yanmar ym1500 update
/ yanmar ym1500 update
o thanks my one is the green model. how did you get the new baring on the shaft? i dont know if you read my thread about the enginner who made a shim or a spacer to fit on a compact of a guy i spole to which ment he did not need to take the azle to bits did you have fillings in the oil with the bearing breaking up ? thanks
/ yanmar ym1500 update #82
billymc, is this what the back axle looks like on your 1500? This looks like a green Yanmar but appears to have a red rear axle setup.
http://www.ustrading.net/Yanmar_1500green_hitch.jpg
If you could take a picture of your back axle that would be helpful to see the differences between the two.
I'm trying to understand the shim/spacer you are talking about. What should that do for you? My guess is that would be to repair a damaged shaft. The bearing itself still needs replacement.
Looking at the drawing for the green 1500, it appears you have no choice but to remove the entire shaft to get to the bearing. But you may not need to remove the axle/brake housing. The tapper in #27 seems to not allow for the repair to be made any other way.
My suggestion would be to break it all down and determine what you need. I know shipping will be costly but Hoye would be your best bet. Make one large order and know you are getting the correct parts for the job. The only thing I suggest is removing the the seals from the outer bearing and pack it with more grease. You can then reinstall the seals. They come with very little grease initially.
Here is the internals for the green 1500 axle.
Yanmar Tractor Parts: REAR AXLE INT (G)
The photos below show the PTO shaft that is inside the rear axle housing. The sleeve that connects it. The original outer bearing from my tractor that had not yet completely failed.
View attachment 274526View attachment 274527View attachment 274528View attachment 274529View attachment 274530
yes that looks like the back end on my green model i will take a picture later to let you see. the spacer shim was to take up the side movement on te guys azle as he could not get the part to fix it.
ok guys this is the pics of the backend of my ym 1500P1010270 (2).jpgP1010272 (2).jpgP1010271 (2).jpg
/ yanmar ym1500 update #85
Thanks for the pictures. Looking at them I'd say you have a red axle setup. I know the tractor is green but if you look at the parts drawing, the green axles have a solid cover over the brakes. The red ones have a removable cover and the housing is longer where the axles come through. Also only the red ones seem to have the square housing behind the wheel where the bearing is located. Yours looks identical to my red one. This maybe something to double check with Aaron at Hoye.
yes im just trying to figure out what is the quickest way to strip and repair someone said you can take the plate of in bellow and get at the nit that holds the shaft in without taking the pto shaft out. do you think that if i can get the bolt out from in bellow that i can then withdraw the shaft with just taking of the rear axle hub and slide it out to repair. i was thinking of sealed bearings to replace?
/ yanmar ym1500 update #87
You can try to get the bolt out of the axle without removing the shaft. It will work I think if you have someone remove the housing with the shaft in it while you back out the bolt. The PTO is easy to remove if you need to. A sealed bearing is fine for the outer. Not for the inner bearing, it is lubed by the fluid in the axle. You still need a seal there.
so i definitely need to remover the housing and and brake cover that is one piece? is it a two man job for sure i thought if i could get the bolt out at the bottom then i could pull the whole lot off ?
/ yanmar ym1500 update #89
If I remember correctly there's not enough room to back the bolt out all the way due to the PTO shaft. You can try it first. The bolts that hold the shaft in were very tight on mine. Don't use an open end wrench. The PTO shaft comes out easily once you remove the 6 bolts from the cover. You'll se the collar inside where it separates. One person can do the job. Having a press is the key to doing it. .
do you think its easier just to take the top of or less work removing the bottom plate and just move it bit bu bit till i can get the bolt out? is there a bit of weight in the case when i take it of? o the localgarage has a press im hoping it will be able to put the new seal in and bearing or did you replace both bearings and seals ? well i need to cut a bit more grass before i do it will it be ok still ok use ? thanks
/ yanmar ym1500 update #91
I would replace it now. The longer you run it you risk more damage. The sleeves for the seals are $34 each. I did both seals and the outer bearings. My inner ones looked good because they are open to the fluid. The plate at the bottom needs to be removed completely. Hoye didn't have that gasket so I had to make it. Also look at both drain plugs. Order new ones and the crush washers if they look worn. Check your hydraulic pickup screen also. Now is the time to clean/replace it if necessary. Don't reuse the copper washers for the hydo lines either.
the place i got the pto seal from is just in england and they do sleeves for shafts bearings and seals but i need to get the sizes they do deliver for just £1.50 a order. and its only two days turn around. so will see if any body can come up with the size or i will have to waite till i strip it down i dont know how long its been like that ive just noticed it . thanks
/ yanmar ym1500 update #93
i does definately look like a red rear end,not a green but they do many odd things between countrys. like my YM14 is a 146 but has no hydraulics for the MMM, it is a long lever.
yes im not sure whether its a red back end or green as i think someone said the seal is different. which is not very handy if i order it tin the us and im in the uk as i hoped to get it back on the road asap . ok guys would i notice that the wheel bearing was away and do they just fail i have been using it and never seeen it till the pto seal was replced leaning against the wheel i felt it move forward ? is there any other thing that can be the cause ? thanks
/ yanmar ym1500 update #95
Talk to the guys at Hoye. They will be able to help determine it for sure. But I'm positive it's a red axle setup due to the square housings for the outer bearing and the bolt on brake covers. 30 some years of use will cause the failure. The outer bearings are never greased after assembly so the finally dry out and fail. It has probably been like that for a while. I found mine when it was apart for the hydraulic pickup screen.
ok i will drop them a e mail and see what they say. i can get most parts here except for the sleeves for the shafts? if the sleeve look ok do you think i could get away with out replacing them?
/ yanmar ym1500 update #97
If the sleeves look good reuse them. They are probably fine. Might just clean them up if they are rusty.
yes i will see what they are like when i take the shaft out ive e mailed hoye to see what they say i will prob start taking it to bits next week . have a few jobs to catch up with this week but will let you know how it goes thanks for your time. billy
/ yanmar ym1500 update #99
yep it is a red rear, a green doesnt have the housing extensions on it. the green axles are exposed all the way back to the diff housing.
/ yanmar ym1500 update #100
Thanks Neat. I thought that was the difference by looking at the parts drawings.
LOOK! (A63111)
LOOK! (A63111)
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
2009 Chevrolet Tahoe SUV (A61574)
2009 Chevrolet...
2007 Grove RT530E-2 4x4 30 Ton Rough Terrain Crane (A61572)
2007 Grove...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
New/Unused 72inch Quick Attach Rock Grapple Bucket (A65583)
New/Unused 72inch...
