Snow Removal Frustration
/ Snow Removal Frustration #21
Weight helps a little, chains a lot, but rear blades aren't great for heavy snow. I've got by with my rear blade for all but 2 of our snowfalls but for them the driveway was just getting too narrow so it became loader time. My banks are now 4 feet high and 8 feet wide. This year a blower would have paid off. My tractor was equipped with mid-mounted PTO and front blower on the lot but I made them take it off and replace with the loader. Big mistake . Should have kept both.
/ Snow Removal Frustration #22
V-Bar Duo chains on gravel made my little B7610 go from a mouse to a monster in snow. But put something down on the garage floor, because the chains ate the concrete pad. The V-bars are too aggressive on paved surfaces, so think twice before you go doing favors clearing your neighbor's paved drive.
Loading tires is cool, but it can't be undone and redone easily. I don't want loaded tires when I'm mowing a couple days after rain. I'd dig in too much. Chains go on and off pretty fast after the first couple of times and you get it figured out.
With a rear blade I've had a lot better luck running forwards dragging the blade behind me for clearing snow. Running in reverse makes the blade want to dig in and I always ended up giving the driveway a washboard texture. I have used this to my advantage a few times on ice by getting the blade to chatter, chopping up the ice a bit and giving it some tooth. I never put a pipe on the bottom of the blade so I don't know if it makes things any easier. I always used top link length to control blade cutting angle, and sometimes ran the blade the wrong way so it would ride up a bit and smooth things over.
I agree that having a blade that covers your wheel width is pretty important. Maybe a wider blade is in order. Maybe you can narrow the rears a bit on the axle, not sure about your machine. Maybe a bit of both.
Come spring there will be some repairs and crowning to do, but that's the beauty of gravel. You can mess it up and put it back with the same implements. Just don't widen the gravel every time you plow otherwise you end up with something wide enough to land a Cessna on after a few years.
It's not the arrow, it's the Indian. Yes the right tool makes the job go better, but no matter what you use, it takes time to get the feel. Practice makes progress.
I had my drive paved and its cool, but I have to admit that I miss grooming the gravel. We had a couple over for dinner one evening, and I had just finished crowning and York raking the drive. When our guests arrived the gentleman mentioned how nice the driveway looked. The way I felt hearing that must be darn close to how a women feels when her friend notices her new dress and hairdo.
/ Snow Removal Frustration #23
In just one winter I have gone from the bucket and box blade to a front mounted used snowplow blade. With just two paying customers the blade has already paid for itself. This set up works great for pushing back the banks when they get too high as I can just hold up the loader arms another foot and put the right side tires right into the bank while pushing over the top two thirds of the bank five feet or so. I do have to remember where the drop offs are and come back into hard ground to avoid getting sucked down but I don't have many of those and only wing back in daylight between storms.
So this is my set up. Loaded tires, ice chains rear, front power angle eight foot plow with wings. regular 73" bucket for loading out and pileing snow between storms.
/ Snow Removal Frustration #24
You may not want to hear this, but it's kinda the nature of the beast, using a rear blade. I live in KC. I got 14" on the first storm and 8" on the next. I have an L5740 with 1298# of RimGuard ballast, and grooved R4s. With my spreader on the back with 800# of ice melt loaded in it, I can shove my 9' plow almost through anything. So after I was done with all my accounts, I decided to clear the sidewalks here in town, so the kids could walk to school. So I put a little 72" blade on the 3pt and gave it the max angle so I wouldn't scrape up too much grass on either side of the sidewalk. Using the 9' plow to knock off the top 12" or so, I still ran out of traction quite often as the rear blade filled up. As soon as I lift the blade, I'm off and running.
/ Snow Removal Frustration #25
I've used this set up on 3 tractors now, a JD955 (1700# + FEL, non loaded tires), Kioti CK30 (3200# + FEL + Loaded tires) and my current Kioti DK45 (4100# + FEL + Loaded tires). The only time I've ever struggled is when the machine doesn't have enough clearance and tries to push snow with the front axle or my pile of snow becomes really, really big. I've always found that using a rear blade backwards is next to useless. Try turning it around and pulling it, I'm sure you'll have a lot more success. This will also allow you to scrape it down by angling the blade forward. Chains will do more than weight, but I'd load those tires regardless, it will be a whole different tractor after you do. Regardless, I don't think you'll be able to push that much snow backwards, but pulling it shouldn't be an issue.
/ Snow Removal Frustration #26
HC, it's a whole different story when the snow has nowhere to go, but if the OP starts pulling instead of trying to push and still has room for a furrow, he should be fine. With 12" of snow, he'll probably need to start by making a few relief cuts, then the rest will be easy.
/ Snow Removal Frustration #27
When the snow is too heavy for me rear blade I just use my front end loader. Yes its slow, but I do my best to think of it as just more tractor time - playing in the snow. Start taking bites that you can handle and it will get done eventually.
This was my approach for our last storm. I haven't gotten to use my tractor much for snow clearing since it doesn't live where I do.
But after 7" of wet sloppy snow last week, I set off with the rear 6-ft blade to clear the driveway. Boy was I dissapointed when it just lifted up and over the compressed snow slop! So I ended up with a procedure using BOTH the rear blade and front bucket simultaneously. You don't have to pick up everything in the front bucket, but if you keep it low and skim/scoop/push at least half the snow, you can get pretty far before you need to stop and dump the bucket. Meanwhile the rear blade will have had no problem cleaning up the path behind you, clearing much less snow than you otherwise would have had to ask it to do.
Wow, 3 pages of replies. Thanks for the great input folks. Since traction is the root cause of my problems I believe that I will start budgeting and planning for a set of chains. Based on your replies that seems the most likely way to improve my performance in the snow. Now, regarding chains, are there different styles and designs? Lightnsound mentioned the "V-Bar Duo" chains being pretty aggressive. Is that a style or a brand (I'll google it)? I wonder how much a set of chains will break the bank. . . photo2.JPG
/ Snow Removal Frustration #29
In the order of cost effectiveness. 1. rear chains, 2. front chains if you have clearance on steering arms and loader parts, 3, load rear tires, 4, bigger rear blade with offset, 5, front plow 6.5 foot, use dump function for power angle. 6, add third function for power angle to allow front plow to float 7, rear 3PH snow blower. 8, six drunk relatives with snow shovels.
Skip the shovels...just use 'em for ballast!
/ Snow Removal Frustration #30
Focus on the good little things that are continually present in my life.....
Like blowing snow ! :)
When I bought my tractor new because I had turf tires installed I asked the service dept. about getting chains. he said.... 'You'll never need them !'
/ Snow Removal Frustration #31
I bought mine from tirechains.com, and was pleased with their customer service. The Duo-Grip indicates the pattern of the cross chains. Duo Grip has a lot of chain and it stays up on top of the tire treads without falling between the bars.
V-bar chains have little V shaped pieces welded on the cross chains. They dig in hard like sharp cleats. You can get the duo-grip chains, and other designs, with or without the v-bars.
Just go on their website, and see what designs they have available in your tire size.
Another option I have messed with is studding the tires with screw-in studs. I bought some on eBay and tried them on my front tires. They work well, but don't go on and off like chains and they ate the garage floor more than I liked.
/ Snow Removal Frustration #32
Here's my new-to-me plow that I mounted on my FEL for plowing snow on my B2400. I've only used it once in a decent 6 inch snow. Overall it worked great. I did have some steering issues. Going around turns the front tires would lose their grip. I bought some chains for the front which, hopefully, will alleviate this problem. Chains on the rear helped tremendously.
/ Snow Removal Frustration #33
Wow, 3 pages of replies. Thanks for the great input folks. Since traction is the root cause of my problems I believe that I will start budgeting and planning for a set of chains. Based on your replies that seems the most likely way to improve my performance in the snow. Now, regarding chains, are there different styles and designs? Lightnsound mentioned the "V-Bar Duo" chains being pretty aggressive. Is that a style or a brand (I'll google it)? I wonder how much a set of chains will break the bank. . .View attachment 306854
Of course there are different designs and applications. The most aggressive chains work great but if the operator insists on spinning he can tear up a paved drive ,concrete or asphalt, pretty quick. These work great but cost real money new.
ice chains
/ Snow Removal Frustration #34
load the tires and add chains
/ Snow Removal Frustration #35
ice chains
If you are concerned about tearing up paved or concrete try the rubber chains. I picked them up this year and had no problem unless ice under the snow on my hill but nothing will help on ice.
Sent from my iPad using TractorByNet
/ Snow Removal Frustration #36
Loaded tires, double link cross studded ice chains, rear blower, heated cab and front plow.
Nothing stops me! (except wet sticky snow as the chute occasionally clogs.)
And my radio entertains me.
The double cross chains actually rarely spin as they grip so well, the only time I spin is on non compacted snow base, like off side of the drive when I decide to push back the snow banks.
/ Snow Removal Frustration #37
My wife & I have some property in Northern Wisconsin (lots of snow). Right now I don't have to worry about plowing, but eventually we will retire there. My plan is to have a rear 3PT snowblower, so I don't have to worry about pushing anything. That will allow me to keep the FEL on. I can see where a front-mount snowblower would be nicer, but cost and the ease of mounting the rear 3PH version seems preferable to me.
/ Snow Removal Frustration #38
When you spend a couple of long nights pretending you are an owl you just might change your mind. Keep your options open.
/ Snow Removal Frustration #39
Coldstream,
I would add weight to your scraper blade. You should be able to come up with some way to do it. Maybe dumb bell weights mounted on a pin welded to the center of your pivot point on your blade. Weight will make a big difference when trying to move snow. I personally would never load the tires some times you need to make the machine as light as possible. Once loaded your stuck with them. My driveway is 1200 feet long, I use the loader for my snow removal not the best but its what i have. I made a 500lb ballast block for the 3pt and it turned the tractor into a tank. The last blizzard we just had was 33" inches of snow and thats without the snow drifts. Needless to say it took me 8 hrs to clear all the snow off 1200 ft plus the house area. Sometimes you just need to make due with what you have. Like you said you don't get that many big storms so i would not load the tires, i would find a away to add weight to the blade. Also add some weight to the loader bucket when scraping, Grab a nice scoop of snow and see if it helps.
Good Luck
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
1995 Freightliner FL70 Fuel Truck (A62613)
1995 Freightliner...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2020 Hyundai Sonata Sedan. (A61574)
2020 Hyundai...
