How do you store welding magnets
/ How do you store welding magnets #1
Hooked_on_HP
Coal City IL
Ford 1900 FWD Kubota F2100E
How do you store your welding magnets so they don't attract every metal filing that gets close to them.
Bill
/ How do you store welding magnets #2
Don't use the ones I have much, but at the moment, their stuck to the side of my welder.
/ How do you store welding magnets #3
ziplock
/ How do you store welding magnets #4
I don't use them much any more, as with DC welding, they can cause arc blow. Mine are stored on the side of my old Lincoln AC225 which I haven't used since I got a DC welder.
James K0UA
/ How do you store welding magnets #5
Glued to the inside wall of a metal cabinet.
/ How do you store welding magnets #6
Absolutely ziplock bags. They also work great that way for picking up chips around my milling machine, and easy to clean up. Just remove the magnet from the bag and chips fall off.
David from jax
/ How do you store welding magnets #8
stuck to the side of my welding cart.
Ive seen some magnets that are "sealed" around the magnet so that filings cant get in between the face plates. Ive also seen one with an off switch so you can just turn it off to clean. I think Ill grab one of the switched ones when I find one.
/ How do you store welding magnets #9
... Ive also seen one with an off switch so you can just turn it off to clean. I think Ill grab one of the switched ones when I find one.
Switched, really?
/ How do you store welding magnets #10
Switched magnets aren't NEW, they have long been used in dial indicator mounts. Not sure if they completely demagnetise or not.
David from jax
/ How do you store welding magnets #11
Switched, really?
The "switch" is mechanical in nature not electrical. It withdraws the magnet inside the enclosure away from the surface when you turn the "switch" to the off position.
James K0UA
/ How do you store welding magnets #12
/ How do you store welding magnets #13
Interesting. Either I haven't come across them before, or if I did I didn't realize what they were.
I just use a sack made out of nylon that looks like tent material. It keeps the big stuff off the magnet, and doesn't tear as easily as a ziploc. But, metal dust does work its way through the cloth.
/ How do you store welding magnets #14
I'm too lazy to store them properly in a bag. I just throw em on my welding cart and when I need it I use a old rag and swipe off the metal filing when I need it.
/ How do you store welding magnets #15
Mine stay in a ziplock bag. The freezer bags are a little bit tougher.
David from jax
/ How do you store welding magnets #16
Stuck to the side of my welder.
/ How do you store welding magnets #17
I cut out a piece of sheet metal and screwed it to the wall. I store my magnets and my magnetic parts trays on it. The Switched magnets are still magnetic after you turn off the switch. Yes they are a little easier to clean. All the magnets are just to get a couple tacks. Not meant to weld into the mag field.
/ How do you store welding magnets #18
To clean small metal filings from my magnets, I have found compressed air blows the filings right off. Of course, you always have to be careful not to get them in your eyes.
/ How do you store welding magnets #19
I do not worry about it, a 100PSI air nozzle cleans
them up in no time w/ little effort...
But for the record and FWIW, they all are stuck to my H-Frame Press.
/ How do you store welding magnets #20
Lid of tool chest
INGERSOLL RAND VR90B TELESCOPIC FORKLIFT (A65056)
INGERSOLL RAND...
2015 CHEVROLET CAPRICE (A66091)
2015 CHEVROLET...
2017 Chevrolet Malibu Sedan (A66738)
2017 Chevrolet...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
CAT 928G GP Bucket (A68134)
CAT 928G GP Bucket...
2011 FORD CROWN VICTORIA (A66091)
2011 FORD CROWN...
