Now they don't show it at all on the standard 346xp but do show 14.1k on the e-tech version.
I have owned several new 346 50cc versions and none were e-techs and they all were 14.1k Just look at your coil it says right on it.
I somewhat agree, but higher max RPM can mean higher 'in the cut' RPM. There are variables to it though.IMO, the max RPM is a pointless spec anyway. Just used to sell saws
My OE stock ones dont have the balls to pull 3/8 JMO used 325 stock. Now the ported OE's did pull 3/8 way better then 325.
The NE 346 was no comparison with a new loop of 3/8 compared to new 325. 3/8 smoked 325 on stock NE 50cc.
My OE is ported and is a little beast. But it is faster with .325. I have been around other 346 NEs' (ported and stock) that were faster with 3/8 and at least one ported one that was faster with .325. All pretty close, so I say run what ya like. I do need to try 3/8 on my NE at some point...
What did you do to port your 346?
Yes, RPM in the cut is what is important and 'spec sheet' max rpm has little meaning. But if I tune one of my saws to max RPM and still get some 4 stroking, it will hold higher RPM in the cut. If tune lower max rpm, the in cut rpm will drop. My ported 346 will hold around 10.5k in the cut with moderate pressure.Modern saws all have a max free speed above 12.5k. Not many pull more than 10k in the cut. Most are around 8-9k in the cut regardless of max-free speed. So it is MY opinion that it is just hype to sell saws because it is meaningless. A saw with a 12k max speed that can hold 9k in the cut will cut faster than a saw with a 14k free speed but only 8k in the cut. RPM is not a replacement for power. I like power, not screaming RPM for my saws.
I have a question for those of you running a 3/8 chain setup on your 346's. Are you running chisel chain or narrow kerf 3/8 chain?
That's regular 3/8 full chisel. Good chain!
You might be confusing narrow kerf with semi chisel, since all narrow kerf in semi. But semi chisel is available all sizes.
I run regular .325 semi chisel and 3/8 semi chisel most of the time.
Thats what I have on my 6400/8400 right now. Its "ok" chain, but I wouldnt buy it again. I dont know if ALL the 30RC chain is this way, but mine came filed to 35 degree angles. I like 30. the 35 will cut a tad faster but dull quicker. For me, the 30 degree is the best compromise of speed and longevity. After I got the angles back to 30, it is "ok" chain. But @ $16 a pop, I'll stick with the locak stihl dealer who makes my 24" loops for $20
is your local Stihl dealer making your chains out of Oregon or Stihl chain?
I dont see the problem a new chain comes sharp and ready to use what difference does the initial angle mean? I have my grinder set @ 30 and whatever a chain is before grinding its darn sure 30 after.
I never have put an angle gage on a new chain to inspect what angle it is I just use them and once dull I grind them and start over. ymmv as always
oh I take that back I have a cheepo $99 northern toll grinder and I did take a new chain once and set my scales to it since they were staked on very badly maybe I AM off hahaha!
Thanks for the info. I run chisel chain on my bigger saws. I run Stihl Oilomatic .325 rapid micro .50ga yellow chain on the 346's. I find that the teeth stay sharper longer than the Husqvarna and Oregon teeth.
they ARENT 30 degrees. I got the woodland chain only because I was buying sveral things and figured it wouldnt hurt to try it out.
