Snow Attachments Best chains for 5045E?
/ Best chains for 5045E? #1
vtsnowedin
Elite Member
central Vermont
John Deere 5045E
One of the main jobs my new 5045E will have to do is move snow on a road with 12% grades and break out roads for sugaring in the spring. A good set of chains are a must and I'm starting to shop for them now to not leave it to the last minute. I've searched through the forum and have found some interesting ideas and suppliers but not an exact match. especially on the front 9.5x24 front tires.
Dose anyone have a 50xxE chained up and or have any opinions about what chains to buy?
/ Best chains for 5045E? #2
Yes. Just about any chains you buy will make a difference. I have chains on all four tires The rears on mine are the size of your fronts and I had no trouble getting them from Tire chains.com. They are nothing special but 4 link ladder chains that make the tractor almost unstoppable in the snow.
/ Best chains for 5045E? #3
Are any of the roads paved? I'm also looking for chains for the winter time and I think I'm going to go with the very aggressive studded ice chains as I won't be using them on pavement.
I am five miles from the nearest paved road so that is not a problem. Hard traveled on ice that then gets rained on is the thing I need to be able to beat. I'm thinking studded chains in some version of the H or diamond pattern.
I'll check out Tire chains.com thanks for the tip.
/ Best chains for 5045E? #6
Regular chains grip very well on ice as well. Vlink chains are just about as effective as studded and much cheaper.
Tirechain.com does have their V-bar duo grip that would do pretty well and fit both front and rears. About as much for four as Labonville wants for the two rears.
duo grip v bar tire chains
/ Best chains for 5045E? #8
VT look at the gap between links on the Duo Grips. My personal preference would be regular ladder chains with the Vlinks in either 2 or 4 link. Two link if you were only going to do the rears otherwise 4 link would do you fine if on all 4's.
I'm not following you here. I am aware of the gaps the H pattern gives and that sliding sensation you can get when you are between the chains. This was a real problem with my last set of chains which were the Canadian ring type. Going down the road with them was like having ten sided tires and I had to re-weld up corks on the rings to get them to stick into the ice. A grade five bolt welded on and cut off at an angle, four to six per ring worked pretty well.
Regular ladder chains just drop between the lugs of R1 tires and are useless as the chain is not in contact with the ice. What you mean by two or four link is probably where I don't follow you. Just what do those look like?
/ Best chains for 5045E? #10
Ahh the big myth prevails. Ladder chains drop between only some lugs on the top of the tire only. They actually fall below the lugs as the tire comes around and they are the first things to hit the ground. If you are looking for smoothness, then you need 2 link meaning there is a cross chain at every second link. This is a picture of 4 link and as you can see, the chain links make first ground contact. If they were useless, then my traction would never have increased big time. As you can see my chains are on loosely with no chain keepers and yes they still stay on.
/ Best chains for 5045E? #11
If you are insistent on the duo grips, what Tire Chains.com may do for you for added cost , is to put a cross chain between the gather links (called duo ladder). This would smooth out the ride somewhat. Believe me with just ladder chains, you'll pick up a ton of traction.
I'm not trying to pick a fight with you or anyone else.
Now to discuss , civilly the issue of what chains work the best.
Your picture shows a heavy gage wire chain, I'm guessing 3/8" chain size. they of course work pretty well when the cross link is on the ice and the tire tread lug is on top of the chain. But if you have new tires with deep cross lugs and even one cross chain falls in front of a cross tire lug then that cross chain has no weight pressing it into the ice and the gap between having traction and getting it back may be two feet of tire rotation. This can be quite a pucker factor if your sliding towards an edge and hitting the brakes almost always assures that the tires will stop between cross links that are gripping and allowing the maximum sideways slide.
I've played this game and don't much care for it. I want a set of chains that have ice picks in the ice 100 percent of the time and can hold the weight of the tractor and implement right where it is if I push in the clutch.
/ Best chains for 5045E? #13
Never took it as a disagreement VT and of course you need to do what you think is correct for you to give you all the security in the seat you are looking for. I am merely stating my opinion in an attempt for you to be as cost efficient as possible and get what you are looking for. I have seen 2 link ladder chains on deep lugged ags. Yes you are correct: this is 3/8th wire they use for the chains and as a result, there is much contact between ground and chains. Google "tire chains on tractors" then go to "images" at the top. You will see a plethora of tractor tires with all kinds of chains including ags. Here you can judge for yourself. With the addition of the vbars, I do think you will have all the lateral traction you need. I feel you will get what you are looking for with 2 link vbar chains. If you are skeptical, then go to the duo ladder chains with vbars. The extra cross chain on the duo's will smooth out the ride. I have been on some of those hills around Ludlow VT and if your lay of the land is anything like there, I do not quibble with you in the least for wanting excellent traction.
Never took it as a disagreement VT ...
... I feel you will get what you are looking for with 2 link vbar chains. If you are skeptical, then go to the duo ladder chains with vbars. The extra cross chain on the duo's will smooth out the ride. I have been on some of those hills around Ludlow VT and if your lay of the land is anything like there, I do not quibble with you in the least for wanting excellent traction.
Just trying to keep it friendly. ;)
And yes I have all the hills anyone will want and even with Velcro tires/chains there are a lot of places on my land where a tractor will never go if I am on the seat.
This last winter one of my neighbors got stuck on the private road that runs through my woods and serves the back four house lots. Another of those neighbors came down to help with his NH 110HP (I think) cab tractor that he had double ring chains on , on just the rears. When he went to stop he put the bucket down but the edge just acted like a skate and the front of his tractor skated down hill until the GMC back quarter panel stopped it. GMC back quarter panels do not make good bumper cushions.
/ Best chains for 5045E? #15
I have Aqualine Talons. No disappointments at all with these chains. Not for asphalt driveways. Not good on a concrete garage floor. I park them on 3/4" thick horse mats on my concrete garage floor. Tellefstall chains are very good also.
Tellefsdal Kjetting - Nyheter
What your picture shows is in line with what I want. Got to weigh the cost vs. performance and see if anyone sells as good for less. Where did you get the "Aqualine Talons."
/ Best chains for 5045E? #17
/ Best chains for 5045E? #18
Double ring chains are not recommended for plowing snow.
I've seen that but my neighbor doesn't consult with me on his purchases. The real problem he had was having no front chains on at all. That and it was raining at 34 degrees on a hard ice road and a twelve percent grade. It was so slippery you couldn't walk across the road without hanging on to something. Of course the other neighbor could have chosen that day to not be a complete Dingy and stayed safe at home by a warm fire.
/ Best chains for 5045E? #20
Aquiline Talon studded chains are great for snow removal applications, same as Trygg or SMT studded chain.
Serious snow is real close to home in Canada! With that being said, some prefer SMT 3/8 chain diameter; others rather have Tryyg 7mm (smaller & lighter ). They both work very well. However, sometime dear neighbours will buy another type of tractor tire chain and will dearly regret them! Such as double ring type of chain.
By no mean, just like VT, I don't want to star a fuss about it. But standard cross chains (simple or double) are no match for Aquiline, Tryyg or SMT studded chain. Double cross chain back home are better than no chain, but in a step hill, or while turning with your front mount snow blower, you will be backing all the time up to reposition yourself because you will lose traction and direction. Some situation will ask for chains on all four tires.
Otherwise, "serious snow removal + tractor+ no chain = a bit odd". I guess studded chains are for people who want to use their snow blower equipment in regard to the full capacity of their tractor. I have a good friend with a BX2029, with no chain. He will not get out of his paved backyard. He got stuck too often, with his tire (R4 - 50% used). Someone might say the guy dont want to help out?! Fewer hassles with others with steep driveway?
The guy just in front of my house got the double link, good improvement sure, but still slippery. At first I did the same move, got the double link chain, I took them back and exchanged them for Trygg studded chain (excellent dealer!) .
It's a whole new ball game with the appropriate chains.
Happy snow removal!
Phil
(4) 205/75R15 TIRES W/ 4 LUG WHEELS (A64281)
(4) 205/75R15...
1988 23ft Stealth Craft Boat w 1988 Arrow 22ft Boat Trailer (A61574)
1988 23ft Stealth...
2016 Mercedes-Benz 300SLK Coupe (A61574)
2016 Mercedes-Benz...
2025 Quick Attach Coupler Mini Excavator Attachment (A61572)
2025 Quick Attach...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - 2018 - Tier 2 - Pump Takeout (A63689)
Kubota V3600-T-E2...
