Need Help for my Mother
/ Need Help for my Mother #1
eonblue
Cookville, TN
none yet
So do a good job!!! :D
Alright, she's 50ish but very active and strong. She's a country girl and always will be! She's moved in with my grandmother after my grandfather passed away and is taking care of the property herself, so I want to make sure she makes a good investment for the next 15 years.
The property is around 3ish acres. Half the property is fairly smooth and will be easily mowed, but the other half is rough to very rough and includes some pretty heinous slopes. She's not concerned with niceties or going very fast. In fact she probably wouldn't go terribly fast even if she had the capability. She's not opposed to a zero turn, but she is a little scared about sliding around because as I stated, there's some pretty good hills. The first and foremost concern is reliability and longevity. 15 minutes away she has an Exmark and Husq dealer at the local coop, 30 minutes away she has Cub Cadet, Bad Boy, and probably a slew of other options.
She was looking at a 1700 dollar 46 inch deck Cub Cadet 1000 series, but the more I researched, the more it seemed like those are built for the suburban 1/4 acre home owner with relatively well formed and manicured lawns. This is not the setting she will be mowing in, so I decided to come here and get ya'lls expert opinions. I'd appreciate any help you guys could provide to get me pointed in the right direction and if you need any more information that I've failed to provide, please let me know. She's actually looking to purchase something this weekend because her 15 yr old John Deer has seen its last lawn and the grass ain't gettin any shorter.
Ohh, I forgot one crucial bit of information. Budget. She's WANTS to stay around 2 grand, but she was previously looking at a 4k Exmark and if I point her in that direction, she has the opportunity at the moment to make that kind of investment and she will, if I feel thats the best route for her.
So, lets call her budget 4500 firm. She is NOT wealthy at all so this is a very large investment for her.
Also, I thought I'd mention that as far as cut quality, we're looking for utilitarian here. Not trying to look professional at all, just keeping the grass short. Thats it.
/ Need Help for my Mother #3
Zero turns do not like to stay on steep hills sideways. Do fairly well straight up and down. All depends on angle of the hill. Once they start sliding or spinning the drive wheels you and the mower are going where ever the mower wants to go. I have rode mine off in ditches a few times. Had to pull it out with truck once and lift it out with front end loader once. Been very lucky it did not turn over. Just my opinion. That being said, I do like my zero turn and once I got used to it and know what to expect I do go up and down slopes and still put it on some hills sideways but try to be prepared for the ride if it happens to slide. Never had it raise up the front end going up hill but it is very light in the front end.
/ Need Help for my Mother #4
Welcome to TBN!
Personally I would look at a garden tractor series, John Deere x300 or 500 series, Cub Cadet 2000 or 3000 series as they likely will be most comfortable especially on wet slopes.
These will run $4-6K new but are built well and should last 15-20 years if taken care of.
I have a Ferris IS2000 ZTR with suspension and love it over rough ground - rides much nicer than my Cub Cadet 1811. But if the slopes are more than 15* and if there is no "bailout" place at the bottom like a flat spot then I'd be wary of a ZTR especially if its wet/damp grass.
It seems like she won't be in a hurry to get this done, or want to speed through the cutting then the standard garden tractor should be fine.
I am sure you will get other opinions too, but one way to do this is to have one of hte dealers bring a ZTR by to test out - then she can make her own decision and "comfort factor" on a ZTR - she already has experience on the rider I presume..
Good luck..
Thanks for the replies fellas.
Hmm. There is one particular spot where I'd say the slope is easily 15* and it ends with about a 6 foot near verticle drop into a ditch. I told her I didn't really think she should take ANY mower over there to be honest other than a push. She actually got thrown down into the ditch by the John Deer. She said she could have been seriously injured, but she's as hard headed as I am. :D
That made her very cautious though and to be honest, I am sort of leaning toward the Lawn Tractor myself because there's no shortage of fairly steep inclines on the property. What is it btw that makes Lawn Tractors better on hills? Weight? Or the fact that its got 4 "real" wheels?
Is the general consensus here that my inclination was correct as far as staying away from the 1700 dollar deals at Lowes etc?
/ Need Help for my Mother #6
The biggest factor is the steering on a GT - on the ZTR the steering and braking is with hydros on the rear wheels.
So once a wheel breaks loose on a ZTR on a slope you dont choose the direction to go like with front wheel steering, you try to control by levers on the hydro..
Yes, I would steer her away from Box store machines - you can find a decent JD x300 for around $3-3.5K I think and a Cub with shaft drive for about the same.
Look for decent used machines too in the same size/type - they are out there with a 100 or so hrs I have seen for in the $2K range.
/ Need Help for my Mother #7
My problem is getting too aggressive with the controls when I lose traction. I'm learning that small movements of the controls work better than trying to power back to a certain direction. That only produces more wheel spin. Turning a steering wheel doesn't apply more power to the driving wheels.
You seem to be leaning toward a garden tractor and if it were my mom I would go that same direction. You didn't say why the Deere was no longer viable but unless it's a rust bucket why couldn't it just be refurbished? If it's a real JD mower then that could easily give another 15 years for probably less than a used one.
If that's not an option then check Craigs' List and the local Deere dealer for a gently used mower. There are lots of good deals out there, I got my current mower 2 years ago, it was 2 years old, and had less than 100hrs. on it. I think it's going to last me a good long time.
/ Need Help for my Mother #8
The ZTR I had was just plain more work to drive on a side hill. The front was always wanting to go down the hill so you were constantly steering against the hill. I was a ball to drive on the flat though. Definately check craig's list lots of good low use stuff there most of the time. Be sure to get her a hydrostatic. Much easier to drive. I prefer the ones with a lever control to a foot control. I am sure that will start a discussion.:)
Hey, thanks for the input. The current Deere is approximately 15-20 years old. It was bought new and was very expensive at the time. I am not mechanically inclined unfortunately, but she's had it fixed 5-6 times and now it wont start. I think she's tired of putting money into it and due to a small inheritance and her situation, I think she want's to invest in something thats going to last her a good long while again. That being said, Im not sure on the model number, history, or expected longevity.
I have looked at the trigreen dealer for a used x500, but again, since Im not mechanically inclined Im kind of scared to go that route. Do they "warranty" those things at all do you know?
/ Need Help for my Mother #10
Eon,
If she has a JD now 15-20 Yrs old it would be good to know the model since you say they paid a good amount it will still have value if its in decent condition.
If its the garden tractor or 318 series, 260 series or similar and running is worth $800-1200 maybe depending on condition. If its the LX series - lawn mower then its less.
So I would spend a little to get it running and working to sell and offset the new machine cost. It could be as simple as a low battery, or fuel issue but if its not running you will get very little.
/ Need Help for my Mother #11
Go with the EXmark, that is the best zero turn you can get...:thumbsup:
Hmm, since she has a Cub dealer near her, would the Z-Force S be another option? I've read a good many accounts that the handling on hills is much better than a lap bar ZRT. That just hype? Is there some other reason I should check the S models off the list of options?
/ Need Help for my Mother #13
I know what you need, a 4 wheel drive sub compact tractor. They handle well on the hills, plus they have a seat belt and a roll bar. The problem is they are outside your budget brand new, but you might find one used with some hours on it for your budget. They look a lot like a riding mower, but are larger and built much tougher. They are also usually water cooled and a diesel.
My property is also rough and hilly in places, and I used a regular riding mower for years. After going for a few dangerous rides, I decided it was time to invest in something more durable and safer.
/ Need Help for my Mother #14
Eon,
+1.
If it was an "expensive" Deere years ago, it will have some value regardless of condition. I would trade it in for a new Deere at a dealer or fix it one last time and sell it in working condition.
/ Need Help for my Mother #15
I got a 1000 series Cub that I got at HD. I have some steep areas but mostly uneven ground. I have replaced the battery and the blades due to ground strikes, as I said it's fairly uneven. The steep areas don't worry me any more as I have had the machine 8 years now. and have not rolled it yet, though first couple times I took it pretty easy still runs like a champ.
/ Need Help for my Mother #16
safety for your moms sake would steer me towards a 4 wheel drive small sub compact tractor such as a JD2305/1026R or Kubota 1860/2360,etc. I believe the JD x700 series are full time four wheel drive. These make as much of difference stopping as well as starting on a hill. Zero turns are fast and fun but will be too much of a handful on this property and she could get seriously hurt/maimed .It takes a seasoned veteran to be able to control one in that situation...but they will still loose control from time to time. I know its out of the budget,but her safety should trump dollars....besides one of subcompacts will probably outlast her and you when you inherit it . She'll be able to till/garden, clean up brush with a rake/grapple on the front end loader,grind up limbs/branches with a Wallenstein cutter....even dig post holes...or use the front end loader to carry groceries into the house:laughing:good luck and keep us posted:thumbsup:
I strongly suggest staying away from the big box store lawn mowers,they wont last notime
/ Need Help for my Mother #17
Why mow the rough to very rough 1.5 acres with heinous slopes?
The rough stuff is flat and separate from the heinous slopes, though, Im pretty sure there ARE areas they could and maybe should just let go. Its just always been like that and my Grandmother is pretty set in her ways. :D
Alright guys, so she feels pretty good about either an x320 or a x500. Last question. Does John Deere wiggle on the price or does the manufacturer pretty much lock that down? Will they throw in free attachments in lieu of coming down on the price? Any tips there?
/ Need Help for my Mother #20
Eon,
Maybe we are being to invasive, but if she has a 15-20 Yr Old JD machine that was expensive when purchased it has "value" if you are interested in getting the "best deal" leverage with what you have - but you haven't provided that part of the puzzle.
The same thing applies to your statement "throw in free attachments" what does she need to do and which ones? It really depends on what she NEEDS and what does she WANT.
Its really frustratiing to see you try to make decisions for your mom without realy knowing her end goal/objective while she seems to know what she wants.
Bottom lne you cant negotiate what you dont know you need. My advice was to get the existing machine running and trade it for a new one..
Good luck from here, just spend the money - its not mine, seems to apply.
Carl
DELTA  FLARE STACK TRAILER (A63569)
DELTA FLARE STACK...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56438)
Kuhns AE10 Small...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
Hydraulic rail grinder (A61307)
Hydraulic rail...
2012 John Deere 328D Compact Wheel Loader Skid Steer (A61572)
2012 John Deere...
ATS ME18 Mini Excavator (A64047)
ATS ME18 Mini...
