"No digging with Kioti's"?
/ "No digging with Kioti's"? #1
CPM
QLD
Looking
Just wondering if anyone has done any light digging with their tractor without ill effect?
I have a driveway a few hundred meters long with some slippage on the banks next to the road. It looks loose enough to me but being a newbie, I'm not sure if this is something a bucket could hande.
I'll be getting a 50hp with a 4in1 and the standard loader - AL43. Is this a big no-no or is some light "digging" acceptable?
/ "No digging with Kioti's"? #2
My DK35SE HST does it ALL! If i have a job to do, we just do it. Think it through and do it. We move a lot of dirt and logs at my place. . .John
/ "No digging with Kioti's"? #3
Even with my little CK20, I can dig and move most dirt. If it's too compacted or clay I could have to break up with box blade to move. You should have no issues.
Have Fun!!
Eddie
/ "No digging with Kioti's"? #4
My DK50 digs JUST FINE.
I love my 50 HP Kioti!:D If you buy one, you will too!:thumbsup:
:confused2: Why isn't this thread in the Kioti area?
David
/ "No digging with Kioti's"? #5
While loaders aren't made for digging you can do if you're careful. Esp so if the earth isn't rocky.
Stay in low with high RPM and while going forward carefully shave 1" or less until you see runoff from the side of the bucket. That will give you almost 3/4 of a bucket. The job is made easier if you have a bucket leveler.
Once the bucket gets a good bit and 1" down or so you level off and continue forward.
It's crude but effective.
That's good to hear. Even with the smaller machines.
Looking forward to having a go!:thumbsup:
In which case, would you get teeth for the bucket?
/ "No digging with Kioti's"? #7
Teeth help with breaking up the dirt while digging. A tooth bar may help in keeping the front edge of the bucket from sagging when you dig. Although, the 4in1 may have a true cutting edge on it. The thing that really bothers me is watching someone slam into a pile thinking they are going to fill their bucket. Go at it in low, about half throttle, and when you get into the pile a little, lift the bucket some and then curl the bucket, with a little practice you will get a full bucket.
So, you'd approach face on, as opposed to driving down the road with only one side of the bucket scraping/digging?
/ "No digging with Kioti's"? #9
It depends on what you are trying to accomplish. But most usually, yes, head on. Wether you drive down the road trying to scrape up material, or if your trying to just shore up the sides of the road, head on is easier on the machine.
/ "No digging with Kioti's"? #10
Not sure what this has to do with owning and operating a Kubota :confused2:
Posted in the wrong forum. Sorry:eek:
If there is a way to change it, I will but thanks for the free advice:thumbsup:
/ "No digging with Kioti's"? #12
You may have to contact a moderator to move it. I don't see a problem doing some light digging with any CUT; if it won't stand up to that I don't want it.
/ "No digging with Kioti's"? #15
You can do light digging like was said go slow.If your going to be digging in clay a tooth bar will help.My tractor is only 20hp and it digs just fine.Take it easy and you will be amazed what you can accomplish.
/ "No digging with Kioti's"? #16
My 18Hp 670 dug & moved 10 yds of red clay. I was able to dig 6 ft into a bank 32 inches deep. Constructed the first RR tie wall today. About 1/2 through I bought a tooth blade in part because the barn and existing fence keeps me from a head on attack.
/www.wrlonginc.com/FTB.htm
I would think the higher HP might provide the power to damage equipment, so a bit more care might be needed. I shaved an inch or two at a time until I hit big rocks, then I used the tooth bar to to pick them out and moved on. Tried to post pictures but the ones on my phone are to hi res.
My mistake when I started was not having a good plan for dumping the dirt. It seemed to grow like popcorn as I dug into the bank.
Go slow, be careful, and enjoy the results.
One additional note check the threads out about ballast boxes and overloading your FEL.
RoN
/ "No digging with Kioti's"? #17
You're kidding? right
No. All the dealers I've spoken to, have a sharp intake of breath and tell you to buy a Bobcat if you want to dig. Apparently, damage is done when hitting rocks on one side.
I know people do use them for light digging but I was wondering how commonplace this is and what experience people had - which brings up another point. Would this affect a warranty?
/ "No digging with Kioti's"? #19
Not sure about Kioti, but I have two Kubotas that will Dig! :thumbsup:
/ "No digging with Kioti's"? #20
Digging, what can I say, yes tractors will dig, They will dig out stumps, and rocks and dig down whole hillsides.. It just takes time and common sense.. can you tear something up? sure, just work smart not stupid. I have dug up many stumps and rocks, and once took the top of of a hillside and moved it about 100 yards to build a shooting berm. Took a while, but it is doable.
I have dug shallow ditches with my Front End Loader plenty of times. It takes coordination and practice but you can dig a long trench 12 to18 inches deep 5 to 6 foot at a time with nothing but your bucket on the FEL. It is easier with a hydrostat tractor than a gear model, but still doable with gear. You can also build a little chain on "shovel" like I did for my FEL to assist you in your digging in a more concentrated area. Good Luck and happy digging:thumbsup:
James K0UA
2012 Ford F-450 4x4 Altec AT200A 30ft Bucket Truck (A61573)
2012 Ford F-450...
2018 Ford Explorer AWD SUV (A61574)
2018 Ford Explorer...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
2008 23ft. Zodiac Hurricane Inflatable RIB with 2007 25ft Myco T/A Aluminum Boat Trailer (A61574)
2008 23ft. Zodiac...
2024 CATERPILLAR 289D3 SKID STEER (A64279)
2024 CATERPILLAR...
Lifts (A61567)
Lifts (A61567)
