Tires Flat tire
/ Flat tire #21
deep if u get those tires i think u may loose some torque. may loose your top gear with those tires when bushhogging or operating on a ahill.
Yeah this is something I'll have to consider, Plus my plans are to load the rear tires on which ever ones I do wind up with, this same person also has 11.2 x 24" tires/wheels for the same price, I think is choice of either set for 450, but for the money it seems that the larger set would be the best deal, Though it does makes sense to stay with a more suitable tire size for my size tractor, I have him getting measurements on both size tires,.... I recall seeing here a while back where someone compared the 11.2 to the 8.3 stood side by side the 11.2 is a good bit larger in height, exactly how much I don't know?
I think I'll pursue the 11.2 size tires, if anyone here would be interested in the larger ones here is the ad,
TRACTOR TIRES
/ Flat tire #22
I see ur thoughts get the most for your money, but if he has that smaller set id go for those. thats closer to the size Cali has. He use to have his larger tires fully loaded but said the additional weight on them slowed him down and boggged him up while pulling a hill, so he only is loaded to half full.
/ Flat tire #23
BBF, do you know what size ( width ) the rims are on your tractor? didn't you state that your tires are 9.5 x 24" ... reason asking is I just bought a set of 9.5 x 24 and hope they will fit the 8" wide rims on my tractor, Knowing if your rims are the same would certainly verify that this size tire will in fact mount on my tractors 8" rims, ..... about those larger tires & wheels I had looked at, The wheels didn't have the correct center hole size which is needed for my tractor, ( 3 3/4 )... the kubota wheels were 5 1/4 center hole, this would have put the hole into the area of the lug bolt holes and would'nt have fit, so I didn't pursue any further, instead I found a deal on some 9.5 tires for 200,
/ Flat tire #24
I think my rims are 8x24? but not sure. My tires are 9.5s. But in my opinion they will go onto 8" rims even if that is not what size my rims are. If anything it will just make them taller and thinner.
/ Flat tire #25
Yeah they will fit Deep I'm sure of it.
My tractor has 24" wheels not OE but thats what it came with... and they put 14.9x24 R-1's on and they fit fine the stock tire size was 11.2/12.5 or something like that dont recall at this moment.
/ Flat tire #26
Yes they do fit......:thumbsup:., My son and I mounted them yesterday, However we manage to pinch one of the inner tubes so we patched it, although having to add an extreme amount of air into the tube (50 lbs) in attempt to get the tires bead to seat, apparently the patch didn't hold under that much pressure:cool: ( went flat over night )..... So! now I need to install a new inner tube, back to the tires themselves are certainly more size differences between the old 8.3 and the 9.5's than I thought would be, with being less than 1" left between the tire and the fender, it has set the tractor up approx 2" higher in the rear which was something I wanted to do, Remember a while back when I installed some 15" wheel/tires on the front, doing this added additional 2" height and more clearance to the front I hope all this extra height doesn't make it more susceptible to turn over, though it also seems to have a wider stance with the 9.5 tires,
/ Flat tire #27
No Pics.:D
/ Flat tire #28
Yeah fer sure.:D comparing the 2 sizes both front and rear, My apologies to you BBF if I have Hijacked your thread, I assure it wasn't intentional,:eek:
/ Flat tire #30
Those look like some good tires you got!! Im sure your old one will round out as well when pumped up to appear taller?
They look good though nice lugs and dont look dryrotted a bit in this pic! Lugs look a good bit taller!
As for the new ones you should be able to get your local tire place to get you tires for less than that ebay price and there will be no shipping as those places deliver daily to the shops to stock their tires. If i remember right i think the shop in town got tubes and tires in my size for a few hundred dollars a peice for the 9.5x24 when i saw a set sitting in the shop waiting to go on someones deere.
/ Flat tire #31
You might want to check with local firestone store. Especially if you are in an agriculture area. Locally our firestone has new 9.5 x 24's for 305 and they also have service truck which will go out and install tires and/or repair flats. Sounds like maybe a boot and a new tube and you would be back in business. Lot less than a new tire. Good luck.
/ Flat tire #32
Those look like some good tires you got!! I'm sure your old one will round out as well when pumped up to appear taller?.
No not really, they are what they are, tractor tires don't necessarily get larger when they're inflated, I mean unless were to over inflate them, you can see by the old picture how much more room between the tire and the fender, I have 25 lbs air in the 9.5, and had about 20 lbs. in the ones I took off due to them being so badly cracked, Otherwise would have ran about 25 in them as well,
/ Flat tire #33
You realize that these tires per the book (Yanmar service manual i have) are suppose to be run with 14lbs of air in them right? Not saying that im right on the tire issue, i beleive you, im just saying that due to your cracks, you might not be albe to see them at correct PSI.
/ Flat tire #34
i agree.. I usually run rears int he 12 psi range.. depending on the tire.. and fronts more like 26 psi.. :)
/ Flat tire #35
Clemsonfor,
No I didn't know the correct air pressure should only be 14 lbs/-psi, I've always run what look to be normal for the tires dry rotted condition, if the tire pressure were too low the sidewall cracks would open and if had too much air in them the tread cracks would start to open, so right around 20 lbs provides an intermediate pressure for both conditions of the tire, ( on a side note:) It's too bad one has to inflate these tires to almost 50 psi in order to get the bead to seat, because what started out to appear to be a good none rotted tire now has some places in it that are in fact cracked,:irked: I think having run inner tubes must make the tire more difficult to seat, because the tube is pushing against the tire rather then only air pressure alone, The inner tube has to reach a certain inflation ( 50 psi ) causing the tire to over inflate to seat, even after using soap to help, and this isn't in just one try, it took 3 attempts,after it finally seated I then lower it back down to 22-25 psi,.... Though! now that I know the specs I'll try to run even less air pressure,
This might be the difference on the owners manual recommendation of air pressure of a tubless tire,
can anyone weigh in on this to clarify explainane the correct method to inflate a tractor tire?
/ Flat tire #36
my tires which are the same as your new ones not sure what they needed to seat, just got them but i paid $10 to have tubes installed. anyway im running 15lbs in rear and they dont squat empty and just ever so when the 700lb finish mower is lifted. i think i could even take 3lbs out to even pull better in dirt. after all u want to use al the lug not just the middle of them.
/ Flat tire #37
After some quick research I found this bit of info, Looks like I went about it all wrong, this procedure was leaving the tire on the tractor,
. Seating the Bead
Lower tractor until the rim is centered in the tire. This is very important to seat beads properly. Make sure tire beads and rim flanges are aligned. Using a remote control inflating gauge (Item No. HI405 ) with extended hose and clip on air chuck, slowly inflate tire making sure tire beads and rim flanges are aligning properly. Continue to inflate tire to seat beads. DO NOT inflate beyond 35 p.s.i. or manufacturer's recommendations when seating beads.
After beads are completely seated, remove valve core and deflate tube completely. When all air is out of tube, re-inflate to manufacturer's specifications. Always stand off to the side when inflating; DO NOT stand directly in front of tire bead/sidewall area
/ Flat tire #38
Operator manual for my 2002d has these listings. 8.3-24 12-23#, 9.5/9-24 12-18#, 11.2/10-24 12-18#, 13.6-16 12-14#,
/ Flat tire #39
Interesting! when looking at the chart air pressure per size tires it shows more air in the smaller tire and decreases as the tire sizes get larger, and usually larger tires mean larger tractors means heavier tractors, or are these the specs if were to run these size tires on your 2002d? incidentally I've just got back from lowering the air pressure to 17 lbs/psi and it seems to be fine at this pressure, although I think anything less when lifting heavy implement would squash the tires down,
As I mentioned in the near future I have plans to load the tires, Doesn't this effect the air pressure as well, what would be a correct pressure with liquid?
/ Flat tire #40
Its backwards logic when you deal with tires. Tiny bike tires run at 50-70 psi and tractor tires run less than 20psi. There is more air and to hold it up. THats just how it is. You put 50psi in your bike tire and 35 in your truck tire?
But Deep like i said i have 9.5x24 tires, on my yanmar 2000. I will run my disk harrow that is ballasted around 500lbs or more is my guess and i run a 6ft BUSH HOG brand finish mower that i think weight 695#s if i remember right and they barely start to squat the side casing of my tires. I transport the FM over at least 1 mile of pavement from one property to the other and will only notice a tiny bit of deflection when i pick it up.
As far as water you run the same pressures, i guess the even though the air space is smaller cause of the mass or the tire area you still can run the same?
I filled my tires with winshield washer fluid and am running like i said 15psi, no problem with squat.
2023 26ft Freedom Trailers Akurate Dynamics T/A Mobile Spray Foam Trailer (A64556)
2023 26ft Freedom...
John Deere 12ft pull-type cultimulcher, Orion, IL (A65640)
John Deere 12ft...
500 gal Poly Fertilizer Tank (A66408)
500 gal Poly...
Gehl 970 Silage / Forage Wagon (A66408)
Gehl 970 Silage /...
Richie 300 Cattle Water Tank (A65640)
Richie 300 Cattle...
2006 Western Star 4900 Concrete Mixer U98352 (A62613)
2006 Western Star...
