Loader stuck in air Deere 4610
   / Loader stuck in air Deere 4610
Thanks, Kenny. I did see that they all have same P/N and could see zero difference. In this case all they do is re-direct fluid from one direction to another. Thanks for easing my mind though. I was somewhat concerned based on other comments about moving them. - Hugs from Mariposa, Gateway to Yosemite!
   / Loader stuck in air Deere 4610 #22
Dumb Question....
Have you checked to see if your 3ph lever is in down or neutral position (not up).....on most tractors this will not allow the FEL to go down if the 3ph lever is in the "UP" position....:confused3:
Hello, I assume 3 ph is the three point hitch. It is working fine, and we have now figured out the problem, which was a weak spring in a spool valve. Working great for now. Thank you very much. Troy
   / Loader stuck in air Deere 4610 #24
Dumb Question....
John Deere's do not have this "problem" that is very common on the Kubota machines.
   / Loader stuck in air Deere 4610 #25
Thanx Kenny......I've seen this on Fords and others too
2023 LANDHONOR VPC-11-72W VIBRATORY PLATE COMPACTO (A51244)
2023 LANDHONOR...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
Killbros 250 bu Gravity Wagon (A50515)
Killbros 250 bu...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
UNUSED FUTURE SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE SKID...
(3) 8' High Pole Swinging Gates (A50515)
(3) 8' High Pole...
