Snow Equipment Owning/Operating Bucket vs Snow Pusher
/ Bucket vs Snow Pusher #1
massey184ferguson
Atlantic Canada
Massey Ferguson 184-4
What is better, a bucket or snow pusher? I've seen some pretty nice pushers on here, might consider making one myself.
/ Bucket vs Snow Pusher #2
As far as I can see the only use for a pusher would be in a parking lot.With a lite materials bucket you can pick it up and move.Standard duty buckets,for the most part don't have enough volume.They are better than a shovel.
/ Bucket vs Snow Pusher #3
I'd pick snow pusher over bucket..for I have place to stack snow no need to bucket away,also less passes w/pusher compare to bucket.
/ Bucket vs Snow Pusher #4
I like my bucket. When we get big storms I have to be able to lift the snow up and dump it on top of some areas that can't be pushed.
IE: In front of my driveway I can only push across the street so long until it's 6' tall, and then I have to lift it and dump it on the opposite (my side) which has a 3-4' dirt wall depending where I dump.
The bucket also makes it fun for snow cave building and such :D
If I had a place to push, and was on flat ground I'd go pusher probably... down the road when we pave I plan to go with a blower! Now it's out of the way for good :)
/ Bucket vs Snow Pusher #5
i have both snowpusher goes on and off within a minute.SNOWPUSHER HANDS DOWN.yOUD BE SURPRISED TO SEE HOW MUCH HIGHER YOU CAN STACK IT WITH A PUSHER. With the side wings you dont start loosing it off the sides ,and can even keep it contained going around a corner.
ALAN
/ Bucket vs Snow Pusher #6
Can you lift it with a pusher or just push it so it builds up? I didn't think you could lift with a pusher ???
/ Bucket vs Snow Pusher #7
allot of times when the snow isn't that deep I just push it with the blower attachment. It acts as a box blade and will pile the snow up.
/ Bucket vs Snow Pusher #8
yes ,you can,mine mounts on the front of my bucket ,i can get the bankings pushed up 3 to 4 ft higher with it on
/ Bucket vs Snow Pusher #9
I can move snow a lot faster with a blade then I can with the bucket. The bucket on my tractor is only 5' wide where the dozer blade is 7' wide. I dont need to pile snow up anywhere otherwise a bucket might be better for that. Just my .02 cents.
Steve
/ Bucket vs Snow Pusher #10
Reversible pusher, also called a push-pull blade, is by far my favorite snow-clearing front implement. Like mentioned above when used properly you can pile up a lot of snow with it and in pull mode you can reach near buildings and other areas that would otherwise require a walk-behind blower or a shovel to clear properly. One caveat though, in order to maximize efficiency a rear blower must be used in conjunction with a push-pull.
/ Bucket vs Snow Pusher #11
Push-pulls can be turned into scoops but that requires an independent hydraulic pivot on the FEL to allow for 180-degree on-axis rotation. It's quite expensive and mostly used when switching implements on-the-fly is not practical, like when you're on a snow run miles away from base.
/ Bucket vs Snow Pusher #12
I do that sometimes as well, but I'm careful to clean the blower afterwards in case of a sudden hard-freeze. Impeller encased in hard ice is bad news for shear bolts. Once it even stalled my 105 hp tractor when I engaged the PTO 'cause none of the shear pins gave, for some reason. Only damage caused was a panicky owner.
/ Bucket vs Snow Pusher #13
Snow pusher hands down. The only thing a pusher does not do better than a bucket is lift up and carry snow. CJ
/ Bucket vs Snow Pusher #14
I'm fortunate to be able to put mine in a heated garage when done
/ Bucket vs Snow Pusher #15
My JD 4720 fits in the garage (2 inch clearance above the beacon on the cab after I modded the door) but my JD 5105M does not :(
/ Bucket vs Snow Pusher #16
The way to use a pusher to stack snow is to push back the top of the pile each time you put snow at the base.You can dispose of a lot of snow this way
/ Bucket vs Snow Pusher #17
I had both, since I got the plow I sold the pusher. I have a plow that mounts in place of the bucket and angles with aux hyd. I have a long drive and with the pusher I would get part way down and run out of steam, with the plow I can angle and go all the way. I can stack just as high with the plow as the pusher and clean up just as fast. Real advantage is being able to angle for the long straight sections. When I did parking lots pusher was much better for carrying snow a long ways through the lanes. Plow can't carry without pushing sideways. I hardly ever use the bucket unless I need to scrape a small section for whatever reason.
/ Bucket vs Snow Pusher #18
Plows and pushers aren't meant for the same purpose. Pushers are usually part of a pusher/blower tandem mounted on the same tractor or loader. Pushers -especially reversible ones- are mostly used in commercial snow clearing when one has to quickly clear a large number of relatively short drives or pile up snow for hauling away, this mainly applies to parking lots. The advantage pushers have over plows is that when used properly they leave no snow in their wake and you can put it exactly where you want it. The dawbacks: requires more horsepower and heavier equipment, it's not meant for garden tractors or pickup trucks; cannot be used to sweep snow aside so distance range is very short and limited by horsepower and terrain conditions. If you're not into commercial snow removal and have a long drive with enough room to sweep snow aside then you're much better off with a plow.
Some plows can be transformed into pushers via hinged hydraulic or electric "wings" that can be lowered on each side of the plow, it's very expensive though and not as sturdy as a standard pusher.
2006 Toro SandPro 2020 Bunker Rake (A61572)
2006 Toro SandPro...
Chevrolet 2500 Flat bed (A63118)
Chevrolet 2500...
2022 MACK ANTHEM AN64T 6X4 T/A  SLEEPER TRUCK TRACTOR (A59910)
2022 MACK ANTHEM...
2005 FORD E-350 S/A MOBILE CONCEPTS CUSTOM CONVERSION (A59910)
2005 FORD E-350...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
John Deere TX Gator (A60462)
John Deere TX...
