mahindra 3510 final drive cap leaking
/ mahindra 3510 final drive cap leaking #1
scrufy12
Mississippi
mahindra/3510
Can any one tell me how to replace the cap on the bottom of the final drive assembly? Can it be remove without taking the entire assembly apart?
/ mahindra 3510 final drive cap leaking #2
Welcome to TBN. :)
/ mahindra 3510 final drive cap leaking #4
You should post in the Mahindra forum for these questions. Yes, you can replace that cap. On my 4110 you remove the 3 bolts and flat plate covering the cap. You can drive a punch or screwdriver thru it with a hammer and pry it out just like a freeze plug - which it is pretty much except that it is rubber coated. Carefully and evenly tap the new one back in and refill the outdrive with 90w.
/ mahindra 3510 final drive cap leaking #5
WELCOME to TBN :)
I moved your thread to the Mahindra Owning/Operating Forum.
My Mahindra is the 2005 new sheet metal model and i don't think there are any bolts to remove. Would I still remove the cap by prying it out with a screwdriver or punch? Sorry about posting the previous comment in the wrong forum.
/ mahindra 3510 final drive cap leaking #8
Your axil is a newer style than Skips, and yes that should just pry out of there, put sealant on the new one and tap it up in.
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
2013 Toro Z Master 3000 Series 52in Zero Turn Commercial Mower (A61567)
2013 Toro Z Master...
John Deere Decorative Metal Sign (A61569)
John Deere...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
