4 IN 1 FEL
/ 4 IN 1 FEL #2
Maybe . One joy stick for four functions. Up, down, dump and curl load.
/ 4 IN 1 FEL #5
I lift with chains all the time.
Be careful not to have the chains too long if you are going to move the item. It will swing in the direction of travel and can dent your grill.
/ 4 IN 1 FEL #6
you can weld on hooks, or bolt on hooks. for chains. normally at least 2, one on each end, across the top of a bucket. some folks go for 3. the extra one in the middle along the top of bucket.
have used chains to lift many things. when something is delicate. i generally tie a rope around the object and let someone else walk along, loosely holding rope. to help keep things from swinging back into the tractor.
/ 4 IN 1 FEL
Surely there must be a better way to use the FEL to lift items and reduce the swing apart from chains and ropes on hooks. Any inventors out there? lol
/ 4 IN 1 FEL #8
if the item is like a fridge, or freezer, or desk or other furniture, i am moving off of trailer and up to house. ya i will tie a rope to each one to prevent swinging from happening all together.
but if i am carrying a log. or something i really could care less about. and it starts to swing. i will stop tractor and just drop the item right to the ground. hopefully not banging it up against tractor before i am able to stop the really ugly swinging.
like curely dave noted, keep chains short. as they wrap over the edge of bucket and down onto the object. no need to re-invent a childs play set with swings on it.
/ 4 IN 1 FEL #9
Of course there is a better way. Get a set of forks that interchange with the bucket. Now you have a real lifting machine.
But lifting anything with a built-in hard point, will go better with chains.
/ 4 IN 1 FEL #11
Something else to consider..
A 4in1 is usually much heavier than a standard bucket so its important to have plenty of weight at the back so you don't lose too much rear wheel traction. You'll notice this most when you are using the 4in1 as a dozer. I have a backhoe on the back so my rear ballast is good. Without it I'd go nowhere. Then again, yours is a pretty good size tractor so you might not have too many worries about this.
/ 4 IN 1 FEL #12
Most forks also have a lifting eye or at least my Bradco Q/A ones due. So basically anything I can not get on the forks I can also lift with a chain Etc.
/ 4 IN 1 FEL
Somewhere i have seen a hook on a backplate which gets attached onto the front quick attack FEL arms ...but i cant seem to locate its name or who sells it...can anyone steer me in trying to find and have a look at it?
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
2013 VOLVO A25F 6X6 OFF ROAD DUMP TRUCK (A62129)
2013 VOLVO A25F...
10ft Cattle Panels (A64047)
10ft Cattle Panels...
2006 FRAC TANK 500BBL WHEELED (A63569)
2006 FRAC TANK...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
Holly 12 Row Harrow (A64047)
Holly 12 Row...
