Box Scraper Beginners guide to using a box blade
/ Beginners guide to using a box blade #21
Nice thread I've stumbled upon; learned alot in ten minutes.
I notice quite a bit of top link adjustments to be made during the course of a box blading session. Now I know what top-and-tilt is for!
3RRL said:
- Levelling - thats a nother story. I cannot for the life of me seem to be able to level the driveway. What position should the blade be in for levelling? Should my toplink be all the way out, all the way in, or somewhere in between? How high would you raise the rear blade off the surface of the drive while doing levelling pass?
I touched on this above where somewhere in between is the spot you want for finish grading. Not necessarily leveling, so I assume you mean finish grading to get a smooth finish, right. Leveling would mean (to me) to cut off the high spots and fill the low spots. I set the blades so they are about the same, meaning the top link somewhere in the middle to achieve this blade position. Then I drag the box. What this does is the front blade slightly cuts off any standing ridges while the rear blade is smoothing the dirt out. But the front is not aggressively cutting. One important thing to remember is to compact those low spots you filled, or when you go through them with the boxblade, it will sink/cut deeper in those areas unless you've firmed it up by compacting.
After re-reading, here is another question I have. Rob, you are absolutely right, I do mean finish grading here.
For finish grading, am I dragging the box with the 3PT all the way down so the full weight of the implement bears down on the surface?
I've found that when I've dragged the box with its weight on the surface it tends to fill up. I suspect that this is because my top link is not adjusted right.
Just to be clear, you are saying I should be able to find a top link position where I can have the full weight of the box on a gravel surface and drag it to finish grade without immediately filling up the box. Correct?
daBear said:
Look in your L3400 manual and it will describe the float position for you.
daBear. The float - the obvious fact that the 3PT does not have any down pressure, somehow escaped me. Thanks for pointing it out. It is pretty obvious now that I think about it of course :eek:
/ Beginners guide to using a box blade #24
I didn't know you had a hinged rear cutter, I would think you could do things a little different than with a fixed rear cutter.
/ Beginners guide to using a box blade #25
Yes, that's exactly what I do.
Yes, you are right. You might need to tilt the box backwards a bit to keep the front blade from cutting/digging out more material or dirt. You will want to have the box "ride" a little more on the rear blade so the rear blade will crush the material down and smooth it.
I didn't know you have a hinged rear, so consider fastening it while doing this step. That way it should support the weight of the box and smooth out the material. You can see if it's hinged, it could swing out of the way and allow the front blade to continue cutting or scraping.
Exactly, but remember in your case that the rear blade needs to be fixed so it can smooth and not flop out of the way, allowing the front blade to dig down and cut again. Now remember I don't have a hinged rear box blade, so you will need to tell me if that works for you. I know it does for my fixed rear blade boxblade.
Anyway, the rear blade should support the weight of the box and smooth the material. It should keep the front from digging in or scraping too much. You want to set the two blades so the front barely cuts, if any at all. Just to knock down little ridges or pick up some stones, but not cut the entire surface. At that point you want to be smoothing with the rear blade primarily.
Once you get it right, a light will come on in your head and you'll know exactly what I'm talking about and you'll say to yourself, "Self...uh so that's how you do it. That's so easy why didn't I think of that?":) You''ll see the difference right away.
Let us know when that happens. When your get that part down, there is no stopping you to making perfect roads, trails, pads etc.
/ Beginners guide to using a box blade #26
I have a hinged Back Box Blade and in the finish stages I Extend my top link so just the Hinged Blade flaps on the ground giving a finished finsh. Play with the up and down of the three pt and you will find the happy medium..
Hmm. I didn't quite realise that the hinged back blade might actually cause me a bit of grief here.
I'm reasonably sure that if I extend the top link all the way back, my front blade will give me a pretty good cut and the box will fill pretty quickly. Of course that sounds like the last thing I really want for the finish grade.
I wonder if the problem might be that my HTL is just not long enough to give me the correct action that johnK is referring to. That would be too bad because I just got an extension bracket added on. I might end up need the longer top link from CCM after all.
I'll try to think of a way to fasten the hinged back blade. Nothing is coming to mind immediately.
I guess the other option might be to do the finish grade in reverse. I wonder if this might work - thoughts?
/ Beginners guide to using a box blade #28
Since this looks like the tutorial for "boxblades for dummys" Like ME! I've one question.
Where do weights come into all this? Just when you've got rippers down or what?
/ Beginners guide to using a box blade #29
canoe,
I was under the impression that hinged boxblades could be fastened so they don't hinge? Am I wrong about that?
rcr,
Weight, either from the boxblade itself OR by adding weight to it helps to make it more ground engaging if the ground is very hard or the boxblade just "skips" along the surface. Weight can be used to make the rippers dig in better or to make the blade dig in better too for slicing or scraping. It especially helps when having to slice or scrape off high points and also for digging ditches along the road when you've got your box tilted.
/ Beginners guide to using a box blade #30
The hinged back-blade has an advantage if you want to dig, in that it places the full weight of the BB on the front cutting edge. However, for finishing you do not want to have the cutting edge taking a bite, therefore you should develop a way to hold it in place.
Think of the back blade as a door and you need to simply place a door stopper so that it does not swing. If you do this will welding on a stopper then you loose the advantages of the swinging blade, therefore my suggestion would be to bolt something on.
At the risk of insulting your intelligence, this is what I would probably do. I would drill a 12mm or 14 mm hole in each side plate about 1/4 of the distance up from the bottom of the swinging blade (guessing at 5 to 8 cm) and about 14-16 mm from the back of the swinging blade in its fully down position. (That is against its stops, but make sure it is not being held out a bit by packed in dirt.) Once you get the position marked on both sides you can swing the blade up out of the way so that you can drill unimpeded. Use a pair of vise grips or a "C" clamp to stop it from swinging back down while you work. When you have the holes drilled get 2 bolts that will fit in your holes (I would prefer the heavier 14 mm) about 40-50 mm long and 4 nuts and 2 lock washers. These are the stops. With the bolts inserted from the outside and the lock washer and 2 nuts on the inside you have effectively made a removable door stoppers. If necessary you can use 3 nuts if 2 do not give you sufficient surface contact with the blade.
I used metric since you are from Canada, but if you prefer you could go with 1/2 in bolts (3/4 in head) and adjust the holes accordingly. Remember that any thread that is exposed on the bolt will get beat up a bit, you might want to cut the bolt flush with the last nut. Make sure that they are tight or they will enlarge the hole.
That is just the advice from someone who as never done it,:rolleyes: has not seen you equipment,:( and takes no responsibility for the result of this free advice.:D
Have a great day.
Mike
/ Beginners guide to using a box blade #31
I learned something new today about my BB on smoothing. Don't let the front cutting edge engage. This place is great:D
Mike - no insult to intelligence at all. I'm pretty new at pretty much everything there. I'm not terribly handy by nature but this site has helped me along the way. Who knew I'd be installing my own hydraulic remotes or doing my own service!
I like your door stopper idea and I'll poke around to see how it might work for me.
Rob, I too would have thought the back blade would have a way to lock in place. Didn't see it in the manual. I'll take a look again and let you know what I come up with.
Thanks again!
I re-read Johnk's post and I think I understand what he was trying to say now.
I think he is saying that I can ensure that there is cutting action on the front cutting edge using a combination of:
- 3 PT lift height and
- Top link adjustment.
This will make the rear blade flop around on the ground and be dragged, thus providing the smoothing action.
The difference between this and what one would do with a fixed rear blade is that the full weight of the implement is not on the rear blade (since it hinges and gets out of the way) to provide smoothing action.
/ Beginners guide to using a box blade #36
canoetrpr,
I've had both the hinged and fixed rear blade versions and they're very different to use. In general, the hinged are very aggressive in both directions because the other blade is always out of the way. But sometimes you just want to "smear" rather than "cut" and a rigid rear blade lets the two blades interfere with each other enough to do that. Also, you can get the rear blade elevated enough so you can "backdrag" with the front blade going backwards. If that's what you want to do, maybe you could bungee the rear blade completely up without having to hold it rigidly in some intermediate position. I think a rigid rear blade combined with a hydraulic top and tilt might have some advantages over a hinged rear blade. It still wouldn't address one problem we have in S. Indiana- red clay. It seems to pack in the dead space between the two fixed blades and its **** to remove with all those bolts in there.
John
jmc thanks. As it turns out, I had originally ordered the Woods GB72 - the standard duty model with a fixed rear blade. The dealer ordered in the wrong one for me - the medium duty HB72.
I decided to keep it since it was heavier but sort of regret it now that it sounds like there dosen't seem to be an easy way get the weight of the implement on the ground but not really cut - and just finish grade.
I'm trying to figure out what the point of the hinged read blade is vs the fixed one. You would think that there was some advantage to it since it is on the more expensive model. Confused.:confused:
I decided to look at the manual and what the recommend (for both the fixed and hinged models) seems to be quite the oppositte of what we've been discussing so far.
Note that they have covered "Scarfying", "Scraping" and "Backfilling' separately and so by "Leveling" I am assuming they mean finish grading.
LEVELING
1. Raise or remove scarifier shanks.
2. Shorten the top link so the cutting edge clears the
ground.
3. Drive forward with the box blade in this position and
loose material will be leveled.
I imagine they are talking about getting the BB in such position so that only the rear blade not the front one contacts the surface. Similar to what I thought johnk was saying
/ Beginners guide to using a box blade #39
What they are saying is that you should SHORTEN the top link until the front cutting edge is off the ground ie. the BB is riding on the side plates. That is that it is tipped so far forward that the side plates are carrying the load.
The way that Rob and others have suggested is to lengthen the top link so that the BB is riding on the rear blade.
Mike
Mike - yeah I figured thats what they are saying. I will have to experiment to see if doing this still allows the rear blade to contact the ground. If it does not then I don't see how this could possibly result in any fine grading / levelling action.
Figured I would play around a bit and the send them an email if I couldn't figure it out. Someone who designed a hinged blade MUST have thought about how it could be used for levelling without having to fix the hinged blade in place - or provided a way to do it.
Hyundai Forklift (A65579)
Hyundai Forklift...
2016 GMC SLT 3500 Pick Up (A62613)
2016 GMC SLT 3500...
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
NEW Wolverine DB-15-84W Snow Blade (A62679)
NEW Wolverine...
725 Gal Poly Tank on Skid  (A62679)
725 Gal Poly Tank...
