yanmar ym1500 update
/ yanmar ym1500 update
yes i agree you can find oil filters and service kits. i think its like you say its when the part becomes more expensive than the tractor. the way i was looking at it just now was that my massey 35 is starting to shpow her age no shame but i can still get the same money as we payed for her 10 years ago . so thought if i could get a half descent larger 4x4 compact to replace here that will work the log splitter saw bench i would not need to put to much more money towards that cheaper than fixing the mf ? i know the ym 1500 you can get the engine kits and startes stuff like that thats why i bought it knowing items like that were available so wandered if you guys know of a model like that that had a good supply of major parts as in the uk its 95 grey imports? or chinese?
/ yanmar ym1500 update #22
In the UK i dont think any of us can fathom a guess? We can get stuff that yall dont have there and cheaper. So what may be common here may not be there, but if we can get it its just the oversea shipping that will cost you on top of part but thats not a killer unless your talki9ng engines or axles or something.
But most of the models are well supported, and i think yanmar is the best, even better than some of the "suposedly domestic" models that are Himoto or shirabu based. As far as i know the 2200 and there is a few other yanmars that are not as well supported but still many commmon parts are still had.
A guy i work with said he has a JD 1020 tractor that his starter is $400-500 or so dollars. But he only buys JD parts for what ever reason. That is crazy high to me.
yes i think you have summed it up about the uk well. and ilive up north in scotland so its more of a problem . and postage cost here well they add extra cause they say its remote. anyway thanks for the reply the vintage tractors here are well supported for parts old david brown ford mf to name a few. but as i said i can get the same money we payed for the mf and its starting to show its age so though well if i can get a good second hand compact 4x4 around 20 to25 to run my log splitter saw and other bits i would not need to spend out a great deal of money as they vary in price from 3 to 4 thousand pounds. i just wanted to know that if i got one that major parts can be got ? two of the models that pop up here a bit are a the iseki2160 and the iseki ts2202 ? any you guys had one or know about them? thanks
/ yanmar ym1500 update #24
I dont know much about Iseki. But i do know that there a japaneese tractor that probly is just as reliable and simple as the yanmars and looke just like the Yanmars Mitsus and Kubotas of the time. BUT around here (dont know personally) but i would think repair parts would be more of a problem to obtain. Not necissarily things like starters and alts as those are more common id think and can be rebuilt anyway. Im talking more about things like steering knuckles or seals (you can get them anywhere you just have to do more reasearch than i have to do by sitting at my PC and clicking on Hoyes website for what i need), steering parts as well as engine kits etc.
As for The MF it should last forever. Those were good american made iron that lasts for ever and is basically infinitly rebuildable. They will easily go thousands of hours. Is it way down on compression, or use to much fuel? I understand the want or need for another tractor but that tractor will work circles around a 25hp tractor. But if prolly dont have a loader and if all you want is to run a pto genny or run stand alone things than its prolly more efficient for that type of work (small CUT tractor that is.).
o the ferguson is 7000 plus hours prob nearer 8000 i think its the engine with the cast liners ?? o its a bit heavy of the steering in small areas that the compacts can shoot round . the mf i use on the road and only plough and split wood and use a table saw and pull a 2 ton trailer maybe twice a year so i though a compact would do that and would then have a 4x4 to ? but i could look for a newer large tractor but they make big money here as they export them to the third world and eastern europe then the rest are swallowed up by vintage collectors or rally tractor. or ploug show tractors.usec anyway i was talking to a friend who works on a local farm and was asking him about hydraulic oil for the back end of the yanmar he said that on the fergusons they have they get a uni oil that dose backend plus engine ? but i told him to check what grade or numbers were on the can? to ask you guys what you thought ? what is the grade in numbers you guys use ie like 10w 40 we use in engines here?
/ yanmar ym1500 update #26
They use the same oil in engines as trannies?? What we use in our trans/hydro systems on most all tractors made since the 60's is called "universal tractor fluid" It can be made under any brand or name(often they have thier own name for it). Its 10w-20W. BUT ITS NOT engine oil! In yanmars it is known and done by several that you can use ATF trans fluid for cars in it, like a Dextron type. I know MJ peterson over there in Poland uses it in his. The fluid i have is some that i bought at TSC, i have some in a 5gal bucket ready to change it next time that i bought at Agrisupply when i swung by (they are about as cheap as i have seen at around $35/5gals).
Here is a link to TSC own brand of fluid in what fits 90% of tractors rolling around today(us yanmar folks look for the JD 303 spec) Traveller® Universal Tractor Trans/Hydraulic Fluid, 5 gal. - 0806391 | Tractor Supply Company
You can read about it on thier breif description.
I have used this fluid before but i actually have "accell" brand of fluid in mine now, also bought at TSC but was $5 cheaper at the time so i got it, not sure if they still carry it or not?
yes when he said that i was not sure about using the same oil for the engine . he is going to check so i will let you know what he comes back with. we have a motor factor in the next town so next time im there i will see if they have any trans fluid 10w=20w boy oil is cheap in the us? you know diesel here to buy at a filling station would work out around $13 a gallon red diesel would be around $7 cheap oil which is re manufactured here ie used oil made new would be around $100 for 5 gallons. will let you know what the guys says about the oil when i know . thanks
/ yanmar ym1500 update #28
Im sorry its 10w20 weight. not "10w20w" which i think i wrote. BUT again THIS is NOT just engine oil at that weight, it has additives in it for the hydro and trans use.
Are there any refineries there that make oil? Most of ours is made here in the US. Its either made along the coasts weather East coast or Gulf coast as well as some inland ones in the Indiana/michigan area i beleive?
At $13/gallon for road deisel our economy would be crippled!!
/ yanmar ym1500 update #29
I found a UK website describing the transmission fluid you need. Shell calls theirs Spirax S4 TXM, formerly called Shell Donax TD 10W-30.
This link shows a BobIsTheOilGuy thread
that list about 50 more names for the same product. I'm sure some of those, BP Tractranョ UTH etc, are available where you are.
As for Yanmar motor oil - just ask locally for the same oil as the largest diesel highway trucks use in your area.
thanks very much guys for the info i now know what im looking for. o yes its very expensive here for fuel here so compacts are taking of quite big here as you can get one for the price of a small petrol ride on mower that cant do half what a compact can do but i would say the biggest majority of the new compacts here are chinese and the rest grey compacts no majo=r dealers selling or breaking them like you have in the us. many thanks billy
just a update about the seal and oil i found there are two seals one has a double sealing ring? with one sealing ring and a dust protection ring ok the oil the guy was right when he said they used the same oil for the engine and back end of the tractor its called suto 10w.30 suitable for engine transmission hydraulics and final drive?
/ yanmar ym1500 update #32
HMMM, that must be a Euro thing?? We dont have that type oil here in the US. I really have never heard of that. Not saying it wont work with plain oil (for a period of time??) but hopefully this has some other additives that will allow it to work in both?
here is a link to let you see what it says about one brand from shell.
Shell Harvella TX 10w/40
View Full-Size Image
Call for Pricing
Harvella TX 10W-40 is an advance "Super Universal Tractor Oil" giving superior performance in engine, transmission and hydraulic applications for a wide range of agricultural equipment applications.
Meets or exceeds the following performance specifications :-
API CF4/SF, GL4
US Military - MIL-L-2104D
CCMC - D4
Ford M2C-159B
Massey Ferguson M1139 & M1144
Mercedes Benz 227.1
New Holland 82009201
John Deere JDM J27
Caterpillar CAT TO2
ZF - TE-ML 06
/ yanmar ym1500 update #34
I would think that 40w oil would be way to THICK to flow properly in the cold? Causing screeching hydro pumps and slow response. When its in the 30s my pump whines with the 20w oil in it.
/ yanmar ym1500 update #35
.. But when cold that stuff is 10w.
The 40 is only a spec for how much it will thin down at the upper allowable temperature - maybe around 300 degrees.
It meets Deere spec so it should be fine.
o i only put that one on you can get it in 15w.30 10w.30 and this one bollow with the spec hope this lets you guys see?
Mobilfluid 424 Tractor Lubricant
Call for Pricing
Mobilfluid 424 is an extra high performance multipurpose tractor lubricant engineered to meet or exceed transmission and hydraulic fluid requirements. The advanced technology in Mobilfluid 424 is designed to optimise the performance of agricultural and commercial tractors operating in a wide range of environments and conditions. Mobilfluid 424 combines select base oils and an advanced additive package to deliver the varied lubricant performance properties required in severe duty applications of agricultural and construction equipment drive trains. It is particularly well suited for reducing wet brake and Power Take-Off (PTO) chatter.
Features and Benefits
Next generation technology has vastly improved the performance capabilities of heavy-duty equipment in terms of load, speed, control, and reliability through innovative power train designs. These designs have markedly changed and increased the requirements of power train fluids to deliver higher levels of performance and productivity while reducing operating costs. Friction control, wear protection, thermal stability, shear stability, rust and corrosion protection, and pumpability are features that must be optimally balanced to provide extended clutch life, maximum drawbar loading, and maintain operations on uneven terrain over a wide range of ambient temperatures. Mobilfluid 424 delivers exceptional performance in today's power train transmissions, drive axles, clutches, PTOs and hydraulic systems. The key benefits include:
Features
Advantages and Potential Benefits
Enhanced frictional properties Optimised clutch and PTO performance
Improved wet brake and PTO chatter control
Compatible with latest clutch materials and elastomers Longer clutch life and reduced leakage
High viscosity index and shear stability Consistent operating response
Excellent protection against rust, corrosion and yellow metal etching Protects equipment in wet or humid environments and prevents premature wear
Excellent low temperature properties Responsive operation and effective lubrication in cold weather applications
Strong anti-wear and extreme pressure properties Reduces wear, extends equipment life, and reduces maintenance costs
Excellent thermal and oxidation stability Reduces deposits, extends seal life, and increases service life of equipment and lubricant
Multipurpose capability Simplifies inventory and reduces misapplication problems
Good filterability Keeps systems clean and operating smoothly
Applications
Heavy-duty transmissions, differentials, final drives, hydraulic systems, power steering systems, wet brakes, PTOs and hydrostatic drives
Recommended in off-highway industries including: agriculture, construction, and quarrying
Recommended for top-up and refill of systems
Suitable for commercial transmission applications requiring Type A (Suffix A), Dexron and Type F fluids. Do not use in passenger car automatic transmissions
May be used in applications requiring API GL-4 or SAE 80W grade lubricants in all gear applications except hypoid gear designs
Outstanding replacement for engine oils recommended for hydraulic and transmission systems
Specifications and Approvals
Mobilfluid 424 meets or exceeds the following industry and builder specifications:
API GL-4 X
Ford New Holland FNHA-2-C-201.00 X
Kubota UDT X
Volvo WB 101/BM X
CNH MAT 3525 X
Mobilfluid 424 is recommended for use in applications requiring:
Allison C-4 (Agriculture Applications Only) X
Vickers 35VQ25 X
Caterpillar TO-2 X
Denison HF-0, HF-1,HF-2 (Pumps Only) X
Ford New Holland ESN-M2C134-D X
J. I. Case MS 1204-07/09 X
Massey Ferguson MF 1135, 1139, 1141 X
UTTO X
AGCO Powerfluid 821 XL X
John Deere J20C X
Click here for the Mobilfluid 424 Technical Data Sheet
Ask a question about this product
You may also be interested in this/these product(s)
SUTO 10W/30w.30 and this mobilone shows the spec,
/ yanmar ym1500 update #37
Yep you got me...???? I know that, dont know what i was thinking?? I did the clasic thing everyone who dont know about oil does.. I know when its cold it acts as the first number then as the second when hot, brain fart i guess.
o i would not have known less the guy told me at the farm but it will save having two cans of oil lying about when one make will do . hope you can get it in the usa too? but thanks for the help i got the seal ordered too. will let you know how the fitting goes . thanks
/ yanmar ym1500 update #39
Well its not to big a deal. The UTF fluid we use is cheaper than engine oil at $35-45 for 5 gallons. I buy Rotella deisel oil by shell for around $13-14 gallon. Any extra from changes goes into small engines etc. Its not just sitting around forever.
o thats a good price you are lucky with fuel and oil prices for sure . will let you know the price when i get a drum . thanks
JOHN DEERE 4052M TRACTOR (A65057)
JOHN DEERE 4052M...
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
2006 FREIGHTLINER CST120 STAND UP SLEEPER (A67714)
2006 FREIGHTLINER...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2015 CHEVROLET SILVERADO 1500 (INOPERABLE) (A67714)
2015 CHEVROLET...
2025 JMR Stump Bucket Mini Skid Steer Attachment (A66734)
2025 JMR Stump...
