Loader stuck in air Deere 4610
/ Loader stuck in air Deere 4610
Thanks, Kenny. I did see that they all have same P/N and could see zero difference. In this case all they do is re-direct fluid from one direction to another. Thanks for easing my mind though. I was somewhat concerned based on other comments about moving them. - Hugs from Mariposa, Gateway to Yosemite!
/ Loader stuck in air Deere 4610 #22
Dumb Question....
Have you checked to see if your 3ph lever is in down or neutral position (not up).....on most tractors this will not allow the FEL to go down if the 3ph lever is in the "UP" position....:confused3:
Hello, I assume 3 ph is the three point hitch. It is working fine, and we have now figured out the problem, which was a weak spring in a spool valve. Working great for now. Thank you very much. Troy
/ Loader stuck in air Deere 4610 #24
Dumb Question....
John Deere's do not have this "problem" that is very common on the Kubota machines.
*BILL OF SALE* 2004 PORSCHE CAYENNE TURBO (A60430)
*BILL OF SALE*...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere Gator (A53317)
John Deere Gator...
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59905)
2016 FREIGHTLINER...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
