4 IN 1 FEL
   / 4 IN 1 FEL #11
Something else to consider..
A 4in1 is usually much heavier than a standard bucket so its important to have plenty of weight at the back so you don't lose too much rear wheel traction. You'll notice this most when you are using the 4in1 as a dozer. I have a backhoe on the back so my rear ballast is good. Without it I'd go nowhere. Then again, yours is a pretty good size tractor so you might not have too many worries about this.
   / 4 IN 1 FEL #12
Of course there is a better way. Get a set of forks that interchange with the bucket. Now you have a real lifting machine.
But lifting anything with a built-in hard point, will go better with chains.
Most forks also have a lifting eye or at least my Bradco Q/A ones due. So basically anything I can not get on the forks I can also lift with a chain Etc.
   / 4 IN 1 FEL
Somewhere i have seen a hook on a backplate which gets attached onto the front quick attack FEL arms ...but i cant seem to locate its name or who sells it...can anyone steer me in trying to find and have a look at it?
Mini Skid-Steer Hydraulic Skeleton Grapple Bucket (New/Unused) (A59225)
Mini Skid-Steer...
2012 Infiniti G25 Sedan (A56859)
2012 Infiniti G25...
2263 (A58376)
2263 (A58376)
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2011 TIGER CHEMISE GOOSENECK (A58216)
2011 TIGER CHEMISE...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
