Shielding gases
/ Shielding gases #1
Bday
Lucerne, IN
53' Allis WD, 54' Allis WD 45, 52' allis CA, Farmall 560, 656 , 47' Deere model A , 38' Deere model A
What gas do you guy's like for steel. I like the bead appearance you get with co2 , but they mention spatter as an issue. We used co2 in school, and I can't recall spatter as an issue. Since I have been in the industry, I have always used 75/25. I use this at my shop also. Thinking about getting a bottle of co2. I have read about different mixes out there. Anyone use something different. Thanks!
/ Shielding gases #2
We use CO2, cheap and readily available. Usually if I have spatter issues its because the metal isnt clean or my settings are off, dont have too much issue when all is right it seems. If anything a quick cleanup with a grinder takes it off easily and I usually pass the grinder around the workpiece anyway to deburr edges and such.
/ Shielding gases #3
I used co2 on the things that looks did not matter as much, but used mix on things that had to look good. This is for mig only, I am told co2 wont work on tig as it will ruin the tungston.
/ Shielding gases #4
I use CO2 because it's a lot less expensive and at my skill level I don't really notice much difference in appearance.
/ Shielding gases #5
Stargon gets better penetration than argonco2
/ Shielding gases #6
I always use 75/25 gas with my MM210.
/ Shielding gases #7
If you really want to turbo charge your welds, go with some C10. Or 98% argon, and 2% oxygen.
This weld was made with C10.
/ Shielding gases #8
What size wire and input power are you using? (110 or 220?)
I personally use CO2 but only do occasional repairs/fabrication.
A med size bottle lasts me years.
SA- that weld was done on spray transfer?
/ Shielding gases
Hey shield arc I like the spray transfer. I also like to see some character to the bead. When I was in school they taught us less heat and more technique. I personally like the mig welds that take on a Tig welded appearance. Man we could lay some pretty welds with the 3 phase units at work.
2016 Ford F-150 Pickup Truck, VIN # 1FTMF1C85GKE26496 (A61165)
2016 Ford F-150...
2008 TRANSCRAFT 48X102 STEEL FLATBED (A58214)
2008 TRANSCRAFT...
2013 MACK CHU (PINNACLE) (A60736)
2013 MACK CHU...
2012 JACK COUNTY 130 BBL STEEL (A58214)
2012 JACK COUNTY...
1770 (A58375)
1770 (A58375)
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
