wood staining
/ wood staining #1
swick1
WV
John Deere 1026R
I know this isn't tractor related but I need some help. My first son is coming into this world in November and I found a solid wood wardrobe for him. The finish is coming off and I would like to strip it off and stain it again. First question: how do I clean it up?
Second question: what should I seal it with? I want it to be slick to the touch and water resistant.
Thanks!
/ wood staining #2
Sorry I can't help, but congrats on the new son. We have a baby coming next month and it's our first too.
/ wood staining #3
Thanks!
What type of finish (stain, paint)
1.
If stain you can sand down and re-stain (probably not what you want to hear)
Paint ; stripper, heat gun, sanding
2. A urethane should provide a nice hard finish while being water resistant
You could always ask on woodworking web
/ wood staining
It is stained and varnished now. I want to refinish the surface where it looks like the varnish is bubbling up. I was going to strip it chemically and lightly sand it, then re-stain to get an even coat and coat it with urethane. Is this correct?
/ wood staining #5
I'd use paint stripper, and then sand it with a medium grit paper and then finer and finer. Find a hidden spot to test the new stain. Then a few coats of varnish or top coat and it should be good for your life time and most of you childs life time.
Wedge
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
2015 JOHN DEERE 544K WHEEL LOADER (A65056)
2015 JOHN DEERE...
2022 BOBCAT T870 SKID STEER (A65056)
2022 BOBCAT T870...
300 GAL WATER TANK (A68842)
300 GAL WATER TANK...
2020 CATERPILLER 326 EXCAVATOR (A65053)
2020 CATERPILLER...
2006 FORD E350 CARGO VAN (A66091)
2006 FORD E350...
