Loader stuck in air Deere 4610
/ Loader stuck in air Deere 4610
Thanks, Kenny. I did see that they all have same P/N and could see zero difference. In this case all they do is re-direct fluid from one direction to another. Thanks for easing my mind though. I was somewhat concerned based on other comments about moving them. - Hugs from Mariposa, Gateway to Yosemite!
/ Loader stuck in air Deere 4610 #22
Dumb Question....
Have you checked to see if your 3ph lever is in down or neutral position (not up).....on most tractors this will not allow the FEL to go down if the 3ph lever is in the "UP" position....:confused3:
Hello, I assume 3 ph is the three point hitch. It is working fine, and we have now figured out the problem, which was a weak spring in a spool valve. Working great for now. Thank you very much. Troy
/ Loader stuck in air Deere 4610 #24
Dumb Question....
John Deere's do not have this "problem" that is very common on the Kubota machines.
SKIDDED PLAIN/WASTE WATER TANK (A60736)
SKIDDED...
2010 Ford F-150 Crew Cab Pickup Truck (A59230)
2010 Ford F-150...
2003 Coachmen Catalina Sport 220RK Class C Motorhome (A59231)
2003 Coachmen...
Kubota L4701 (A53317)
Kubota M5-111 (A53317)
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
