Finish Mower Mounted on Front?
/ Finish Mower Mounted on Front? #1
dieselscout80
Elite Member
South Carolina
New Holland TC45DA
Could a finish mower be reversed and mounted on the of a tractor?
I know a driveshaft would have to be made to connect to my pto at rear of tractor.
If a winch was used to raise any lower it I would think it would follow the ground.
/ Finish Mower Mounted on Front? #2
If you have the hyd GPM's and pressure, you can drive a hyd motor driven deck.
You could also add a hyd motor to a gear box and move the 3pt finish mower to the front.
Here is a hyd driven deck, from Power-Trac.
8 GPM hyd flow.
Finish mower. --------- Rough cut mower.
/ Finish Mower Mounted on Front? #3
A number of old model Gravley garden tractors had a front mower option.
/ Finish Mower Mounted on Front? #4
There is a company the sells a front mount that adapts the three point equipment to run on the front, and down speeds a mid mount pto to rear mount pto speeds. It's pretty speedy, but it's available. I'll see if I can find the link.
Laforge Front 3-Point Systems | Front PTO
That's one of them, there is another as well.
/ Finish Mower Mounted on Front? #5
I have played with the idea. For a number of years I mowed with a five foot Arts Way PTO deck which I converted to run off a 16 hp Briggs Van Gard twin that sat on top of it. This was needed as my little home-built tractor did not have a PTO or high output hydrauilcs.
While mowing I would often day dream about mounting it on the frt.. Always figured if I did this I would use a electric clutch rather then the twin belt with hand tensioner.
Sure would be nice to have it on frt. where you could see it.
/ Finish Mower Mounted on Front? #6
8 GPM hyd flow.
JJ
What kind of power would be needed to provide 8gpm?
