Picking a trailer for new JD 5083E
/ Picking a trailer for new JD 5083E #1
bglz42
DIckinson, Texas!
2013 John Deere 5083E
I'm looking for a trailer for my 5083E with 553 loader. I will occasionally haul with a mower attached so I'm looking at 24' gooseneck minimum. What are the pros/cons of lowboy vs deck-over?
I figure the deck-over might be advantageous if I were hauling something wide like a 7' to 8' mower?
/ Picking a trailer for new JD 5083E #2
DECK OVER, and absolutely a GN, My tractor (5083E) with the 563NSL, loaded tires and base weight of the tractor (granted im usually hauling something else) pretty much maxes out my GN, I pretty much sold my 1 ton Cummins because it was hairy stopping it in a hurry. I would reccomend a Low Profile Deckover, some manufacturer's make them some dont. Moritz does and its a full 3" lower to the ground. (not advertising them, just what i personally own.) If you start trying to get the correct tongue weight on your truck, your going to run out of deck in a hurry, Hence why I usually ended up with a very pin heavy trailer and hence why I upgraded to a bigger truck. Hope that helps!
btw, IIRC loader figures in around 1500-1700lbs, and I believe beet juice adds almost 800 (780 if you wanna be technical, 16.9-30) per rear tire. so we are easily talking 7435(per deere)base tractor plus extras, which rounds out to about 11k, Any additional attachments are extra of course. I usually happen to have a 2k counter weight with me. So I'm right at my trailer max.
Thanks, RedNeckRacin! That was exactly the type of info I was searching for!
/ Picking a trailer for new JD 5083E #4
I am very interested in this topic also. Anyone have any pics of hauling around there 5083e? or 93 or 101 for that matter, they are exactly the same size if i recall.
I am leaning toward a tandem gooseneck 20 plus 5 dovetail...
/ Picking a trailer for new JD 5083E #6
I got a 20 plus 4 dovetail gooseneck that I haul my 5085M w/ H260 loader around on. This setup is a bit heavier than a 5083E w/ 553 loader, but size is about the same I think.
It fits fine without a rear implement, but with something on the back, the bucket needs to go up on the gooseneck itself for sure.
Here is just the tractor on the trailer:
I have hauled this combo before with no issues (sorry, no pic of it loaded on the trailer), although it is real right getting the ramps up. A 5' dovetail or another few feet of deck length would have been nice, but I'm having a hard enough time turning around in tight places as it is with my crew cab long bed truck, so I'm happy with what I got.
Thanks SO much for the pics! Thats what I needed to see...
/ Picking a trailer for new JD 5083E #8
My 1 ton SRW cummins and the brand new 5083E. 563NSL, loaded wheels, and a little bit of a pucker factor! I think a dually would help immensely with the weight.
/ Picking a trailer for new JD 5083E #9
Thanks for the pics!
/ Picking a trailer for new JD 5083E #11
Looks like some pretty heavy loads on tandem single axles. This may or may not be the place to ask this question, but when evaluating load capacity of a trailer is it safe to take the total axle capacity and subtract the trailer weight to determine how much weight can be put on the trailer? For example, I have a 22' 12K bumper pull trailer that is 82" wide. I estimate the trailer to weigh 2000 lbs. So the max weight the trailer can carry would be 12,000 lbs axle rating(2 @ 6,000 lbs each) less the 2,000 lbs trailer equal 10, 000 lbs possible pay load. I realize tongue weight factors in, but it is difficult to calculate. Seem about right?
/ Picking a trailer for new JD 5083E #12
Yes, kind of. You really need to weigh it. Most 12k ttrailers are closer to 3k empty.
Chris
/ Picking a trailer for new JD 5083E #13
Chris
So if the trailer weighed 3k, the net capacity would be 9k? And the capacity could technically be increased by the amount of tongue weight too?
/ Picking a trailer for new JD 5083E #14
That is my understanding. My trailer weigh 4800 lbs empty and has a 7ton or 14k capacity. I figured 25% can be tongue weight, so 14k + 25% = 17.5k. If I then subtract the trailer weight of 4.8k, it means I can haul 12.7k on it.
I'm currently hauling lumber to the mill with it, and have had loads over 14k. Here's a 14.6k load:
So my gross weight going down the road was 27.6k, which is probably borderline for my truck. Fortunately, the mill is only 10 miles away.
I have also hauled a 6405 with this trailer.
And a boom lift:
Of all those loads, I would say the boom lift was probably the heaviest, and I hauled it about 50 miles on the interstate, crossing the Blue Ridge Mountains. Neither truck nor trailer every felt unstable or unsafe at any point.
/ Picking a trailer for new JD 5083E #15
And a boom lift:
Great pictures! I have a very similiar gooseneck just a different brand, mine scales out about 5100 lbs with chains, binders, and a couple 6x6 blocks. I dont think i could go back to a bumper pull trailer now. Here are a few pictures of some various loads.
Picking up my Ford 961
The Jeep loaded to go to camp
Delivering a buddies truck that he just bought
Twenty foot sea van, at this point it was almost unloaded, probably only 2-3,000 lbs left in it.
/ Picking a trailer for new JD 5083E #16
Chris
I have a 20' 7k trailer that scaled 2600 just on the axles, not sure what the tongue weight was, so yeah I would hope a 12k trailer would be more than 2,000 empty.
/ Picking a trailer for new JD 5083E #17
26,000 lbs and over should imply a CDL driver's license...
/ Picking a trailer for new JD 5083E #20
i haul my 7040sud fel loaded rear tires cast centers on my 10k 20 fot bumper pull trailer ii figure its 8-8.5k my trailers bout 1000ibs over
