Box Scraper Beginners guide to using a box blade
/ Beginners guide to using a box blade #81
I personally don't know of an attachment that will pick up only those rocks?
A Rock Bucket should work. They are available for Skid Steers and for FELs. Everything Attachments is one place to get them.
/ Beginners guide to using a box blade #82
Here is 100% what will happen to those side plates over the years if they engage hard ground a lot.
First pic is when the boxblade was fairly new after my hydraulic rebuild.
Notice the side plates are fairly parallel top and bottom. Look at them now after hundreds of hours.
Now I like that box blade with the hydraulic scarfers. When you said after your hydraulic rebuild did you mean the adding of the hydraulics to the box blade? Did you do that yourself?
/ Beginners guide to using a box blade #83
3RRL doesn't come around to often anymore, :( but yes he did all the mods himself. He is a "Master" with his box blade. :thumbsup:
/ Beginners guide to using a box blade #84
3RRL was here this today.
/ Beginners guide to using a box blade #85
Hi guys!!
Yes, I was snooping around today on TBN.
Glad to see some of the old stuff is still being viewed now and again. I still have that Howse box blade and did the hydraulic gear driven ripper set up myself while I was camping on my property. Here is the old link to that story if you're interested: http://www.tractorbynet.com/forums/hydraulics/77667-gear-driven-hydraulic-scarifier-system.html
I recently broke off the right front drive unit on my 4wd Kama tractor.
You know how the castings are, two pieces that bolt together with a bearing post on one that goes into a bearing on the other. Well, I sheared that off and also the vertical shaft for the bevel gears, lol. Had to weld it all up and make new again! Sorry, didn't take any photos though...
Good luck guys,
Rob-
/ Beginners guide to using a box blade #86
Great write-up Rob! I've had all kinds of problems trying to get a nice finish on my gravel driveway with a box blade. I can see now that I had my top link set completely wrong for what I was trying to do. I'm heading out now to do some adjusting and get some practice in.
/ Beginners guide to using a box blade #87
I also find pushing backwards is better for leveling small areas as your tractor runs on the levelled surface. You need to have pretty loose material to do this though.
/ Beginners guide to using a box blade #88
Bulldozing in reverse is very satisfying giving a great result.
Remember not to push too much or you could easily bend your drag links. The best way to avoid this is to use your scarifiers to loosen up the soil first. If possible, rip in 90 degree directions (or more) until the soil is loosened. Then ONLY push the loosened soil in reverse. Do this over and over again until you obtain the desired results.
One important thing that has been said repeatedly, is NOT to expect a "one pass" finish whether pulling or pushing the soil when using a box blade. It is a great tool when used properly and with patience.
/ Beginners guide to using a box blade #89
Great thread with lots of good advice. Can't wait to put it to use.
/ Beginners guide to using a box blade #90
Great thread full of info. Thanks to all for sharing.
/ Beginners guide to using a box blade #91
I didn't see the information on beginners use of boxblade, only the gear driven tooth set-up. Can you post the link again please?
/ Beginners guide to using a box blade #92
Look at post number 8 on the first page.
/ Beginners guide to using a box blade #93
I have spent many, many hours when I worked construction in CA. on a tractor with a "box scraper" (Gannon) as I was the only one on the crew who had ever touched a tractor (I'm from Nebraska) so I HAD to catch on to how to actually operate one, not just drag it behind me. The Gannon box is a box scraper that moves hydraulically up, down, side to side and the rippers are also hydraulic too. They are a WONDERFUL tool that you can do many, many more things than most people can ever imagine, after a few years I could cut blue tops with it and my finish grading was second to none BUT there are some basic things you HAVE to know to make a box scraper work for you.
I have a Kubota B3000 of my own and it has a Woods box scraper on it and it is a basic unit with no hydraulics. The settings on box blades are a little unusal until you "catch on" to how it actually works.
1:Take you tractor and park it on level concrete surface if possible, make sure you box blade is level when it is about an inch off the ground, if it's not get it leveled up any way you can and it will work much better for you when trying to work your ground.
2: Let the box blade completely on the ground, notice if the front blade is off the ground or the back blade is off the ground. If the back blade is off the ground the box blade is in a "digging" position and no matter what you do it will want to dig, this is fine if you are trying to trim down some ground but you don't want to try to take too much at one time, you will have to do this in several passes, the more passes the more it will go down. If the ground is loose when the box fills just take enough weight off to keep it from dropping while you are dragging the dirt, just have the back blade about 3/4 inch to start with as this is not too agressive but you should be abel to tell if you need to back it off with the middle arm or add a little more angle as long as the front bottom sides are not dragging in the dirt.
3: If you have dirt you are wanting to "feather out" or "spread out" dirt adjust so the front blade is off the ground lifted by the back blade being down further, I would start out about 1/2" up as most box blades are pretty small and will spread out rather quickly.
4: If you are just wanting to move dirt have both the front and back blades hitting the ground evenly and when you get where you want the dirt you are dragging just slowly lift the box up with the 3 point.
5: You can also let more out one side or dig more on one side by adjusting your adjustable arm if you have one. If not you can always let a little air out of one tire and put a little more in the other. Notice I said a little, not the best option but if it's all you got and you HAVE to do it then it will work.
It's simply realizing the front blade of the box is for digging and the back blade is for holding the front blade off the ground for spreading. This is for moving dirt while going forwards.
6: Cutting with the back blade is the same principle but much, much more difficult even with a fully hydraulic Gannon box but you will have traction like nothing else with all the down pressure on the back tires. It takes a ton of practice and a LOT of things can make each situation different but that is the basics of the box blade.
/ Beginners guide to using a box blade #94
OK I have another question. Several times compacting was mentioned. How do I compact the gravel drive after I have it smoothed out. The drive goes up at quite a steep angle and just driving the tractor over it doesn't seem to help at all. Any suggestions? How are you compacting the surface?
OOOPS never mind I just went back and read where that was address. Thanks.
/ Beginners guide to using a box blade #95
Just wanna say I really appreciate this thread. I just bought a box blade and was wondering what I was doing wrong. Now I know! Plus I guess I have a little too much BB for my GT. Any way, thanks to all who participated!
/ Beginners guide to using a box blade #96
Great tips, thanks so much for posting
/ Beginners guide to using a box blade #97
good synopsis Garrett-- exactly right on the control of the blades. The addition of a hydraulic "top link" makes the forward/reverse material movement a snap. Another type scraper that groomed many many yards in the early 50's is the Gannon rollover or "tumbleweed" scraper. It was a great tool when used with the drft control on the tractor. Using the draft control and proper adjustment of the blades made the tumbleweed the first choice of landscapers cutting swales and moving new material in new housing tracts. It would move material, spread like a champ and to use the ripper, the operator reached back and pulled the release and it "rolled over" to engage the blades. Same operation returned it to scraping. Secret to make it all work is as you pointed out, level the unit and make sure you can return the scraper to the same depth and attitude adjustment after raising , dropping the material and making the next pass.
/ Beginners guide to using a box blade #98
Great information here, just wish I read this a week ago. Now I can go out and practice. Thanks to all who took the time to post and help out the box blade newbs!
/ Beginners guide to using a box blade #99
Wow. What a great explanation on how to use a box blade. Thank-you very much Rob (3RRL).
I recently got a 54" BB from Everything Attachments for my BX25. I have a short road and a wide area I want to have graveled and wanted to do it myself, but after playing around with the BB for a while I had my doubts if I could do it well. Or even adequate. Then I hit on this article the other day and discovered what I was missing -- the top link adjustments. I had been told to adjust it so the BB was level to the ground, and that's it. But what a difference a little angle makes. Before, I had tried smoothing out a 20' x 20' area I had used for burning brush. There was a pile of dirt in the center of it before it became a bonfire. After, I hauled away most of it with the FEL then tackled the remains with the BB. Still looked awful. After reading this, I adjusted the front blade about 3/4" higher than the rear blade and hit it again. In one pass it's as smooth as a baby's rump. Now I have hopes for my road. In the first picture you see the difference in front/rear blade height. The second picture shows the results. I wish I had a before picture to show the difference, but trust me, it wasn't pretty.
/ Beginners guide to using a box blade #100
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
JOHN DEERE BD1108 GRAIN DRILL (A64277)
JOHN DEERE BD1108...
2014 Frontier BB2060 Box Blade (A65640)
2014 Frontier...
PAIR OF TRACTOR TIRES AND RIMS (A65643)
PAIR OF TRACTOR...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
