Vise pedestal
/ Vise pedestal #1
mjncad
Super Member
In the civilized First World
A couple
Sometime ago I treated myself to a new 6-1/2" vise as I was tired of using a 55 - 60 year old 3-1/2" vise that was my old-man's. My workbench is too flimsy to handle this vise, so I built a pedestal for it. I could have bought one from Wilton; but they wanted well over $400 just for a simple pedestal that is made from thinner materials than what I made mine out of.
The following three images are teasers, and all the pictures can be viewed at: https://picasaweb.google.com/110106108324823291002/VisePedestal02#
/ Vise pedestal #2
Looks Great!
I made one almost identical to yours.
I do not have a lower tray though.
If you do alot of welding you can ground your vise permanently with a bonding strap.
I have my work bench hooked directly to my welder and a vise on the bench.
I also have a vise on a pedistal like your with a second cable bonded to the bench.
you can run flat stock steel and secure it to the floor so there is no cable to trip on or damage. I just run a cable.
I like being able to lay work pieces on the bench or secure them in the vise with out a clamp in the way.
I can stick or tig this way.
I hook my wire feed welders to the bench top or vise stand and can mig without a cable clamp on the work piece.
just an idea for you.
again, looks great!
aaaa tools 001.JPGaaaa tools 002.JPGaaaa tools 003.JPGaaaa tools 004.JPGaaaa tools 005.JPG
Tom
/ Vise pedestal #5
Nicely done! That's not going anywhere.
/ Vise pedestal #6
Workmanship at its best. Both items done to perfection but knowing who did it I'm not at all surprised. Really enjoyed the photos. Good work :thumbsup:
/ Vise pedestal #7
One of the most handy vice mounts I have put together fits into a 2" receiver on the back of the truck.
/ Vise pedestal #8
:thumbsup: I like the sub platform. I find a wheel/rim to be quite convenient for a base. Easy to move around. Store steel inside for added weight.
larry
/ Vise pedestal #9
Very good idea and workmanship. I made a similar post mount for my Wilton. Just thought I'd add that I use my vice for an anvil just as much as I use it for holding pipes and items to be welded. It takes a beating and still works fine. I've also added a clamp barb to hold a welding ground.
/ Vise pedestal #10
I've got two vices mounted on semi rims. I can roll them around to where ever I need them. It works out very well!
/ Vise pedestal #11
Very nice. I couldn't dedicate the space needed for a large vice pedestal bolted in place. Since the vice can handle large (long/heavy) material size I just didn't have enough shop room to fully utilize a solid mount. I found a man hole cover and welded an I beam with 3/8" top plate for the vice to bolt to. It is amazingly stable for all but the longest/heaviest pieces and I can muscle it over and roll it around when I need to.
/ Vise pedestal #12
Pictures? What size is your vice?
I'm looking for ideas for 2" receiver mounting for a vice. I also have a receiver on my loader bucket that would be handy to mount a vice on occasion.
/ Vise pedestal #13
Nice work:thumbsup: I wish my shop was big enough to put my vice out in the open area like that. A vice on a bench limits what you can do. Has any one ever installed a receiver in the concrete, Then you could easily remove the vice when not in use.
Bill
/ Vise pedestal #14
I saw a video on how to change the tire off the wheel for an ATV. What was neat about the setup was that they had a work table with a 2" hole that they could slide there special tool. But they could also slide their vice into the same while because it was mounted on a piece of flat metal that was welded to the 2" tube that could slide down in the same whole. Just used a set screw to hold it in place.
So for those that don't want a permanent mount and a little versatility, might consider that as an option.
/ Vise pedestal #15
I built this last year to try and save some space in the garage. Took a rear break drum of a big rig and bolted a piece of 1/4" plate inside. Then took 3" tube and welded to the plate to make a stand. I was going to fill the drum with cement but the weight was enough for its intended use. The top is a welded up front differential out of a 95 Chevy pickup. The stand will hold 4 tools and by spinning the yoke I can bring the needed tool to the front. The base would work great for a vise.
/ Vise pedestal #17
I have 3 different mounts with 2 6" vices and one 4".
One looks like the one above. Another is pretty close to that but has two 5/8 holes so it can be mounted normal or on its side, it mounts in a 2" reciever in the side of a flat bed.
The last one is very close to this press mount.
/ Vise pedestal #18
Wow, nice set up.
/ Vise pedestal #19
i like your porta-band adapted to become a mini bandsaw, nice.
any details on how you did that? i'm sure more here than just me would like to know.
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2018 RoGator 1100C (A63688)
2018 RoGator 1100C...
2005 Freightliner M2 106 20ft. Reefer Box Truck (A61573)
2005 Freightliner...
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
UNUSED WOLVERINE HYD STUMP GRINDER (A64281)
UNUSED WOLVERINE...
Generac Generator (A61572)
Generac Generator...
