Mig welding aluminium
/ Mig welding aluminium
Cheers guys.
I think I am going to call it a day on this.
I don't know the grade of the wire, just whatever was stocked at my local Machine Mart. It is very soft though and my rollers have teeth so the wire comes out with ridges rolled in it.
The gas is also leaking as the liner doesn't fit properly. It is very slightly larger then then the original liner and the seal clamp by the rollers doesn't clamp down properly. I guess my set up isn't going to help even if all else works out.
I am going to return my welder to steel welding and hope that I haven't caused any damage to it trying to convert the liner and the gas pipe.
Anyway, I have a 10 pack of Durafix brazing rods coming in the post to me so I will give that a go. At least it won't melt away the tubing even if it were to go wrong.:)
/ Mig welding aluminium #23
Yep, that setup just sounds like too many things wrong to do aluminum. As you found out, it certainly aint as easy as sticking steel together.
If the brazing rods dont work out, Save up to get a TIG machine. I know you said you arent ready yet, But when you are, you will wonder why you waited soo long. Some of the chinese machines are pretty good (so I have heard). A couple of them are sponsers on this forum. (Everlast and longevity). They are pretty affordable, and when/if I ever get one for home, it will probabally be one of them two cause I am a tightwad.:laughing: I just hope that the dynasty 200 I use at work hasnt spoiled me too much:D
/ Mig welding aluminium #25
Definatally is nice.
Gotta ask though, The 200 and 300 are pretty similar machines. What do YOU do that requires you to set it over 200A?? Cause I Imagine under 200, everything is pretty much the same. I can see stuff over 1/4" maybe wanting for more, but as it is now, I do 1/4" at or right under the 200A setting.
The machine also has a lot of features that I dont use, like the pulser. I am old school and like the foot control. About the only settings I mess with are the amperage and balance (depending on how much cleaning/etching I want). I dont even mess with the Hz on it. Just as long as it is somewhere between 100 and 200 I am happy. But I aint no pro neither.
I could see where the 300A may be of benefit if one likes to weld 1/4" WITH the pulser, cause the pulser makes the puddle run cooler than without.
/ Mig welding aluminium #26
Me neither!
My 300 will struggle with 3/8-inch thick aluminum. If the piece has any size / mass I have to use the heat gun to preheat.
When I want a lot of penetration on aluminum I use very high frequency, this narrows the arc. I also use some pulse, this will also help narrow the arc. I use 85% background, 80% peak time, and 200 pulse per second.
TIG would be great but just can't justify it yet. It is as much the cost of additional gas bottles from BOC as the cost of the welder.
I don't like having to pay, on top of the gas, annual rental on the bottle, delivery and handling even if I collect it myself, admin, a business account when I am not yet in business, hidden costs, environmental costs and every other cost they can think of that makes £50 of gas cost £170 to get hold of.:mad:
I am trying to work my way out of sickness benefits. Due to the unemployment levels here, and being ill for near two years, and not being able to get a reference from my stupid previous employers who made me sick in the first place, I have to make my own work by making bespoke bicycle trailers and bicycle parts, converting small tractors to electric drive, and fine furniture (my proper trade and teaching subject).
Awkwardly I also can't start to work without losing the benefits that pay the mortgage and bills when there is also no certainty that the work will continue.
However, I am trying to do this with no spare money and a lot of good will from people I have worked with in the past. If I can get regular commissions of any sort then I can justify investing in more equipment, TIG welder, a small milling machine, and a bigger lathe.
I will keep trying though.:thumbsup:
/ Mig welding aluminium #28
I didn't read every word in this thread, so forgive me if this has already been mentioned!
I sort of remember trying to do this years ago, (30) before buying my first Tig welder. I had a Miller S32S remote wire feeder that I ran on my 450-amp diesel drive. I bought the shortest Mig gun I could get, with a nylon liner, U-groove drive rolls for the feeder, and hung the feeder above the work, so gravity could help me. Had to keep the Mig gun as straight as possible at all times, or I'd spend the next 5-minutes cutting the bird's nest out of the drive rolls. It can be done, but what a PITA!
Here is a couple pictures of a 1/16th inch corner joint I did when I first got my spool gun. I'd still rather use Tig! I never have been comfortable welding thin material, even to this day 3/8 inch is about my limit!
Shield,
That's a very good weld for MIG!
I have a spool gun on my Miller and it's a joke if you ask me. It works but for SS and aluminum it just passes. (nothing I want anyone to see!)The trouble is you want to control the heat on those metals and the amps you start with aren't he amps you continue to weld with.
Rob
/ Mig welding aluminium #29
If you do aluminum on a daily basis you might see if you can make a deal with a shop that rents you time on their TIG. Also I don't know how it is there but we do see TIGs on local farm/shop ads. Maybe you can get a deal on a used one, EBAY?
Rob
/ Mig welding aluminium #30
Shield,
Rob
Yea, our miller 350p has a sp30a (IIRC) spool gun. It aint worth didly. Before we got the tig, we spent more time fiddling with it than actually making the weld.
Anyone serious about aluminum....Tig is the only way to go IMO
/ Mig welding aluminium #31
Shield,
Thank you! ;)
But I can't take the credit, if you'll notice my signature I buy top of the line welders, they do all the work. I just turn them on, and point them in the right direction.
See here is what my Dynasty 300 can do with Tig welding aluminum.
/ Mig welding aluminium #32
Shield Arc said:
Thank you! ;)
Looks great, have you ever tried a positioner bud? I just got one, and although im still sorting it out, I could definately see the advantages.
/ Mig welding aluminium #34
Shield Arc said:
I bought one awhile back. If you're anything like me, best get a notebook and start writing down the speeds for which process you're using. Otherwise I forget! :eek:
WP-250 Light Duty, Standard Speed Welding Positioner [AUT-WP-250] - $1,719.00 : Arc-Zone.com, The Welding Accessory Experts
Thats a big YUP! on that. Whooo doggie, you aint kiddin! Im starting to really enjoy it, ive only been using it with tig so far, and still have my moments of brain freeze, but little by little im working that out. One things for sure, I have to build a lower table for it, im short, and its way to high for me on my table, and standing up working two foot pedals is very tricky to say the least! :0
/ Mig welding aluminium #35
Woodsmith, after reading all the suggestions from the other members and I agree with most of them, here is something different and save you a few bucks. The cleaning is the most important overall, but instead of buying degreasers, solvents and such, just use vinegar. You say you used a s/s pad to clean with, thats good as long as you only use it on aluminum and always use a clean side or you're just rubbing contaminats back into the metal. After the pad, spray or brush it with vinegar, that will nutrilize the metal. Without a spool gun its hard to use the smaller size wire, really need .030 but to help absorb the heat from the bigger wire and give you more metal to work with get some aluminum rod, 1/8,5/32 and lay it between the tubes where you are going to weld, be sure to clean the rod too. I differ with a couple quotes here, you can make mig look as good as tig. I have been welding for over 40yrs and although tig is good, mig is faster, I hope this helps in some manner.
/ Mig welding aluminium #36
I have mine mounted on one of those cheap Harbor Freight tool stands. The height worked out perfect with my stool. My biggest problem is remembering which pedal to step on!:mad:
/ Mig welding aluminium #37
I've come close to making my Mig welds look like Tig. Guess it's a good thing I can't Tig weld all that well.:eek:
/ Mig welding aluminium #38
Too much spatter and ripples in the puddle. I like tig:D
/ Mig welding aluminium #39
I thought the ripple / fish scale look is what everybody is after! :confused:
/ Mig welding aluminium #40
Yea, the stack-o-dimes look is what everyone goes for. But in that mig weld, there looks to be tiny "ripples" (for lack of better words) in-between the stack of dimes look.
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
2022 Blue Diamond Brush Cutter (A64126)
2022 Blue Diamond...
