dodge man
Super Star Member
I must be living right, I've been a homeowner for over 20 years, and I think I've only replaced the guts to a toilet once. The problem wasn't the flapper either, but the valve.
NOPE i am not confused about anything, this flapper is allegedly adjustable to control the amount of water released from the tank during a flush..
Brian
Per the linked website, it states "•Dials to adjust volume for a custom flush."
Did it have instructions on how to "dial"?
To lower the water level, just bend the rod that holds the float (spherical plastic thing) to the flush valve. A little bend can do the job...and you can always bend it more, if necessary.
QUESTION FOR EVERYONE - do your toilets completely empty the tank on each flush?
Brian
DO what i said and Fix your float so that it dosent fill all the way up. You either bend the rod(down) if its the round type float or you adjust the fkoat if its a verticle float by reducing the height of the fill valve depending upon model.
Sorry i opened the page and ate dinner and watched tv so i did not see any of the posts till i posted and you pointed out the activity.
Me i like the higher water consumption. The new toilets dont seem to flush well. But i guess one designed to flush 1.6 wont flush any better with 2 gals?
Is the fill valve you have designed for a low flow toilet?
In the long run is it a big deal? Are you worried cause your water is really expensive or worried about the extra load on a septic system?
Water is sold by the thousand gallons and my water only costs $3/thousand. so if a toilet is flushed 5x per day your using an extra 150 gallons a month or if you flush the toilet 15x per day your only using an extra 450 gallons a day. Even at water 2x as expensive as mine your only looking at what $3 month.
but I may try to put something in the tank to take up about 1/2 gallon of space..
The higher the water in the tank, the more pressure you will have in the bowl when the toilet is flushed so, leaving water in the tank makes sense ( .433 psi per foot). I just don't know how the flapper can regulate the water level or the amount of water that leaves the toilet.
The last flapper I bought (a couple of weeks ago), did not come with a seat, it just slid over the fill tube. It seems to me the higher you lift the flapper, the more water leaves the tank. So lengthening the chain might be the ticket. :confused3:
As long as toilets have been around and as simple as they are, you would think there would be no mystery's here.ullinghair:
Roy - are your toiled the 1.6 gpf or the older version?
I just adjusted the water level in the tank - BUT the lowed i could adjust it was about <2" below the old water level - so it is still using well over 2 gallons per flush..
this is the type of fill valve we have, so it only has limited adjustment available
Toilet Fill Valve from Fluidmaster | The Home Depot - Model#: 400ARP25
Does the flapper have a void in the lower part or part that winds up in the flush valve? That is supposed to lift the flapper as it fills with air when the flapper is down. As the flapper rises it fills with water and falls, in the mean time the water is moving into the bowl.
I don't see how you can adjust this....other than changing the pivot point on the flapper. Seems like if you raise the pivot the flapper would fill faster......
Are you sure that the little tube that sticks down into the flush breather column does not go so far down into it that it is below your fill water level? If it is it can siphon water from the tank into the column and thus the bowl. It could be this rather than an actual leak at the flapper.We have been in our house (built new) for 6 yrs in October.. So far I have already replaced the toilet flappers in 2 commodes at least once, maybe twice.. Now they are both leaking again (very slightly, but they are leaking)..
Why do they leak?
What is the best replacement for them?
Last time I bought 'adjustable flush' flappers from Lowes - they had an adjustment to control the amount of water used during a flush.. On one commode I was able to get it set so you it only used about 1/3 to 1/4 of the water in the tank to flush and still get a complete flush.. On the other toilet (same style, just a handicap height) will empty the entire bowl on every flush no mater how i adjusted it OR you didnt get a complete flush..
Suggestions on a good/better flapper?
Suggestions on a better 'flapper system' to just replace the entire ring/flapper system.
Brian
