Best Hydraulic Top Link???
   / Best Hydraulic Top Link??? #21
Curious as why some of you guys like the 3rd function so much? Do you really feel that you need be doing 2 or 3 functions all at the same time? In 7 years of use I have not needed to curl and close my grapple at exactly the same time. How do you guys that have the 3rd function control the flow? Hit the button on-off-on-off a bunch of times? :confused: I have sold a few restrictor fittings to guys with the 3rd function valves, but then you only have one speed of operation, :( although at least it is manageable. :thumbsup:
Just curious. ;)
   / Best Hydraulic Top Link??? #22
Yes, if you want short hoses, that is what you will get. You need to have the hoses have a loop in them. Can you do that with the shorter hoses? The top link comes with 90* fittings, those fittings really should be pointing backwards towards the implement.
Here's how another member has hit top link configured with 24" and 30" hoses (exact same tractor I'm getting):
Looks like plenty of slack to me.
Green is no problem, but will be an additional cost of what the JD dealer gets for their paint.
Ok, sounds great. Can you get me a total price, including the in-line restrictor?
   / Best Hydraulic Top Link??? #23
I have a CCM TnT... with no restrictors. Now I learn about restrictors, the remotes are way way too sensitive on the TnT setup I have now. I was thinking all those with TnT and box blades must have Dog like skills to effectively use a box to flat the ground or crown a road, now I know better!
   / Best Hydraulic Top Link??? #24
Hyperlink you provided to PCLAUSON is corrupt Brian, here's a correction: click here
//greg//
   / Best Hydraulic Top Link??? #25
Wish I had it too. Grapple buckets and 4-in-1 buckets are likely plumbed pretty much the same. But cuz JD outfitted my 3720 with a pair of diverters, I have to hit an electric switch everytime I want to use the clamshell. With that switch in position 1, the flow is diverted forward to lift/curl. But since the clamshell cylinders are plugged into a pair in the rear, I have to hit the electric switch to send flow to the rear for the clamshell. PITA. The other rear pair is usually dedicated to the HTL, that's not such a big deal. But when I'm doing loader work, using an electric switch to "turn on" the clamshell sucks.
//greg//
   / Best Hydraulic Top Link??? #26
I had it on my previous tractor and will have it on this new one. I found that having the 3rd function right there on the loader joystick was very convenient when using a grapple. It just seemed very intuitive and I would think having to remove your right hand to toggle a switch all the time would get old after a while.
   / Best Hydraulic Top Link??? #27
Thanks Greg!
That does look like a decent kit, but if I went that route, I think I would do it a little bit different (like get a JD momentary 2 way toggle switch to fit one of the existing blanks in the cab), and likely plumb it into the PB circuit and use the toggle switch to control the HTL directly.
   / Best Hydraulic Top Link??? #28
I've got the CCM with a restrictor fitting. Don't know if it's the best ot not.. I'm sure they're all pretty good. The restrictor allows me to feather the movement perfectly.
   / Best Hydraulic Top Link??? #29
Just curious. ;)
I constantly use 2 functions on the loader with the joystick on my 2030. I connected my grapple to a rear SCV and have to use that lever for it.
I need to make different mounts for the grapple to be able to use it on the 6415. Since I can't mount the grapple on the 6415 yet I can't comment on how well the third function button on the joystick will work for it. Opening it should not be a problem, all I want it to do is dump. I don't feather it when using the 2030, I just push the lever to detent and when the tines are closed the lever jumps back to center position. Picking up brush and logs is not precision work.
I plan to try the joystick third function when I get hydraulic toplink. I will be using 1/4" hoses. If that's not precise enough, I'll add restrictors. If that fails I'll move the hoses over to a rear remote that has flow control built in.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A56435)
2023 Kubota...
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A56857)
2025 GIYI GY-ZWB...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
2012 Ford F-550 Ext. Cab Stellar EC3200 1.5 Ton Crane Utility Flatbed Truck (A55973)
2012 Ford F-550...
BUNDLE OF 6" X 12" BUILDING PURLIN (A54757)
BUNDLE OF 6" X 12"...
