around 9000 pounds ballasted like it is and I was having trouble today pushing a six foot bucket to clear an area that hadn't been cleared all winter even with both diffs locked and brand new r1's (several feet of snow). Frozen ground and hard pack provides very little traction for any tire. A good set of vbar chains though will bite into it and improve your traction immensely.
/ Snow Removal Frustration #52
Snow blew in, and the FEL wouldnt make a dent. 7' two stage snow blower was grunting behind the 70 horse 4WD White, but it got through.
Fluid filled tires, no chains, about 12,000 lbs for tractor, plus blower.
Here is a pic of my 6 foot son standing beside the end results.
/ Snow Removal Frustration #53
I spilled some ice out of my cooler, on the ground. the tractor seemed to drive over it just fine. It was 80 degrees out and bright sunshine so it didnt last long enough to get pictures. Y'all have fun plowing snow. :)
Ha, nice one Firemanpat! No snow/ice for you but watch out for those hurricanes! We just can't seem to get winter pushed out of here! 4" to 6" of the white stuff expected here over the weekend - and I already removed my loader and blade! Back out to the barn tonight to get the equipment ready......
/ Snow Removal Frustration #55
... 4" to 6" of the white stuff expected here over the weekend - and I already removed my loader and blade! Back out to the barn tonight to get the equipment ready......
At least you're not alone -- Across the state line here in KS I was doing the same thing tonight. I'm a little farther south where they're saying the storm total could be 5" to 13" at last check.
/ Snow Removal Frustration #56
Very similar experience in Indiana. Larger than normal snowfalls multiple times in a row. A 1600' gravel driveway with lots of drifts. And last time we had a thaw for a day so the driveway turned to heavy slush that I couldn't clear. Temps dropped the slush turned to an inch of bumpy ice and then we got another 10 inches of snow. Now pushing is near impossible.
It made matters worse I just bought myself a Kubota MX5100 4wd, that I love, but the dealer hasn't had time to load the tires and I don't have anything but the FEL to move snow.
So I have my old Ford 2000 with a front blade, which normally works great but with so much snow on the sides of the drive the snow I push doesn't have any place to go. Last night I worked with a buddy, I pushed piles back from the drive with the FEL while he drove the Ford. Eventually we ended hanging an old tire off the box scraper on the back of the Ford and I pushed the tractor with the Kubota.
Now for advice. Same as everyone else, you need weight. Look at ALL your 3pt attachments and ask which is the heaviest. I put my big old 6' bush hog on the back of the Kubota. It is awkward, but all that weight hanging way back from the tractor makes a HUGE difference. With that the Kubota is able push things again. I just wish the blade I ordered would arrive.
I also debate if I can use the rippers on the box to remove my ice layer. Probably not without messing up the driveway even more.
/ Snow Removal Frustration #57
After fighting that problem for 10 years finally wised up and bought a rear PTO snow blower. Use it for the first pass which removes all but a couple inches then second pass use front blade to push the rest to the side.
/ Snow Removal Frustration #58
Yeah, I know. The problem is that we really only get this much snow every 5 years. So my money would be better spent just hiring someone to clear the drive when it gets too bad. Of course I am too stubborn to call anyone so I go battle the snow and ice. I bought a heavy blade with offset LP RB3784 (on order) thinking it will work and will be generally useful all year. I am also debating ordering chains for the new tractor. Right now it does OK and when I get the tires filled it will be another 800# heavier. Again how much do you spend for something that doesn't happen every year?
/ Snow Removal Frustration #59
Chains make a significant improvement in traction. I use rear chains all Winter and also front chains for snow on top of ice conditions.
/ Snow Removal Frustration #60
I'll explain my frustration and listen to your all's expert advice! B2920 with FEL and R4 tires purchased spring 2010. Tires are not loaded and I don't have chains. I've got a 4' king cutter (i think that's the brand) blade on the 3pt, blade turned "backwards" with a 3" ABS pipe installed on the blade to minimize gravel displacement. Gravel driveway, 500' long. I've removed several 2 and 3 inch snows over the time I've owned the tractor without much trouble. I use a combo of running the blade down the drive (set at the middle angle) and then cleaning the piles with the FEL. However, in the last 2 weeks we have had two 10 inch snows about a week apart. Trying to move this much snow took me to near the limit for this tractor. The first snow was pretty dry and I was able to move it OK but my blade isn't heavy enough so I never got clear down to the bottom of the snow, even without the ABS pipe installed. Would adding weight to the blade help with this? Of course if I add weight I'll dig more snow and come up against the most significant problem which is lack of traction. The second snow was so wet that the blade would just pull a few feet of snow before I broke traction. So I tried using the bucket to "skim" the snow and I also quickly lost traction after traveling just a few feet. I am open to loading the tires and/or adding chains but I wanted input from you all as to how much these will really help me. And yes, I know some will say "buy a bigger tractor" but that is not an option due to 1: finances, and 2: these big snows have been relatively rare recently so I'd like to adapt the equipment that I have as much as possible. Well, enough rambling for now, lay it on me!
This counter weight has served me well.
Gasoline Concrete Mixer 8.0 Honda (A62679)
Gasoline Concrete...
2005 International 5900i T/A Gardner Denver Kill Truck (A64194)
2005 International...
30x57 Welding Table (A65640)
30x57 Welding...
2016 Ford F-550 Flatbed Truck, VIN # 1FD0W5HT7GEC46417 (A65563)
2016 Ford F-550...
New 20Ton Air/Hydraulic Bottle Jack (A65579)
New 20Ton...
Willmar Wrangler 4500 Loader (A66285)
Willmar Wrangler...
