Cutting crooked
/ Cutting crooked #1
bill54
perrysville in.
farmall m
I've got a Jonsered 630 super and it's a real screamer, but a problem has come up that has me puzzled . I can fix any saw but this one is cutting sideways in a half moon shape . My chain was wore out and my bar was slightly bowed so I bought a nae bar& chain combo . They're matched 58 x 3/8 pitch and it still cuts cockeyed . Could it be my rim sprocket ? I've never had this problem before but I'm at my wits end . Any help out there?
/ Cutting crooked #2
Dull chain.I've even had brand new chain cut crooked.Sharpen and try again.
/ Cutting crooked
I just can't believe it's that. I checked and it's razor sharp, however the depth gauges looked shiny so I checke them and theres plenty of clearance. All that I have'nt done is change the rim sprocket which
Checked that its razor sharp and plenty of clearance on the depth gauges. I'm going to change the sprocket tomorrow, but I don't know why that would matter.
/ Cutting crooked #4
I had that problem on one of my saws. I noticed when I put the bar on, there was a little collar on the studs holding the bar and cover on. I didn't have the bar sitting perfectly flat on the surface. It was cocked just a smidgen. I just had to make sure it was seated all the way.
/ Cutting crooked #5
When the chain is on, is there slop or wear that can cause it to angle on the bar one way or the other?
With the chain off, are both bar rails (above the slot) the same height if you put a straight edge perpendicularly across them. Although not with a new bar, I had them wear uneven, and this caused crooked cutting as the chain now sat tipped on them.
Also, are you double sure that both the bar and chain are .058"? And not a .050" chain in a .058 bar?
Or like Yellowhair said, dull or unevenly charpened chain.
/ Cutting crooked
Yeah , They're the same on top of that I've got a bar rail grinder and a Foley 108 chain grinder. I touched up the bar but it really din't need it since I just put it on. I do know that my sprocket is worn but, like i said I can't believe thats the problem .
/ Cutting crooked #7
Change the sprocket. When one changes the bar and chain, every second time, the sprocket should be changed too. This way one doesn't end up with this type of problem. I believe all Stihl chains come with instructions stating this. I was surprised when I read it- wasn't aware of the periodic changing of the sprockets before that.
Its the only thing you haven't done so far.
/ Cutting crooked #8
Wow, I haven't ever changed a sprocket and probably cut up a couple hundred chords. I thought it was just getting broke in :D
/ Cutting crooked #9
Bill, the advice of changing out the sprocket is valid. If you have a rim sprocket, there should be "wear" indicators on the sides. If these grooves are worn to their base, its time for a new sprocket. Your old curved bar could have warped your sprocket causing immediate damage to your new bar and chain. Another thing to check for that alot of people do not know about is proper oiling. Make sure all oiling holes line up and/or are not plugged as this would also make a chain cut in a curve. I agree with the poster who stated your bar may be seated incorrectly as another cause so check that.
Make sure all depth gages and rakers are of the same height even if its new. I have even seen factory (or whoever put together a chain) blunders of putting several cutters in a row facing the same direction. It will only take two of these to start a cut wandering. I once had a chain that had 4 cutters in a row facing the same direction.
/ Cutting crooked #10
'Broke' being the operative word:eek: Its a maintenance part like the bar and chain, even more so since it drives the chain through the bar, and if the bar is bent or pinched or not oiled properly- well you get the idea....
/ Cutting crooked
Thanx, I'll change it tomorrow. Yea, thats all I had'nt done but in all my years of cutting (40) I'd never came across that .
/ Cutting crooked #12
You're welcome! I'd never changed one either; then I bought a used 192T Stihl pro pruning saw, and had my Stihl dealer check it out - I was replacing some completely whipped parts, and asked about the sprocket condition and they confirmed it needed replacing. I wasn't quite sure looking at it, but they knew right away....Cheap insurance, and makes a BIG difference in performance.
Don't feel bad I've been cutting since I was 14. Now 60! Used to cut for a big Tree Co., and was climber too...never knew 'till last year :confused3: :pullinghair:
/ Cutting crooked #13
Most of the time a sprocket will not have much of an effect on cut wandering but in your case with using the saw with a slightly bowed bar could have worn the sprocket in such a way as to throw off the chains direction. If the sprocket replacement still doesn't fix it, put on a new chain (its always good to have a mess of chains anyway). If that doesn't fix it, check for bar fitment and oil hole lineup. Also, recheck bar sizing and gage which is stamped at the base of the bar and compare these figures to your original. I have caught several mistakes from the saw shops when handed over the "direct replacement" bar so I always confirm the sizing.
/ Cutting crooked #14
Mine was almosst cut in half before I noticed. Changing the sprocket is just anothe routine maintenance task. "Rim Sprockets" make the job simple and cheap. If the saw doesn't have one when I change I switch to a "rim".
Harry K
John Deere 4840 Tractor (A66285)
John Deere 4840...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2000 Ford F-750 Debris Truck, VIN # 3FEXF75H8YMA01188 (A65563)
2000 Ford F-750...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
