Loader stuck in air Deere 4610
   / Loader stuck in air Deere 4610
Thanks, Kenny. I did see that they all have same P/N and could see zero difference. In this case all they do is re-direct fluid from one direction to another. Thanks for easing my mind though. I was somewhat concerned based on other comments about moving them. - Hugs from Mariposa, Gateway to Yosemite!
   / Loader stuck in air Deere 4610 #22
Dumb Question....
Have you checked to see if your 3ph lever is in down or neutral position (not up).....on most tractors this will not allow the FEL to go down if the 3ph lever is in the "UP" position....:confused3:
Hello, I assume 3 ph is the three point hitch. It is working fine, and we have now figured out the problem, which was a weak spring in a spool valve. Working great for now. Thank you very much. Troy
   / Loader stuck in air Deere 4610 #24
Dumb Question....
John Deere's do not have this "problem" that is very common on the Kubota machines.
   / Loader stuck in air Deere 4610 #25
Thanx Kenny......I've seen this on Fords and others too
2015 VERMEER PD10 PILE DRIVER (A60429)
2015 VERMEER PD10...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
2016 CATERPILLAR D5K2 XL CRAWLER DOZER (A60429)
2016 CATERPILLAR...
2007 Nissan Frontier SE Crew Cab Pickup Truck (A59230)
2007 Nissan...
2015 Nissan Altima SV Sedan (A59231)
2015 Nissan Altima...
2019 FORD F-150 XLT CREW CAB TRUCK (A59823)
2019 FORD F-150...
