Snow Equipment Owning/Operating Bucket vs Snow Pusher
   / Bucket vs Snow Pusher #1
massey184ferguson
Atlantic Canada
Massey Ferguson 184-4
What is better, a bucket or snow pusher? I've seen some pretty nice pushers on here, might consider making one myself.
   / Bucket vs Snow Pusher #2
As far as I can see the only use for a pusher would be in a parking lot.With a lite materials bucket you can pick it up and move.Standard duty buckets,for the most part don't have enough volume.They are better than a shovel.
   / Bucket vs Snow Pusher #3
I'd pick snow pusher over bucket..for I have place to stack snow no need to bucket away,also less passes w/pusher compare to bucket.
   / Bucket vs Snow Pusher #4
I like my bucket. When we get big storms I have to be able to lift the snow up and dump it on top of some areas that can't be pushed.
IE: In front of my driveway I can only push across the street so long until it's 6' tall, and then I have to lift it and dump it on the opposite (my side) which has a 3-4' dirt wall depending where I dump.
The bucket also makes it fun for snow cave building and such :D
If I had a place to push, and was on flat ground I'd go pusher probably... down the road when we pave I plan to go with a blower! Now it's out of the way for good :)
   / Bucket vs Snow Pusher #5
i have both snowpusher goes on and off within a minute.SNOWPUSHER HANDS DOWN.yOUD BE SURPRISED TO SEE HOW MUCH HIGHER YOU CAN STACK IT WITH A PUSHER. With the side wings you dont start loosing it off the sides ,and can even keep it contained going around a corner.
ALAN
   / Bucket vs Snow Pusher #6
Can you lift it with a pusher or just push it so it builds up? I didn't think you could lift with a pusher ???
   / Bucket vs Snow Pusher #7
allot of times when the snow isn't that deep I just push it with the blower attachment. It acts as a box blade and will pile the snow up.
   / Bucket vs Snow Pusher #8
yes ,you can,mine mounts on the front of my bucket ,i can get the bankings pushed up 3 to 4 ft higher with it on
   / Bucket vs Snow Pusher #9
I can move snow a lot faster with a blade then I can with the bucket. The bucket on my tractor is only 5' wide where the dozer blade is 7' wide. I dont need to pile snow up anywhere otherwise a bucket might be better for that. Just my .02 cents.
Steve
   / Bucket vs Snow Pusher #10
Reversible pusher, also called a push-pull blade, is by far my favorite snow-clearing front implement. Like mentioned above when used properly you can pile up a lot of snow with it and in pull mode you can reach near buildings and other areas that would otherwise require a walk-behind blower or a shovel to clear properly. One caveat though, in order to maximize efficiency a rear blower must be used in conjunction with a push-pull.
2018 UTILITY VS2RA 53FT REEFER TRAILER (A56129)
2018 UTILITY VS2RA...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
CATERPILLAR 302.7CR EXCAVATOR (A52707)
CATERPILLAR...
Volvo BL70B (A53317)
CASE CX57C EXCAVATOR (A52707)
CASE CX57C...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A55315)
2023 Kubota L3560...
