yanmar ym1500 update
/ yanmar ym1500 update
o its just that the paper gasket is good for temp 80 to 90c then there is one called 8094 grade which is good for 150 to 180c just dont want to put one one then have to do it in case its not up to the heat? thanks
/ yanmar ym1500 update #62
Can the hot one work for cooler temps? the latter one sounds like exhaust type stuff. but i admit without a calculator or the internet i have no idea about the eq temps? I know 32F=0C and 100C=212F But the conversion is kind of consusing isint something like 9/5 or 5/9 or something? or is that 3/5? after elementary school and middle i just used a calculator.
yes im not sure about converting from c to f? but i think i will just get a multi pack of 5 sheets of gasket i had some but its not big enough to do the pto cover. i will let you know how it goes or i will ask about the c to f . thanks
/ yanmar ym1500 update #64
just use google to convert them. If were wondering? Well ill do it. 160F =71 C
200f =93C so im guessing you may want to use the hotter paper. I bet the lable temp is something like operating temp, that it should be used in, but could stand hotter temps. the 80-90 range is a good range for what looks like waterpump and tstat gaskets, although the water gets hotter than 200f and at 200f its already over the sugested range? i would use the hotter paper though to be safe.
For other conversions just use this google page and change the number to what you want to know.
Google
thanks i am going to order a multi gasket paper pack with all heat ranges . will let you know how it goes many thanks
/ yanmar ym1500 update #66
just wondering if any body can tell me of any other online yanmar parts suppliers ? on monday this week i e mailed hoye about a seal and postage costs to the uk but they never got back to me? the pto oil seal on my ym 1500 starts to leak after around 2 hours of use is that normal for a seal to be ok till its used a few hours then leak? thanks
L
I am thinking of buying a Yanmar. I do not know much about them. What do you know about Yanmar tractors.
L
hi o this is my first yanmar the ym1500 . just getting to know about it but seems well supported for parts which iss good as i live in the uk. i use mine with a finishing mower and it has plenty of power for it and seems good on fuel. but these guys here are very helpful if you run into any probs.
What do you guys think about a Massey Ferguson???
well i have a mf 35 was my late dads before mine . over 70000 near 8 hours on it just starting to need a few things done on it but its basic and can be fixed with plenty of parts in the uk dont know about what its like in the us?
ok guys just completed the pto oil seal job but when i was at the bacck end looking forward i saw what i think is a dirt seal on the left back axle side was loose so had a look but notice the back wheel has about a inch of side movement i take it it sounds like a bearing?
/ yanmar ym1500 update #72
Yes that sounds like the outer bearing is bad. I had the same happen to my 1500.I would suggest that you do both sides. You will have to pull the axle cases on both side also. 30 years of crud doesn't allow the bearings to come out easily and they are snug on the shafts. Also if you need to do that you will be disturbing the old oil seals that are in the axle housings so I would suggest them also. To pull the axles you need to remove the internal PTO shaft so you can remove the bolts that attach the shaft to the inner gear #25. It's not a quick job and you will most likely need a press to disassemble and reassembly the parts.I may have some pictures of when I did mine. I will post them if I have them.
Yanmar Tractor Parts: REAR_AXLE_INTERNAL
o so there is no real easy way to remove the shaft ?the other side has been done and a new seal put in it just before i got the ym. yes would be handy to see what is involved in stripping it down if you still have the pics? thanks or tips?
/ yanmar ym1500 update #74
... To pull the axles you need to remove the internal PTO shaft so you can remove the bolts that attach the shaft to the inner gear #25. It's not a quick job and you will most likely need a press to disassemble and reassembly the parts.I may have some pictures of when I did mine. I will post them if I have them.
I had to replace an outer bearing on mine years ago. As I recall, I did not remove the PTO shaft. I removed the plate on the bottom of the gear housing and loosened the bolt in the axle from there. Not a quick and easy task. The inner seal was a bit of a problem to find.
how did you find getting the bearing of the easiest way?you dont happen to remember the bearing size or the seal size? did you just replace one bearing and one seal? thanks
/ yanmar ym1500 update #76
The bearing numbers and seal sizes are given on Hoyes parts list. You can google the bearing part number and get sizes. They will all be in metric. For instance, the red 1500 outer axle bearing is a 6209-2rs. Googling that will find the bearing to be 45mm bore, 85mm od, 19mm width with double seals. I'll conclude by saying Hoye is not making big profits on their bearings. Of course if you live in Scotland the shipping would eat you alive.
The sizes are also given for the seals.
yes hoye have a good price on there items for sure o i have the green ym are they the same bearings? i was talking to a guy who said he had a compact and could not get the parts for the axle . he said the engineer made him up a sleeve that took the play away on his old compact he said the took the wheel of then the rear axle hub and measured it and made a sleeve to fit over the shaft and took up the side movement play?? has any body herd of doing that?
/ yanmar ym1500 update #78
Hoyes parts list shows the 6209-2rs on both green and red but they do show different seals. Interesting.
yes im going to ask the engineer about it if it stops me from having to take the shaft out and strip it as ive got a bit of work to do with it yet . so ont be doing it just yet but will let you know about this sleeve shim he did . thanks
/ yanmar ym1500 update #80
Are you asking how I got the bearing off? That was not a problem; it had destroyed itself.
Sorry, I do not remember the bearing or seal sizes. As I recall, the outer bearing and inner bearings are the same size. The outer bearing was sealed. It occurred to me that it would be possible to replace the inner bearing with a sealed bearing and eliminate the need for the inner seal, tho that would be an expensive way to avoid replacing the seal. BTW, this is on a red 1500D. The green version might differ.
Yes, I replaced only the one side--the outer seal, the inner seal and the outer bearing. That was about 10 years ago and there have been no problems on the other side.
78in Caterpillar Skidsteer Tooth Bucket (A65579)
78in Caterpillar...
2017 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A65053)
2017 CATERPILLAR...
1985 John Deere 2550 Tractor (A62679)
1985 John Deere...
2017 John Deere X570 Riding Mower (A66408)
2017 John Deere...
2000 FORD F-650 SUPER DUTY (A63569)
2000 FORD F-650...
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
