Grid-tied solar
/ Grid-tied solar #161
An average solar PV panel puts less than 3 pounds per sq. ft. load on a roof. Not nearly enough to cause roof collapse.<snip>
I wasn't referring to roof collapse due to the weight of a correctly designed system but rather due to shoddy construction. In a prior time I worked as a roofer for several years and have seen some very shoddy construction in additions and modifications. Very often leaks develop due to improper flashing. Leaks cause wood to rot.
There are a lot of homeowners that don't like to clamber up two or three stories to double check all the flashing etc.
/ Grid-tied solar #162
Never seen a battery fail early in 30 years?? I'm not even going to touch that as it's either a play on words or something else.
If you set your panels vertical for NE winter to shed snow, you loose effective surface area.
It's subsidized because it has to be, because it costs more. They have to improve the 80% energy loss before it becomes economical in the north east.
I used to work for telecom about 10 years while I had a second job installing and replacing "station" batteries (200 Ah and up). The typical telephone switch battery lasted at least 25 years. That was about 40 years ago. Since then the battery and especially charging technology improved substantially. I believe that batteries might last 20 years or more.
/ Grid-tied solar
Dave, You must be joking when you say PV panels don't need to be subsidized...
With taxpayer subsidies, you are looking at 15-22 years to break even. Drum roll please....
That's a bad business investment no matter how you slice it. Then you have a worn out 20 year old system then what?
Don't get me wrong, I like it, just don't like people tring to sell it to people on the grid with false promises of saving $$.
Right now it's a hobby for people and that OK. Maybe some day there will be a tech breakthrough I hope.
No, not joking.
I hope I have been very straight forward about costs, see post #37 for example. It isn't an investment, it is a front-loaded cost replacement. I sure don't expect to make a dime on it, others may due to the markets for renewable energy credits which are state-specific. I do hope I will be in the break-even area at the end of the system life. At that point, it will be time to replace it with something newer and start over again.
In my particular case, replacing the water heater involved plumbing and electrical work. I don't have an itemized bill, but I would say that accounted for about $2K of my total cost that should not be counted toward the electrical payback period in the strict sense. I count it because it was part of my total project goal.
If 20 years from now, I can say I avoided burning 5,200 gal. of propane, produced some of my other electricity needs, and my net costs were very low, I will be happy, and doubly happy if I am alive to see that :laughing:
Let's say I come up $2K short of netting out to zero. Over 20 years that is $100 per year. I'll bet most of us pi** away that much and more every year. It's good to keep a perspective.
/ Grid-tied solar
Good point. Just because a house has a roof, doesn't mean it is a suitable roof, and all roof penetrations need to be done correctly and maintained.
/ Grid-tied solar #165
No, not joking.
That's a mature perspective. If solar is a "cause" and a potential money saver, it is doubly worth it to the "investor."
/ Grid-tied solar #166
If I were not on the north side of a hill with high trees behind me owned by my neighbor, I'd have solar for sure. I don't worry about the payback so much. I'd like having it around, monitoring it, installing it, and whole deal. I am considering moving just to get a flatter place, with more land, and one more conducive to such projects.
My all electric home power bill only costs me around $65/month in the summer, and ~$120 in the winter, but I do burn some wood. And I continue to try to drive those numbers down. First best money for me would still be more insulation...but not nearly as fun as solar and I do like fun as much as the next guy. And life just keeps getting shorter.
/ Grid-tied solar #167
I didn't consider them. They aren't compatible with my standing seam metal roof. Maybe in the right climate, they could be worth a look.
I have no idea what their life expectancy is, and the thin-film PV is not as efficient as the solid crystalline types unless they have made a lot of progress in that area. The trade-off is low production costs, but if their life is short, or not efficient enough to offset the low cost, you might have something that is a poor shingle and a poor PV panel. I would have to hear some local success stories before considering them.
In this area, I would be concerned about snow and ice build-up. What happens when a roof rake is used to clear the snow, for example.
Just making a guess here... I would suspect that solar shingles are best-suited for climates that do not get snow, get significant sunshine, and the architecture allows for the appropriate angle to get good efficiency from them. In addition, would you install these on the whole roof or only on large surfaces that face South to maximize sun exposure?
Efficiency doesn't matter.
If efficiency was always the driving force behind energy use, we wouldn't be driving cars powered by gasoline engines.
No, not joking.
VERY front-loaded at that... And, what will the cost be to replace the system in 20 to 25 years when the subsidies are gone?
My front-loaded replacement system was to install a 75,000 BTU wood-burning insert into my fireplace and save $3,000 / year on fuel oil for heating. Considering I paid $4,500 for the insert, installation, and the chimney pieces, the system is completely paid for in 1.5 burning seasons. I got a manufacturer rebate, and because the efficiency level was so high, I also got a tax credit... That reduced my cost recovery time to about 1.3 burning seasons. When solar approaches these sort of cost recovery timeframes, they'll be highly adopted.
/ Grid-tied solar #168
Well, you have good points and reasons, IMO. We certainly don't all view world issues exactly the same. I imagine many here (including me) have a huge stash of wood, and a woodstove, or the like. However, I hope for the potential and the improvement of wind and solar. The more options we have, that are truly in place and functional, the better off any society making use of them, peaceably, will be. And the rules change, alot. In the 70's, electric heat was all the rave... then oil tanked, and made converting to oil, the next big thing. I'm enjoying learning from the variety of contributors on this site. Many great people, with incredible insight, vision, and ingenuity.
/ Grid-tied solar
Who knows what will be available 20-25 years from now? A handful of people in Japan are buying natural gas-supplied home fuel cells at about $64,000 each :eek:
Never say never, but I doubt solar electric generating systems will ever have short payback periods. You can't run a light bulb from an insert wood stove, and solar PV is a poor choice for home heating. We aren't really comparing apples to apples.
You made a very good move financially, for energy independence, comfort and for it's green value.
But...
I don't know what you included in your cost to replace the $3000 in oil. It should include the wood, purchase or own labor, if labor then there is a chainsaw, truck/trailer/tractor, keeping it dry, toting it, emergency room :eek::D, etc. Your stove will be ready to be replaced or rebuilt in 20 years or sooner too, and you will probably be on your second or third circulating fan by then, and chimneys need maintenance and don't last forever. I think your continuing costs will be much higher than a solar system's.
Your upfront costs and annual costs are reachable by many more people. I don't say that dismissively, it's just an economic fact. That's more of a financial problem than technical, and there is no easy solution. Right now, leased solar PV systems are the only thing on the horizon to address that.
/ Grid-tied solar #170
But...
No, you can't run a light bulb from a wood stove, and it isn't a good comparison of ways to implement solar. The point I was making was that there are other areas where we have to invest money up front to get savings, and the savings comes MUCH faster.
I burn about 6 cord of wood per year. I buy it in log length for roughly $100 / cord. I have a $800 wood splitter, a $300 chain saw, and will spend about $50/year in fuel for the saw, splitter, and tractor (to move the wood on pallets) for cutting, splitting, and stacking. In total, my investment for the year in wood is somewhere in the $700 range.
By way of comparison, a cord of wood replaces an average of 175 gallons of oil (lots of factors have to be considered to get a fully accurate number: burner efficiency, type of wood, water content, etc - but 175 is a good "working number"). That totals out to 1050 gallons of oil. At $3.50/gallon (cheap during heating season in the northeast), that's $3,675 in oil. Subtract out the $700 I spend for the wood, and you're just shy of $3,000 every heating season.
Put better, I save somewhere around 80% by heating primarily with wood. That's a more useful number because the cost of wood increases in relation to the cost of oil. If oil were to double, you could expect the cost of wood to double. I would still save 80% although the dollar amount would increase to almost $6,000. :shocked:
/ Grid-tied solar #171
I failed to add that the chimney has a stainless steel liner in it that requires nothing more than seasonal cleaning (which I do myself). Replacing it would cost a few hundred dollars, and I would not expect to have to do this more than once every 7-10 years. The rest of the pointing work and such for the chimney would be handled at a cost of a few hundred dollars every 3-5 years.
All-in-all, I'm saving WAY more money that it costs me to operate, and the payback is very quick from the initial investment.
/ Grid-tied solar #172
QUOTE]
You have to consider efficiency in correct context. Gasoline engine uses fuel you have to pay for. Solar panels use free energy. If they are less efficient you just build the system bigger. Efficiency of solar panels matters too. The more efficient they are the cheaper they will be because of the bulk of the cost is the cost of the silicon crystal they are made of. At the end all what matters is bang for the buck. How much energy it produces relative to the cost of the system.
The solar system is very upfront loaded investment but if you finance it and the loan payment is about the same as you energy bill ( due to currently very favorable interest rates) it in effect costs you nothing. And you are not hostage to energy cost increase.
/ Grid-tied solar
I'm not disagreeing with that. You will save money, but most people don't look at a solar system as a way to save money. The goal or motivation is not the same. If I can accomplish my goal at no or low cost, that is a whole different concept. Five years ago, I could not afford to accomplish my goal, the cost was too high.
Waiting for solar technology with rapid payback plus savings may be waiting for something that will never happen. Sometimes, it is better to take what is there to take and be happy.
/ Grid-tied solar #174
Efficiency is efficiency, regardless of the context. Your comment was that efficiency doesn't matter. My comment supports that. If we chose all of our energy systems based on efficiency, we would not be using the internal combustion engine to power our cars. And, exactly to your point, the reason we do is "bang for the buck". We could have much more efficient motors in our cars, but they would cost much more. And / or they would cost much more to operate. The gas engine gained its popularity by being reasonably inexpensive to build and reasonably inexpensive to operate. When solar reaches a point where you get out a lot of energy without putting in a ton of money, it will gain in popularity.
I disagree that the financed cost of a solar system being the same as your current energy bill is a wash... If I currently spend $200/month (on average, over the course of a year) on electricity, I can not install a solar system for that much money that will completely eliminate my energy bill. And, even if I could, it wouldn't have any "growth" potential in it for any future needs that may increase my current bill. So, what's the point?
Further, why would I invest all that money to break even every month only to have to quite possibly "start all over again" in 15-20 years?
I understand the potential for green energy, renewable energy source, reduced dependance on foreign oil by cutting demand from the grid, etc....
But, the end question is the same - why would I invest my money into equipment that I must own, operate, and maintain unless there is a significant cost savings to me? See my earlier comments about installing the wood-burning insert... I avoid buying 1,050 gallons of heating oil each winter by burning wood. To achieve that fuel reduction, I spend $600 for wood and "$100" in miscellaneous costs for fuels and stuff. On top of that, I figure in about $100-$150 per year in maintenance costs for the chimney and such. Even with my operating costs, my investment for my stove is completely paid off in under two years and then I'm banking at least $2,500 every year.
/ Grid-tied solar #175
Why do I need to replace my system in 20 years? I expect a hit in efficiency, but they are not just going to quit in 20 years. My panels are warrantied efficiency 90%/12years, 80%/25years. It's not like they just drop to 0%.
Having been in hi-tech industry for the last 28 years, I imagine in 18 years when my panels and inverter turn 20, that technology will have jumped ahead. I'm not confidant that solar panel wafer development will follow Moore's Law, but I expect they will improve significantly.
Still, it is not like at 20 years I have to start over.
/ Grid-tied solar #176
Meburdick, the way I understood Dave1949's response a few posts ago, was he sees it as a cause. If I understood that correctly, than arguing about payback is less relevant ...
I give money to charitable organizations, in a large % basis, compared to my income. I do that, because I believe in the "causes"... There is no financial payback to me, whatsoever. On a spreadsheet level, donating to charity is financially stupid to do.
Dave1949 believes he is helping the planet. I think he sees it as a form of charity, however, he thinks he may potentially recoup all of his "donation" and possibly even make/save money over time.
Dave1949, if I'm misinterpreting what u said, please correct me.
/ Grid-tied solar #177
You can look at it another way too. People buy big trucks or Porsche as a daily drivers. Nobody questions sanity of such purchase. Show me any 50k car that cost nothing to operate and keep its value.
/ Grid-tied solar #178
Your savings could fund PV is also a point worth considering.
/ Grid-tied solar #179
That is comparing apples to apple pie. A cord of wood goes from $150 to $300.
In order to FAIRLY compare wood heat versus most other methods one should include human interaction such as labor required to get the fuel to change into heat and the "going" cost of the fuel, not what one individual pays for it.
I've got 3 houses and 4 methods of heating.
1. When I want to heat with the natural gas heater I just ensure the pipeline is still working and turn the thermostat.
2. When I want to heat with the electric heater I ensure the electricity is still working and turn the thermostat.
3. When I want to heat with the LPG gas heater I call the delivery man and turn the thermostat.
4. When I want to heat with the woodstove or fireplace I have to ensure the wood is nearby, carry it in and feed the unit.
SWMBO wanted a pellet heater at one time. Until I reminded her that if she was alone she'd be the one carrying the pellets.
My costs for fuels 1 thru 3 is the market rate, fuel 4, wood, is "FREE" to me. I make it as a byproduct of my small sawmill and cleaning up the lots. But even "FREE" requires a bunch of effort.
Since you ((meburdick) cut, split, transport and stack a cord of wood for about $10 a cord (6 cords with an out of pocket price of $100, plus $50 in fuel) and then gets it inside, you must have a greatly more efficient way of doing it than I have found.
I've enough trees on my land I could keep you (meburdick) busy forever at $10/cord.
A better comparison would be to price your 6 cords of wood at market rate. Connecticut Firewood Service sells it for $230/cord in Connecticut. Thus your 6 cords OUTSIDE would be worth $1380, and that's still not in the burner. So add in your labor to get it to the insert.
I agree there is a large savings, but to compare logs to oil is just not fair.
And if you looked into wood gasification you would see how easy it would be to run a light bulb from wood. WoodGasifier News - Wood Gasifier Generator
/ Grid-tied solar
I can see how you would enjoy analyzing a solar system. Probably have to add 4 panels just to run all the sensors and monitors :laughing:
Seriously though, energy savings through insulation and high-efficiency are the low hanging fruit that should come first. I think you are on the right track. If more people looked at their particular situation with the goal of reducing energy consumption, the cumulative effect would be huge.
ATS Mini Excavator (A66285)
ATS Mini Excavator...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63688)
2004 Cadillac...
New 11'x19' Steel Carport with 10' open sidewalls  (A62679)
New 11'x19' Steel...
2022 EZ-GO ELITE...
New/Unused Landhonor8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2001 Volvo Sleeper (A62613)
2001 Volvo Sleeper...
