Bullet trap build
   / Bullet trap build #1
jwmorris
The target thread reminded me of the back yard bullet trap I built. It's only 3/8" thick mild steel so I only use .22's, pistols and pistol caliber carbines with it but it's better than nothing. Its 8' tall and just over 16 feet wide, weighs around 4000 lbs.
   / Bullet trap build #2
Extremely cool! I'm guessing you didn't pay full retail for the metal. LOL
   / Bullet trap build #3
Now that there is a trap! What's the story with your torch set up? I've never seen that before.
   / Bullet trap build #4
It's a straight line cutter. It is motorized and follows the "track" We had one at a shop I worked in.
   / Bullet trap build #5
600 rider:
nice, lots of STEEL in that bugger, we built our own track torch looked almost identical to yours. It had the oxy torch on it and we modified to hold the plasma too. It was a bit slow for the plasma on light stuff so we mostly just used the track as a side guide. but we cut some thicker stuff with it at it's high speed setting to cut which was useable but not best.
those are some BIG sheets BTW must have gotten them discount from work?
I've got First Energy high tension lines on my place and they are taking out about a dozen trees next week as they are getting close to the lines. Most of them are POPPLE trees (kind of a type of mixed hybrid popular) that are not really even good for fire place as they stink when burning. Those are going to be cut into ~8' lengths and I'm building a sand bank behind them & burying them about 1/3 and sand in behind them. they are going to be uphill from my target so top will be about 6 or 7 feet above the target and 8~10 feet back. That is going to be 100% tractor project & maybe a shovel.? :eek:)
Mark
   / Bullet trap build #6
When your title said "bullet trap" I figured something to use inside a shop or basement, like two or 3ft wide. That sucker is HUGE!
   / Bullet trap build #7
That's a spray and pray bullet trap! Lol
   / Bullet trap build #8
Ahhhh, would not a Berm of equal height and width not be less expensive,,, and stop all bullets of any size? Not that your Catcher is not cool. But a picture of efficiency,,,. Pretty impressive non the less though.
   / Bullet trap build #9
It makes it easy to collect the lead.
   / Bullet trap build #11
Are you still allowed to use lead? LOL
   / Bullet trap build
I picked the steel up at a scrap yard that was advertising steel plate on Craigslist. The sheet I picked up started out as an 8.5'X32 and cost under $1000.
The track torch is a really old one I picked up on eBay for cheap, it does the big stuff that won't fit on my CNC plasma better than the Handyauto torches.
Yes I cast my own bullets. No one seems to be having a problem with the gun related threads so I'll start one on my casting machine.
   / Bullet trap build #13
I like your build on the satalite stand:thumbsup:
Nice trap!, would it stop a 223?
   / Bullet trap build
Tested some drop with .223. Stops it but with dents, so I don't use it for rifle calibers.
The satellite is mounted on the wheel with 3 marks 120 degrees apart that line up with marks on a pad at the farm so I can move it and get a signal without having to adjust it at the farm.
   / Bullet trap build #15
look up radiograph...there quite common in fabrication shops tracks are in sections u just use as many sections as you require..uses 110 ac for power to crawl along the track, theres a speed adjust depending on what your cutting..the "turtle" pulls the oxy/acet hoses with it down the track
   / Bullet trap build
Yes, it's just an old track torch. Pretty heavy but works a little better than a HandyAuto with cuts that long.
   / Bullet trap build
Here is a video of my buddy using it, you have to click on the photo to play it.
You can also see the auto reset steel targets working.
   / Bullet trap build #18
I have one that almost looks the same, very old, I have repaced 3 cords on it that I can remember.
I have cut 8" plate with my track cutter.
2020 DRAGON ESP...
2405 (A60432)
2405 (A60432)
Enmark Z Spray (A53316)
Enmark Z Spray...
2017 Ford Fusion Sedan (A59231)
2017 Ford Fusion...
207280 (A52708)
207280 (A52708)
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
