Tractor Restorations
/ Tractor Restorations #21
Well in my expereance it's all about money! I purchased a ford 841 on Ebay and drove all the way from erie pa to past detroit to pick it up it was a little rougher that I thought but so what I wanted to restore it and keep it. I already had the Jubilee and the 621 and this was the same basic tractor with lots of HP when I needed it. Well I used it for the remainder of the first summer and tore it down that winter. First off it had a loader on it but no power sterring so the loader had to go. After tear down I realized the following. The engine was in great condition seemed like it had been done on to long before there wasn't any slop at all that's good except the rear seal liaked so out it came and it got a new clutch at the same time. Some one had dropped something out of the loader and shashed the hood and gas tank, they fixed the hood pretty good so there was not much work there but it needed a new gas tank new because all of the used ones I found had holes in them. The radiator was leaking so I had to ghet a new one also. The breaks wer week and when I took that apart the rear seals needed replaced and I also did all of that. No and on and on, finally done and I have 5K into the tractor. In the interum I bought the Montana new and now I have 5K into a tractor that just sits there. Now the Jubilee needs a new motor because it blew up during the restore of the 841, so I start over because a tractor just isn't a tractor with out an engine. Just buy a new one and get it over!
/ Tractor Restorations #22
For me, it depend upon what condition the tractor is in mechanically. For example, why rebuild the engine if it's in great shape? Same goes for the clutch or whatever else. When I do a restore, I attempt to find a tractor that is mechanically sound, or as closely as possible, and just do only what needs to be done, leaving most of my time, money, and efforts for the best and most original looks I can achieve. Of course, you have to watch what you buy, because some tractors may appear to be in good mechanical condition and turn out to burn you badly. I just got burned on a Ford 2000 I bought. About an hour after I started using it, it started smoking like a mosquito machine, and problems multiplied from there. Needless to say, I abandon the "restore" project and ended up selling the tractor for less than I gave for it.:(
I agree that there is no point in fixing what doesn't need fixed. As for finding a good used tractor, that will likely be a challenge because I've noticed that many sellers go to great lengths to make them look pretty and have little doubt that many would do the same to make them appear to be in good mechanical condition.
/ Tractor Restorations #24
yep.. I'm pleasently surprised when I drag one home and DON'T find as much hidden damage as I THINK is there.
on many units, you can give a good guess as to what you are getting.
sloppy steering, oil pouring out the front while running.
no charge.. etc.. etc.
on some it's an easter egg hunt.
but then.. that's part of the fun too! even if you break a few eggs making the omelette ( egg pun intended! )
/ Tractor Restorations #25
I've had pretty good luck with buying old vehicles / equipment from people who keep good records of the maintenance they've done. No guarantee there aren't any problems but gives an idea what's been done and how well the owner maintains equipment.
/ Tractor Restorations #26
I prefer to buy old iron that's running (maybe not running perfectly, but at least blowing exhaust out of the muffler). But I have my wish list of old tractors that I want in my collection. So when I find one of these I pounce on it, running or not.
Last non-runner I bought was a 1948 Farmall Cub. As soon as I can clear a spot in my shop, it's engine gets pulled and sent to the engine shop for a complete rebuild (low compression on all 4 cylinders). That Bolens GT1453 lawn tractor in the background in the photo is taking up space now (new engine, new seals all around including rototiller seals).
Last runner was a 1945 Oliver 60 Row Crop.
It needed brake relining. Gear oil was like thick molassas when I drained the rear end. Needs new temp gauge. Otherwise it's pretty much parade ready as is.
/ Tractor Restorations #27
last 'non runner' i bought was my farmall C it had no battery and had been setting.
I hooked cables over to my truck, and actually managed to hand crank it strted 1 time.
came back the next day to get it.. and it would not hand crank ( tried for an hour! )..
when it did run, a steady stream of oil flowed out the place hwere a front crankshaft seal used to be.. :)
was a fun project. had no oil pressure gauge. etc. that 2nd day I came back out with a test gauge on a whip ( gauge on a grease gun hose with box of fittings ).. that's my test gauge I carry to evaluate old tractors.. etc.. had good pressure.. once we drug it off with a donor battery for coil power.. stiull wouldn't crank start / hand start at that point.. starter was all gunked up..
/ Tractor Restorations #28
Lookin good, SG:thumbsup:
/ Tractor Restorations #29
fun to drive...
/ Tractor Restorations #30
So, I just bought a MF 135, don't know the year as the mfg plate is missing. It is really a kit. The engine is removed and apart. Came with a Ford front end loader.. It's all there. It has the Multi-power transmission and remote rear hydraulics.. Motor needs a bottom end rebuild.. The head was just done, as were the injectors and pump. Weirdly, it has 16.9-24 rear tires (need replacing) and has brand new front tires. I have ordered every part to rebuild the motor, including a new crankshaft, liners, oil and water pumps, etc, etc. Paid $980 for it. I hope to have no more than $3500 into when done.
I own a race car shop and have all the equipment needed to rebuild it.. But my customers are a little freaked to see the tractor sitting next to their expensive road-racing machinery.
So far I've spent $70 on the fuel to go get it, $1500 on all the engine parts and a power-steering kit. The tires should be around $850 for the pair..
It will not get a pretty restoration as it will be a working tractor, but everything that needs to work will get attention. I'm in California so it has no rust. I'll post some pics as I have time.. And I'll keep y'all informed as I progress.
-John
/ Tractor Restorations #31
-John
Have fun :thumbsup:.
My 135 is a 1964 MF135 diesel deluxe with multipower. It's been partially restored but needs some work in my shop (oil leaks at engine and pto shaft, new clutch pack). It's a field tractor that's been modified for work in the olive orchards around here. The rears are Goodrich 6-ply 18.4-16A rubber on 16" dia rims. The front axle spindles have been shortened to keep the tractor level.
Good luck with your restoration. Looking forward to the photos
/ Tractor Restorations #32
WOW !!!!!!!!!!!
NICE !!!!!
Now that I've actually begun the process of restoring my Massey 135 tractor, I find that it's a very rewarding experience. Thankfully, I haven't found many unexpected surprises. As you can see, it's a work in progress.
/ Tractor Restorations #34
there's always surprises once you start taking stuff off and turning bolts.. and hardship cases yet?
So far, it's not been too bad. However, I did have some trouble with a couple of things. The steering wheel was stuck, and I had to cut and crack the hub to get it off the shaft. Also, the draft control spring clevis was stuck on the plunger shaft, and I had to weld the plunger shaft to the cup so I could use a pipe wrench and bar to unscrew it. Here's a picture of the draft spring assembly after I disassembled it.
/ Tractor Restorations #36
sounds about like a ford then.. :)
/ Tractor Restorations #37
ps.. that's wher ethe adventure is.
nobody wants a paint and drive tractor.. :)
Absolutely! For me, restoring it is as much (or more) fun than using it. Every day, I find myself slipping away to my garage, and tinkering with something new. Heck, I've barely begun restoring this tractor, and I'm already contemplating the next one. Perhaps an old Massey MF-35 will be next, or maybe an old Ferguson TO-35.
Yep, I'm hooked. :confused2:
/ Tractor Restorations #39
one of my favorite tractors was a 'put together' ford 950
probably half the studs and bolts in it were broke off, stripped or gouged out.. I drileld out bolts, welded them out.. backed them out for 2 straight weeks after work. yes.. 14 days straight.. removing and repairing threads. happy to say I never once had to use an insert. everything was in an area i got the shank out without damage to the parent.. or where I could oversize and rethread.. or relocate.. etc..
It's funny that you mention broken bolts. Last night, I was looking at the front of my tractor's engine, and noticed a timing cover bolt that apears to be broken off in the block. I won't know for sure until I eventually remove the timing cover, but there appears to be a decent amount sticking out so it shouldn't be difficult to remove if it is broken off.
I also discovered that my tractor has electroluminescent gauges. Rather than being illuminated by traditional light bulbs, they are illuminated by electroluminescence. It's difficult to explain how it works, so here is a link for a better description.
Electroluminescence - Wikipedia, the free encyclopedia
All of the gauges work, except for the generator (amps) and water temperature. When illuminated, they have a soft green glow that looks really cool at night. However, I suspect that finding replacement OEM gauges (new or used) of the same type may be difficult and/or expensive, so I am considering the possibility of replacing them all with new ones. However, I'd like to have accurate hours showing on the tach so that could create a complication if I decide to replace them all. I'll try to take a picture of one of them later.
HYUNDAI HL770-9A WHEEL LOADER (A65053)
HYUNDAI HL770-9A...
Towable Pipe Road Crossing Trailer (A63689)
Towable Pipe Road...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
2022 EZ-GO ELITE...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
