Bending 1/2"x3" to 45-90 degrees
/ Bending 1/2"x3" to 45-90 degrees #1
Buty
Canton, GA
Kubota L3200
I want to make bends with a small DIY press brake with bottle jack and would like to know how many tons it would require to bend 1/2" plate. My guess is that I'd never exceed about 3" wide. Thanks.
/ Bending 1/2"x3" to 45-90 degrees #3
Is the press up to the task? I have a 12 ton air over hydraulic on my homemade press and just re-designed the die. I think it matters more "how" the die and press are built as opposed to how much force it will take. I think with the proper die 1/2" by 3" could be doable with a 12 ton given the right circumstances. I have some 3/8 by 6 I want to try, just haven't had the time.
Thanks guys. Looks like a 20 ton would be more than enough for what I need to bend. I will just be making some brackets for 3 pt hitch like in the photo below. 015.jpg
/ Bending 1/2"x3" to 45-90 degrees #5
/ Bending 1/2"x3" to 45-90 degrees #6
i made my log splitter into a press to bend 1/2x6 inch to make the bearing support for the disc harrow i made. its a 27 ton
1/2" is what I have on most of me implements so that's what I was going by. Maybe 3/8" is plenty though.
/ Bending 1/2"x3" to 45-90 degrees #9
Make a bottom die that is 8 times wider than the thickness and you wont have a problem. 8x.5=4" across the top. you could probably do it with a 3" die as you wont be bending 90* just 45* or so. On a side note hot rolled steel will bend easier than cold rolled!
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A61307)
2023 Kubota...
Bobcat A770 (A60462)
2012 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A60736)
2012 HEIL TRAILER...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
24017 (A56859)
24017 (A56859)
