mahindra 3510 final drive cap leaking
   / mahindra 3510 final drive cap leaking #1
scrufy12
Mississippi
mahindra/3510
Can any one tell me how to replace the cap on the bottom of the final drive assembly? Can it be remove without taking the entire assembly apart?
   / mahindra 3510 final drive cap leaking #2
Welcome to TBN. :)
   / mahindra 3510 final drive cap leaking #4
You should post in the Mahindra forum for these questions. Yes, you can replace that cap. On my 4110 you remove the 3 bolts and flat plate covering the cap. You can drive a punch or screwdriver thru it with a hammer and pry it out just like a freeze plug - which it is pretty much except that it is rubber coated. Carefully and evenly tap the new one back in and refill the outdrive with 90w.
   / mahindra 3510 final drive cap leaking #5
WELCOME to TBN :)
I moved your thread to the Mahindra Owning/Operating Forum.
My Mahindra is the 2005 new sheet metal model and i don't think there are any bolts to remove. Would I still remove the cap by prying it out with a screwdriver or punch? Sorry about posting the previous comment in the wrong forum.
Thanks
   / mahindra 3510 final drive cap leaking #8
Your axil is a newer style than Skips, and yes that should just pry out of there, put sealant on the new one and tap it up in.
Deere 9970 Cotton Picker (A51039)
Deere 9970 Cotton...
2003 John Deere 1790 Planter (A50657)
2003 John Deere...
2009 JACK COUNTY 130 BBL VACUUM  TRAILER (A50854)
2009 JACK COUNTY...
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
2018 John Deere 8370R MFWD Tractor (A50657)
2018 John Deere...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A51039)
Kubota BX2680...
